Slow Stick Wing - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Slow Stick Wing
Old 05-30-2008, 10:16 PM
Benson1
Trout Bum
Default Slow Stick Wing
I have not flown in 35 years so I am starting on a SS to refresh my skills. This sport has come a long way and I like electric. I did not think much of the slow stick when I saw my neighbors, but this forum changed my mind when I read about the many mods that could be made. I bought one, flattened the wing and added ailerons, brushless moter but no lipos yet. I use an 8 cell nimh with 1100 mah. I busted my first wing several times and finally needed another. It is cheapest to by the glider version and you get all the other stuff, but I like to screw around building. I have scratch built several planes over the years and most recently a Pietenpol that I am too chicken to fly yet. In any case I built several wings but they took too many hours with traditional techniques. I found one that I really like using Dan Schwartez's (Foamfly.com) Wing Jig and Bluecor.
I modified the jig to incorporate 6 ribs instead of 5. I also wanted the ribs to show on the top profile. I cut the top section of the ribs off and glued them to the top of the 1/32 nd ply form directly over the ribs under the ply. I then used matt board( thicker) rather than poster board for the cover.
In that cover I cut slots directly over the exposed ribs. This kind of acts as a female mold over the foam when cooking in the oven. When I remove the wing from the oven I gently rub the mold between the ribs giving some down pressure but not as far as the leading edge. The wing works great, is fast and easy to make and cost about a buck not counting reinforcing and epoxy. There seems to be no distortion in the airfoil using this modificaton and I reaaly like the impression of seeing the ribs. The wing on the plane below has ailerons and I used foam to make a flat bottom. I think this works better in the wind as opposed to the original under camber. That wing weighs 7.5 OZ. The wing beside the plane has no A's and no bottom foam. It weighs 2.5 OZ. I just like the way the plane responds with the A's
I stuck the Peitenpol pic in just for fun. It is not a foamie.
ID:	67618   Click image for larger version
ID:	67619   Click image for larger version
ID:	67620   Click image for larger version
Benson1 is offline
Old 05-30-2008, 10:26 PM
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Wow excellent job on the wings, and nice plane hanging too looks really good. How does the stick fly?
if you would use a rudder, how would undercambered wings work for ya? 7.5oz for a wing seems much, but then again you said you liked ailerons more and that is a flat bottom airfoil type wing..
oh and you use an oven? wow thats really neat.
i like how your wings look, they look like GWS wings.
GreenAce92 is offline
Old 05-30-2008, 10:52 PM
Benson1
Trout Bum
Thanks! The ss flies great! The weight is a bit high on that wing but my brushless will handle a 40 oz plane. Mine is 30. The under camber just behaves poorly in the wind, but otherwise is fine. That wing is much faster to make. The oven handles 20 inch sections that you can put together in any configuration you want, even two together to go symmetrical. Someday I will learn to fly again to handle situations better, but I like building the most. Oven info at foamfly.com
scott
Benson1 is offline
michaeljvdh
ParkFlyers
18
12-09-2009 03:56 AM
xray328
Aerial Photography
09-30-2007 07:34 AM
BilliamReturns
ParkFlyers
9
05-02-2007 05:18 AM
TheOldGuy
02-05-2007 06:02 PM
ParkFlyers
17
10-31-2005 06:27 PM
Quick Reply: Slow Stick Wing
Page generated in 0.09162 seconds with 18 queries
