sell balsa wood
Dear Sir,
Our company located in Lampung in Indonesia.
We have resource of Balsa wood in our region and now we want to continue planting it so it could be available continually.
We can supply balsa wood any size and good quality.
Balsa Block
Thickness Width Length
60mm 101mm 1200mm USD580/CBM
60mm 101mm 1020mm USD530/CBM
60mm 101mm 930mm USD490/CBM
60mm 101mm 780mm USD420/CBM
60mm 101mm 630mm USD390/CBM
60mm 107mm 1200mm USD600/CBM
60mm 107mm 1020mm USD535/CBM
60mm 107mm 930mm USD495/CBM
60mm 107mm 780mm USD425/CBM
60mm 107mm 630mm USD395/CBM
Balsa Sheet
Width Length Thickness
10cm 100cm 1 mm = USD0.15/sheet
10cm 100cm 1.5mm = USD0.15/sheet
10cm 100cm 2 mm = USD0.20/sheet
10cm 100cm 2.5mm = USD0.25/sheet
10cm 100cm 3 mm = USD0.30/sheet
10cm 100cm 4 mm = USD0.35/sheet
10cm 100cm 5 mm = USD0.40/sheet
10cm 100cm 6 mm = USD0.45/sheet
10cm 100cm 7 mm = USD0.50/sheet
10cm 100cm 8 mm = USD0.55/sheet
10cm 100cm 9 mm = USD0.60/sheet
10cm 100cm 10mm = USD0.60/sheet
2)Dowel
length diameter:
100cm 2mm = USD0.02/sheet
100cm 3mm = USD0.03/sheet
100cm 4mm = USD0.03/sheet
100cm 5mm = USD0.04/sheet
100cm 6mm = USD0.05/sheet
100cm 7mm = USD0.06/sheet
100cm 8mm = USD0.07/sheet
100cm 9mm = USD0.08/sheet
100cm 10mm = USD0.09/sheet
100cm 15mm = USD0.1/sheet
3)Sticks
2mm 2mm 100cm = USD0.01/sheet
3mm 3mm 100cm = USD0.02/sheet
4mm 4mm 100cm = USD0.03/sheet
5mm 5mm 100cm = USD0.04/sheet
6mm 6mm 100cm = USD0.05/sheet
Density : 130kg/CBM.
please contact us : balsaindo(at)yahoo(dot)co(dot)id
Balsa Block
Balsa Sheet
2)Dowel
length diameter:
3)Sticks
pace_likethesalsa
03-11-2009 04:47 AM
