Safe To Trust Esc Low Voltage Cutoff? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 12-27-2007, 05:33 AM
jsd316
Default Safe To Trust Esc Low Voltage Cutoff?
I am using a great planes silver series 25 amp brushless ESC with my 11.1v 1250mah 20C packs. Having only recently switched over from gas, I was wondering if it is safe to run the batteries until the ESC kicks in or if I should be using some other method of monitoring voltage during my flights to prevent battery damage?
jsd316 is offline
Old 12-27-2007, 12:26 PM
Sam_K
From experience, and advice from others, I have learned that it is NOT a good idea to use the ESC low voltage cutoff as an indicator of when to land.
Most ESC cutoffs are somewhere between 2.7v to 3.2v per cell. However if you discharge this low you will cause damage to your LiPo that will significantly decrease it's life span.
The current wisdom on Li-Po batteries, if you want to get the maximum life you can from them, is to not discharge them more than 80% of their total capacity. Thus from a 1250mAh pack you should never draw more than 1000mAh.
Also the standing voltage after a flight (say 10 mins later when the battery has cooled and voltage has recovered) should not be less than 3.75v per cell.
It will not kill your pack straight away to exceed these levels, but if you do it regularly then you will start to notice pack degradation (cell imbalance and/or loss of capacity) after only a few dozen cycles.
Sam_K is offline
Old 12-27-2007, 01:38 PM
JAM MaxAmps
JAM MaxAmps's Avatar
I agree, I go with the 80/20 rule also. Once you know your plane well enough set your timer and fly to the buzzer. Most planes that use the same battery pack size can generally be set to the same time if the power systems are similar. With the pack you have depending on amp draw and flying type do a 6 minute flight on a full pack and see what is left in it. Then you can adjust accordingly of course if it's a really low amp draw system you'll be able to go much longer.
Jason
JAM MaxAmps is offline
Old 12-27-2007, 06:19 PM
flydiver
flydiver's Avatar
Absolutely NOT!
This is the spec for that unit (quote):
http://manuals.hobbico.com/gpm/gpmm1800-manual-v1_1.pdf
Low Voltage Cutoff: Battery voltage x 0.67
12.v x .67 = 8.5 (much too low). Shouldn't trust anything under 3.0v/cell, 3.3v is much better.
IMO these should not even be sold along with similar miserable ESC's.
fly
flydiver is offline
smitty
07-21-2007 09:17 PM
smitty
07-15-2007 07:00 PM
p901
05-01-2007 05:24 PM
rx20040
09-20-2006 01:50 PM
oaktown
04-28-2006 01:39 PM
Quick Reply: Safe To Trust Esc Low Voltage Cutoff?
Page generated in 0.08690 seconds with 13 queries
