Super Cub- larger battery quesyion
Old 07-28-2007, 01:09 AM
Larry G
E-Pilot
Default Super Cub- larger battery quesyion
I have the stock 8.4 volt 1000 mAh battery in my Super Cub, and I read the optional 9.6 volt 900 mAh works better.
I also have a Spitfire with 10.8 volt 1000 mAh 9 cell battery. I thought I read in a forum that someone has used this battery in a Super Cub.
Would the 10.8 volt fry the Super Cub's stock Rx ESC or motor?
The motors in the SC and Spit are supposed to both be 480 and use the same prop size, but are different part numbers.
Larry
Larry G is offline
Old 07-28-2007, 03:39 AM
batman
batman's Avatar
If they fit you could use them and they would give you more power but if you use the extra power it will shorten your flight times, and lets face it, you would use the extra power, right? I couldn't say how much shorter the flights will be as lot depends on how much throttle you use.
batman is offline
Old 07-28-2007, 05:08 PM
Larry G
E-Pilot
Sure, anything could be made to fit.........but I want to hear from Super Cub owners who run the 10.8 volt 1000 mAh 9 cell battery and didn't fry their electrics.
Larry
Larry G is offline
Old 07-28-2007, 05:40 PM
Gnascher
Got My TX - Need 2 Fly!
Gnascher's Avatar
People are flying 11.1V Lipo through the stock speed controller and motor. I haven't heard of either frying.
I'm sure your 10.8 Nimh will be fine if it fits in the battery compartment.
Gnascher is offline
Old 08-06-2007, 09:54 PM
Prof100
A 3S 11.1 volt Lipo works great with a Super Cub. Just avoid the rookie mistake of flying wide open throttle all the time.
Prof100 is offline
nazgul
Batteries & Chargers
16
09-17-2012 04:32 AM
geetee
02-07-2008 08:23 PM
Prof100
ParkFlyers
10
07-09-2007 11:07 AM
diablo
01-21-2007 01:14 AM
OhioBuckeye
01-15-2007 05:59 PM
Quick Reply: Super Cub- larger battery quesyion
Page generated in 0.11045 seconds with 13 queries
