Spektrum DX5e and FMS
Old 11-19-2009, 03:28 PM
dancal
Default Spektrum DX5e and FMS
Hi folks, there is my first message in the forum so let me start by saying, Hello!
I've just bought a Spektrum DX5e with an Easy Star from multiplex. Anyway I would like to use this transmitter with the FMS simulator software in order to develop my skills as a pilot as I used to do with my Zebra transmitter.
Although the Spektrum has a trainer jack I'm unable to make it works with FMS. There is no signal, no movement, nothing!
Any good advice? Thank you for your help.
dancal is offline
Old 11-20-2009, 01:39 PM
kaindub
You will need some sort of interfacing cable to your PC.
have a look on the web (even ebay) for cables for JR transmitters to PC for flight simulator.
the cable goes into the USB port.
You can't plug the DX5 into the sound card port even though the connectors are the same.
kaindub is offline
Old 11-20-2009, 05:51 PM
flydiver
flydiver's Avatar
Actually you may be able to. The trainer > USB cord is easier though.
If you want to try the straight trainer cord > sound card you do need this program-it won't work without it:
SmartProPlus
You can get a lot more info by browsing in the FMS Forum if that doesn't work.
You aren't the only one with problems.
flydiver is offline
Old 11-22-2009, 04:10 PM
dancal
Thank you folks. It was my fault!!
I was using a cable connected to the sound card with smartproplus. But I connected the cable while the transmitter was on (as I used to do with my previous transmitter) and that's not the way to go with Spektrum.
You need to plug the cable while the transmitter is off. Tha transmitter knows you want to use the slave-mode and it turns on by itself in that mode and ... it works!!
Once again, thank you.
dancal is offline
Crash N Burn
10-22-2009 04:17 PM
Rabbitcreekok
19
03-24-2009 08:17 PM
Bill Hawthorne
03-01-2009 10:14 PM
Bill Hawthorne
01-01-2009 05:30 PM
Rickochet
12-28-2008 03:38 PM
Quick Reply: Spektrum DX5e and FMS
Copyright İ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
Page generated in 0.08774 seconds with 13 queries
