Takeoff from bumpy grass yard?
Old 02-26-2017, 12:54 AM
craigrs84
Default Takeoff from bumpy grass yard?
I have the E Flite Taylorcraft 450. I'd like to fly it at my grandparent's farm where they have a large grassy area. The ground has some bumps and grass is probably mowed to about 2.5 - 3.0 inches.
Are there any special wheels I can order that would allow me to take off under these conditions with a lightweight model like the taylorcraft? I currently have 2.5" inch wheels but when I tested it in my own yard it gets stuck very often and noses over so that the prop hits the ground.
Can you recommend brand and size? Thanks.
craigrs84 is offline
Old 02-26-2017, 01:22 AM
remove the wheel covers and get some large balloon style wheels like seen on real planes that land on rough ground. find a video of planes like yours that are real and scale from there. your wing span is plenty to be able to take off in 2-3inch grass.
Images of rc balloon tires
https://www.youtube.com/watch?v=mFaBtlV-P2k
Jump to: navigation, search https://www.rcplanet.com/E_Flite_Tun...efl1045012.htm
Maule M-7-235C on bushwheel-style tundra tires
A tundra tire (UK: tundra tyre) is a large low-pressure tire used on light aircraft to allow operations on rough terrain.[1]
A common variant of tundra tire is the bushwheel. These tires include an integral inner tube with the valve manufactured into the side-wall, allowing the tire to operate at very low pressures without risking shearing-off the valve stem and causing a flat tire. Low-pressure tires provide greater cushioning and enable aircraft to land on rough surfaces, unsuitable for normal tires.[2][3] Bushwheels are a common
Old 02-26-2017, 01:51 AM
Great Vid!
Old 02-26-2017, 06:10 AM
craigrs84
I ordered the Dave Brown 4.5" foam wheels.
Perhaps a little on the large side for a model this size but I wanted to go bigger rather than smaller. Fingers crossed that this works. I guess it's only $12 lost if it doesn't.
Old 02-26-2017, 11:19 AM
Another option could be positioning the wheels forward.
My experience in flying off grass is that the aerobatic planes perform the best. Many of the designs have the wheels places well forward of the CG. We use no wheel pants and still run oversized wheels on the smaller models. The 3D/aerobatic planes offer large tail surfaces for "blowing" he tail down and generally offer greater amounts of thrust. When the grass really gets out of hand, you can basically punch the throttle and with some fancy control work get on top of the grass and then get in the air in a short distance.
As a last resort, there s always hand launch/belly landing.
Dragon Master
11-25-2013 04:56 PM
CNY_Dave
07-03-2013 02:43 PM
mbarker
11-22-2012 07:25 PM
Timewarp
Foamies
8
09-16-2012 03:28 PM
wolfewinde
15
08-12-2011 03:15 AM
Quick Reply: Takeoff from bumpy grass yard?
Page generated in 0.10781 seconds with 13 queries
