Storing balsa and plywood?
Old 02-10-2021, 09:46 PM
RKTLaunch
Default Storing balsa and plywood?
How do you guys store balsa and plywood? Will it warp?
RKTLaunch is offline
Old 02-11-2021, 08:24 AM
I sit all mine on a flat benchtop and have weights on it. It keeps perfectly.
Old 02-11-2021, 09:12 AM
Cool dry area ..... yes it does warp if it has any chance !! Heat and moisture are its enemy.
Old 02-11-2021, 04:31 PM
RKTLaunch
I don't have any weights I can put on it. Certainly cold, unheated and rainy outside. All I can do is lay them flat.
There still in the boxes from BalsaUSA. I suppose I could put them all in one box.
Old 02-11-2021, 05:04 PM
TBH - I have sheets of Balsa and ply - they are not specially stored. Some have been in open box for years ...
Old 02-11-2021, 05:42 PM
Past President of PSSF
Default I built a special cabinet
Being a cabinet builder has it 's benefits. I built a special cabinet in my model room.
Part of it was designed for storage, The smaller drawers are 6 1/4" wide and 50" long for the rare choice pieces. The bottom drawer is 20" wide and 50" long for full sheets of aircraft plywood and large scraps.
The front has 15 drawers for other things and the top is 1 1/2" thick to hold my small drill press, small scroll saw and a micro table saw.
Name:	Balsa drawers 2.jpg
Wildflyer is offline
Old 02-12-2021, 02:55 AM
I have a cabinet also but they are all lateral drawers and shallow. Each one has a different size wood in it.
ID:	188367   Click image for larger version
ID:	188368   Click image for larger version
Old 02-13-2021, 12:48 AM
RKTLaunch
Nice cabinets, both. I doubt that I'll build long enough to justify building something like these. I built for many years and stopped, just picked it back up to build a couple ideas I had years ago, but that may be all. I never worried about storage, having a really good hobby shop near by. Most of those places are gone now and you have to ship everything.
Old 02-13-2021, 01:10 AM
Hobby Lobby and Michaels crafts stores usually carry a pretty good supply. I get from my HL quite often. Not contest grade balsa but good enough for the average builder.
Old 02-13-2021, 06:28 PM
RKTLaunch
Yeah, one of my leading edges (1/2 x 3/4 x 36") has warped. Hope I can bend it back. I'll try and leave it bent the other way, just a little for a while....before using it.
Old 02-14-2021, 06:14 PM
Warps .... there are a number of ways to sort ...
Water .... wet the wood and then gentle heat ... while the item is eased to opposite way of warp ... let cool
Ammonia or Window Cleaner .... similar action.
Warps happen because one side contracts or expands due to external conditions affecting that side ... Or simply that the item has stood on one edge at an angle.
You can actually reproduce the effect with Water and Dope ... Dampen one side, paint Dope on other ... watch it warp as the Dope causes it to contract ... If you can control this - then you can use it in model building to advantage.
Old 02-25-2021, 02:21 AM
RKTLaunch
How much water, spray bottle...or under the faucet?
antione
02-07-2019 06:10 PM
Merritt
02-17-2013 11:53 PM
payne9999
34
11-26-2011 02:52 PM
hillbillynamedpossum
10
04-06-2011 03:16 PM
Quick Reply: Storing balsa and plywood?
Copyright İ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
Page generated in 0.09002 seconds with 14 queries
