Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Indoor & Micro Electric Planes
Old 08-21-2006, 07:39 PM   #1
JohnnyC
Exclamation Looking for Channel Change Mod info
So far I haven't found much on the channel changing mod. I did find this picture which apparently shows where to solder in wires, but not much in the way of explaining what all I need or what.
If someone has the information about what kind of switch I need to buy and perhaps some instructions on how to do this mod, I would greatly appreciate it.
See... I have two AHAA's. The planes are both great, one of the controllers however, is not... it has a problem where the throttle wants to go to full blast unless I PULL down on the throttle stick, almost bending the stick itself. This has the effect of rendering that particular plane very difficult to fly since I don't have adequate throttle control on it.
If someone has a fix for me on how to fix the controller that is goofy, that could help as well, but I just assume put a channel switch on my good controller and use it for both planes.
Thanks in advance.
JohnnyC is offline
Old 08-21-2006, 09:25 PM   #2
ICHItheKILLER
ICHItheKILLER's Avatar
View ICHItheKILLER's Gallery4
Lol!! I copied that pic. It did not work. What you need to do is get a SPDT toggle switch "Mini center off" 26 gauge solid wire one spool red one spool black . In the pic you have there make sure that little blob of solder is in the middle like pic .I think thats A channel. Solder red to it and the two black to the sides of it and your done!!! I'll post the pic of mine, And my solder skills suck!
ICHItheKILLER is offline
Old 08-21-2006, 09:58 PM   #3
ICHItheKILLER
Name:	tx mod 001.jpg
Name:	tx mod 002.jpg
Name:	tx mod 003.jpg
Name:	tx mod 004.jpg
Old 08-21-2006, 11:10 PM   #4
JohnnyC
Excellent. Thanks for that. I will be heading out to radio shack tomorrow to go pick up the nessicary stuff to add that in.
List:
1 - SPDT Toggle Switch "Mini Center Off"
1 - Spool of 26 gauge, Solid wire, Black
1 - Spool of 26 gauge, Solid wire, Red
and a little skill at soldering.
Out of curiosity, why that gauge of wire and why solid?
JohnnyC is offline
Old 08-21-2006, 11:56 PM   #5
ICHItheKILLER
Its small enough to work with, and you want it to stay put and not flexable at solder connections. The solder connections are really small,I would have used smaller wire if i found it.
Old 08-23-2006, 12:21 AM   #6
jipp
Thanks for posting this, you made it perfecly clear how to do the mod.
pics worth a million words + 10;
I orderd some mini toggles, ( 3 ) and 20 diodes. Im good to go ( we have no radio shack near by and i could not find a store that sold mini toggle just big and medium size. so figure id pick up soem diodes since i used the last 4 i had in my eletronic parts organizer. never know when you may need one i guess ) , I will mod three TX and as long they dont where out ill be good to go.
chris.
jipp is offline
Old 08-23-2006, 05:10 AM   #7
JohnnyC
I picked up my stuff today to do the mod. I will most likely have it done tomorrow.
By the way... the drawers they have at radio shack with the switches in them... I found my switch in one that wasn't very clearly labeled.
JohnnyC is offline
Old 06-21-2007, 03:30 AM   #8
iceboxqs
This looks like a great mod. Does it really help at all?
Some of my friends and I have all bought various aero aces. We have noticed interference between radios that are on different channels.
My friend has a 27 A and I have a 27 B. We will get interference between the radios.
The interference does not give you control of the other plane it just kills the controls for the other guy.
Is this mod worth it? Is there a way to change the frequency up or down a notch? Like 28 or 26?
iceboxqs is offline
Old 06-21-2007, 07:25 AM   #9
Ryvon
Fly it backwards Scottie
Ryvon's Avatar
Send a message via Skype™ to Ryvon
all the AA operate on the same freq. Only difference is A=6 per second B=7, and C=8. The mod doesn't help with interference. It just helps if you have a couple planes on different freq. When you want to fly a different plane you switch freq. You can also add a switch on the Reciever, but you have to be fairly decent with an iron.
If its not broke, try harder.
Ryvon is offline
DX6 channel 5&6 change to rotary knob skorski RC Radios, Transmitters, Receivers, Servos, gyros 8 05-06-2008 06:28 PM
Info needed on 2 Channel Dragonfly jswigart Micro Sized Electric Helicopters 0 01-20-2008 05:39 PM
info needed on T-rexXl mainframe change theecoop Standard & Large E-Heli Talk 2 11-26-2007 04:03 AM
Need help with Aerao Ace 3 channel mod... Trex Indoor & Micro Electric Planes 8 04-25-2007 08:10 PM
How difficult and expensive is it to change what channel my radio is on? radioflyer75 RC Radios, Transmitters, Receivers, Servos, gyros 9 01-09-2007 12:34 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.35279 seconds with 41 queries
