Depron SlowPoke - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Depron SlowPoke
Old 01-03-2012, 10:35 PM
vuoladodo
Default Depron SlowPoke
Hello,
About three years ago I built a Slow Poke and documented the build for RCHangout--now defunct. I am now living in Germany and while the kit is available in the US it seems hard to find. Also, in Berlin its not possible to fly Nitro so I decided that I would try to put together the plane in Depron. I am using both 5mm (sold as 6) and 3mms. I am essentially following the plan but reduced by 30%.
Because Depron is a lot lighter than wood, I assume this plane will be a lot less able to handle wind and with the shortened body the elevator will presumably be even twitchier. If you have any experience or recommendations with this, do let me know.
Ok, so here are the first three photos of the fuse (upside down build) with the bottom formers.
Good flyings...
VD
ID:	156077   Click image for larger version
ID:	156078   Click image for larger version
vuoladodo is offline
Old 01-03-2012, 10:41 PM
constantCrash
prefectionist
constantCrash's Avatar
Some insperation for you:
http://www.rcgroups.com/forums/showthread.php?t=1420943
It came out heavy, with bad balance. Extend the nose a bit and widen the body.
constantCrash is offline
Old 01-03-2012, 11:34 PM
vuoladodo
Oh man, it looks fantastic, though. I think a plane with the elevator so close to the trailing edge of the wing and such a massive chord probably needs the dihedral angle to add a bit of stability. Unless of course you wanna go GeeBee. But that comes at a price. Usually the pilot's life.
Old 01-17-2012, 09:30 PM
vuoladodo
Default Bottom fuse.
Hey everybody. Here are pictures of the bottom fuse with the detail of the wing saddle. I will be putting in the next few days the doubler for the wing seats on the side walls.
As opposed to the Depron Poke, this one is not made in bluecore but in depron so I think that generally it will be lighter. This plane is normally very pitchy because the elevator is very near the trailing edge of the wing. However, I am not planning to change the length or proportions. We shall see.
VD
ID:	156488   Click image for larger version
ID:	156489   Click image for larger version
Old 02-13-2012, 07:14 PM
southside
Default design parameters-balsa v. foam
Following balsa plans to build a foamy is not destined for success. That always ends up too heavy and rarely, if ever, gets rigid enough to perform well.
For me, "bent" foam was the answer. It gets extremely rigid and strong, allowing many structural components that are necessary in a wood model to be eliminated.
Judicious use of "strengtheners"(plywood, balsa, bamboo skewers,carbon fiber rods and strips) in particular areas is called for.
Playwith the foam, build a few 'throwaways' and learnhow versatile foam can be.
good flying.
southside is offline
Old 03-20-2012, 06:36 PM
Air-on
Default Please continue...
South,
Well designed plans take into consideration the building material. Therefore, you are probably right about the weight if you build it without updating the build technique.
I am building in depron "out of nowhere", developing my own solutions, because I could not find any specific depron plans.
Because I feel depron is an excellent building material, I would like to team with people like you to try and develop a multi-purpose, or "general" depron scratch building technique (I dream of electric multi-engines! a DC3 or a C47! Or the "Tante Ju"! ).
I am starting a new build thread: "Depron SB Piper C. Mini FF". Please be on the lookout, and help me there!
Also, don't give up! Keep sharing more of your findings, thoughts, frustrations - and pictures!
Have a great day!
Aharon
Air-on is offline
Old 03-21-2012, 01:20 PM
Crashalott
Crashalott's Avatar
Heya VD, did you ever finish the Slowpoke?
Crashalott is offline
Old 03-26-2012, 11:26 PM
southside
Default things Iv'e learned about foam building
Originally Posted by Air-on View Post
South,
Have a great day!
Aharon
bentfoam techniques are tricky,but give the most rigidity to a build. Nose to tail former (called thrust plate) is a great place to start a fuselage. stiffenners like bamboo skewers and carbon tube or strips help airframe integrity greatly.
Foamies crash like any other plane, so I have been building with damage control in mind....crumple zones at the nose,integral wing units that break away in a crash...things like that. I use low melt hot glue -foam to foam, and gorilla glue or epoxy, foam to wood. Gorilla glue if i am attaching plastic to foam. For prettier builds use lightweight spackle. Use water base polyurethane and craft paint(acrylic) if you are going to paint your models. dollar stores sell packing tape that is very thin and light, I use it to protect leading edges on the wing and sometimes I cover the whole plane with it(combat wings and things like that). Foam flies great and is a blast to play with.....south
Old 03-26-2012, 11:50 PM
southside
Default tiny foamy bipe
This has an ax 1806 19 gram motor and three 5 gram servos. flies slow and fast(fast for its size, anyway) motor cowl is made from a glucosamine bottle. wing system was saved from earlier crash....for a small plane it is surprisingly easy to control, if a bit pitchy.
made out of 2mm and 3mm depron.
Name:	photo (3) (1).JPG
ID:	158517   Click image for larger version
Old 04-18-2013, 08:32 PM
vuoladodo
Ok, so the bird is almost done. I am having an ESC problem and need some help.
Old 04-19-2013, 12:25 AM
road king 97
old hat
road king 97's Avatar
This plane's plan came from Germany and they have some great plans there.I am signed up in their forums . joe
Name:	slowly 5 mine.jpg
ID:	167937   Click image for larger version
Name:	slowly 6 mine.jpg
road king 97 is offline
Old 04-19-2013, 02:22 AM
southside
Default More biplanes and things
It's been a while since i visited here, I have some photos to share
Name:	pitts  24 002.jpg
ID:	167955   Click image for larger version
Name:	pitts  24 013.jpg
ID:	167956   Click image for larger version
ID:	167957   Click image for larger version
ID:	167958   Click image for larger version
Old 04-19-2013, 02:42 AM
southside
It's been a while since i visited here, I have some photos to share. I have built the swee'P' at 17", 24" and pushed this version out to 29''. Flies like it should....with 54 gram turnigy bell motor at 1200 Kv...1000 mah 3S batt. Aerobatic and beautiful in the air.
The little pitts is great fun and is made of dt foam. 1300 blue wonder w/8x6...800 2s.
Old 04-19-2013, 12:34 PM
vuoladodo
This plane is beautiful. WHere did you get the plan? I have an idea for a manta which is a paper glider. But this could be my next project. Those are KF wings, right?
Old 04-19-2013, 12:40 PM
vuoladodo
Default Here it is
So, this is the almost finished plane. It is missing the pilot which I will get to in the next few days. I will probably maiden it tomorrow. Hey Southside, I would love to get a hold of the plans for the sweetP and the Pitts. How big is the pitts?
Name:	Photo on 2013-04-19 at 13.31.jpg
ID:	167964   Click image for larger version
Name:	Photo on 2013-04-19 at 13.31 #2.jpg
ID:	167965   Click image for larger version
Name:	Photo on 2013-04-19 at 13.31 #3.jpg
ID:	167966   Click image for larger version
Name:	Photo on 2013-04-19 at 13.32 #2.jpg
ID:	167967   Click image for larger version
Name:	Photo on 2013-04-19 at 13.32.jpg
Old 04-19-2013, 12:43 PM
vuoladodo
Hey Joe, what is the name of that plane?
Old 04-19-2013, 02:41 PM
road king 97
old hat
The name of the plane is the slowly and you can find the plans a video here plus Jurgen and christian from germany dropped in with theirs.http://www.rcgroups.com/forums/showt...0#post22098736 Here is the German thread on it also. joe http://www.rclineforum.de/forum/boar...load/?052484f9
Old 04-21-2013, 06:12 PM
vuoladodo
Ok, so I just meidend the plane in quite a bit of wind. I started out a bit tail heavy and quite a bit of purposing. I added a few grams and went back up. It flies like a dream. If flies, actually, just like the original though a lot faster and can be a lot more agressive. Yet, against the wind you can more or less park it in the air. Also, smaller means you need to control your expo or you will have a twitchy plane. Good to warm up the fingers but not necessarily relaxing. Either way... I love this plane.
imarealslow
11
05-12-2012 12:27 PM
fly_lots
Foamies
11-03-2011 11:20 PM
prof_fate
Foamies
10-26-2011 04:18 AM
Davethebluessinger
Foamies
08-12-2011 08:47 PM
n3o
07-23-2011 06:47 AM
Quick Reply: Depron SlowPoke
Page generated in 0.08874 seconds with 34 queries
