looking
Old 07-21-2008, 05:41 AM
pvtzemerak
3D Huckifyer!
pvtzemerak's Avatar
Default looking
Hey guys, im looking for a 1-3 cell lipo charger that i can charge in my car. i dont like the crocidile clips. i want something i can use in a wall or in a car jack. im trying to charge this lipo
http://www.hobbypeople.net/gallery/182253.asp
can anyone help me out? im trying to keep it under 50$.(so i can save up and buy the spektrum dx6i )
--pvt
pvtzemerak is offline
Old 07-21-2008, 07:34 AM
ministeve2003
Class Clown
ministeve2003's Avatar
--pvt
eeek, $56 for a 3cell 2000 pack...
too bad these are out of stock right now... or I'd recommend them over that impulse pack anytime... heck I'll still recommend them...
http://www.hobbycity.com/hobbycity/s..._15C_Lipo_pack
Charger options
cheapest.... option
http://www.hobbycity.com/hobbycity/s...Charge_Capable
better... option
http://www.hobbycity.com/hobbycity/s..._Charger_6cell
I'm not sure about your battery, it appears to have hyperion style for the balance tap, which wouldn't fit the jst-xh one on these chagers but you can always order the adaptor for a couple dollars...
adaptors on this page...
http://www.hobbycity.com/hobbycity/s...6&ParentCat=85
SK
ministeve2003 is offline
Old 07-21-2008, 02:32 PM
Bluebird
Hey pvt! Steve's right on with his recommendations. The LoongMax/ZippyK has caught on big time. Our e-club has a hundred or more in use now. I've got 54 cycles on my 'test' pack and it's still goin' strong. Hobbycity has a number of LiPo and multichemistry chargers. Check 'em out!
Bluebird is offline
Old 07-21-2008, 03:36 PM
pvtzemerak
3D Huckifyer!
pvtzemerak's Avatar
THanks steve! where do i plug in those croc clips? thats what confused me, i thought i woould have to buy another 60$ item
Old 07-21-2008, 05:39 PM
Hughes500Bob
Full Scale Pilot
Check out the fuse on your car jack ..... dedicated accessory jack, or cig lighter. If you want to charge at 1C, then you would be putting out 2 amps of current plus the charger circuitry amperage useage. So lets just say you have a 5 amp fuse and things are looking good. Next I would check the wire to the 12 volt car jack and make sure it could handle the load (16 ga would be used for 3 amp typically). Maybe your owners manual would list the load that could be put on an accessory jack.
Better yet is to look on your underhood fuse box and see if it has an aux post on it. If it does then it would be better for you to make your own 12 volt line and coupler to your charge unit using good heavy duty wire.
Hughes500Bob is offline
Old 07-21-2008, 08:28 PM
Sir Raleigh
If you live in the US here are a couple of suggestions available from Radio Shack:
Vehicle Power Adapter Plug with Banana Jack No need to remove the alligator clips with this one.
Or, if you don't mind doing a little soldering you can use this 12VDC 7.5A Power Plug
Sir Raleigh is offline
Old 07-21-2008, 08:31 PM
ministeve2003
Class Clown
find an old cigarette lighter adaptor from any old phone charger or whatever... cut the end off , split the two wires, and you got yourself an adaptor, works good if you solder some type of clip to it, make sure the two ends never meet again after that though...lol
also Pepboys or any car place has an adaptor...
SK
Old 07-21-2008, 08:34 PM
ministeve2003
Class Clown
for home, I picked up an old laptop 15volt 5amp chager for 10bucks on ebay... cut the end off and splt the two wires and soldered some ends to it.... so I can clip it on there too....
SK
Old 07-21-2008, 10:55 PM
pvtzemerak
3D Huckifyer!
pvtzemerak's Avatar
hmm, i think ill stick to the car jack one that ministeve sent me. 20 dollars and no banana plugs. right? i just shove that into the cigarete lighter and its ready to go?
Old 07-22-2008, 12:26 AM
Frank Voikel
Frank Voikel's Avatar
That's what I have. Works great, yep, shove it in and it's ready.
Frank Voikel is offline
Page generated in 0.13713 seconds with 12 queries
