2,4 Ghz Transmitter to 1,2 Ghz?
Old 08-17-2008, 12:18 AM
VCtony
Default 2,4 Ghz Transmitter to 1,2 Ghz?
Hello,
Is it possible to switch a 2,4 Ghz transmitter into a 1,2 Ghz ?
Maybe there is just a chip, which I have to switch?
And is it possible to gain up the signal of a futaba remote control?
regards, tony.
VCtony is offline
Old 08-17-2008, 01:22 AM
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
Are you sure it's even legal to use 1.2GHz for RC aircraft?
FlyWheel is offline
Old 08-17-2008, 01:29 AM
fr4nk1yn
^_^
fr4nk1yn's Avatar
I'm curious to what benefits there would be to that.
Posted via Mobile Device
fr4nk1yn is offline
Old 08-17-2008, 01:53 AM
VCtony
Yes and No,
It's illegal in the USA but in some countries in the EU it's legal I think.
Here in the EU it is really illegal to use your 900Mhz systems, you can get a very high punishments.
So do you think, it should be possible to switch from 2,4 Ghz to 1,2 Ghz?
regards, tony.
VCtony is offline
Old 08-17-2008, 03:48 AM
FlyWheel
FlyWheel's Avatar
I wouldn't know how to do the actual dirty work, but theoretically it shouldn't be too hard, assuming it's possible. 1.2 is just a harmonic of the original 2.4. However, technically, as an unliscenced user you're not supposed to alter your transmitter's emmisions. That's why they don't sell transmitter crystals (I don't think 2.4GH transmitters even use crystals, even CB radios use phase-lock loops these days).
Most certainly you'll void any warranties.
FlyWheel is offline
Old 08-28-2008, 08:00 PM
Blaze.45
Caution: Contains NuTs!
Blaze.45's Avatar
Ask, and ye shall recieve.
http://www.freeantennas.com/projects...te2/index.html
Note that this reflector is for 2.4Ghz only and will boost your signal by as much as 50-60%, however it is now directional, which means you have to keep the reflector pointed at your plane. The best part about it is that you can simply slip it on or off of your antenna in less than a second depending on your preference.
Some of us use this in FPV flight once in a while when we get out to around 2 miles or so.
-Chris
Blaze.45 is offline
pd1
07-07-2008 04:38 AM
CaptainCub
02-08-2008 03:08 AM
MarkL
09-25-2007 03:57 PM
Fly Time
08-31-2007 07:37 PM
MarkL
General RC E-Heli Talk
08-09-2007 04:16 PM
Quick Reply: 2,4 Ghz Transmitter to 1,2 Ghz?
Page generated in 0.06421 seconds with 12 queries
