Running/Charging Lipo's in Parallel
Old 02-07-2007, 02:54 PM
p_r_i_m_e
Loony Toon
Default Running/Charging Lipo's in Parallel
Hi, I have made up a Y lead to run my 2 Emax 1650 11.1v (15c)lipos in parallel
as singularly as the current drain from my std brushed Multiplex Moviestar at WOT draws 29amps (over the 15c Spec of the battery)
Whilst this has proved sucessful as the batterys stay cool and duration is excellent, my concern is that as the battery packs are also used in other planes (singularly) that out of balance problems might occur (between packs) would it make sence to do a top up charge using the "Y" adaptor to ensure that both packs have the same charge in them before each flight or carry on charging them singularly.
Thanks in advance for you advice.
p_r_i_m_e is offline
Old 02-07-2007, 10:30 PM
JoshGordon
JoshGordon's Avatar
Do you use a balancer when charging the packs?
You should really be using a balancer everytime you charge the cells - the balancer allows the cells to get an even charge and helps maintain the life and performance of the cells.
Joshua Gordon
Common Sense RC
www.CommonSenseRC.com
Toll Free 866-405-8811
JoshGordon is offline
Old 02-08-2007, 12:52 AM
p_r_i_m_e
Loony Toon
each cell in each pack will be balenced using a balance charger, however as this set up uses 2 packs could it not end up that one pack is slightly higher than the other even though both packs are balance charged?
Old 02-08-2007, 01:24 AM
Jacket Man
Jacket Man's Avatar
If you leave two packs wired together in parallel, in a short period of time, they will equalize and have the same voltage.
Jacket Man is offline
Redneck Air of ME
9
05-15-2008 02:54 AM
humboldt guy
34
03-02-2008 07:39 PM
PerlAddict
8
11-25-2007 01:23 AM
rx20040
10-12-2007 10:29 PM
Water Bug
04-17-2007 12:01 AM
Quick Reply: Running/Charging Lipo's in Parallel
Page generated in 0.11208 seconds with 13 queries
