T28 Trojan
#801
Hi guys. I posted this elseware but got no respone so I thought I'd try here. I'm new to all this RC stuff. Now I'm gonna get a HZ Supercub to learn on. But I managed to pick up 1 1/2 Trojans earlier this week. Ones complete (stock) and the other needs all the electronics, motor etc. I'll fly the stock one after the Cub. But I was thinking of making the other one the fast one that will come after I've mastered the stock one. I will be using the DX6i transmitter. I have gone through this thread and come up with this setup.How does it sound?
The Fast Trojan
Motor: Turnigy SK-3536-910
Motor Mount: HXT-C35-30
ESC: Tunigy Sentry or Plush 40A
Battery: 2200mAh 3S 25C Zippy Flightmax
Receiver: AR6000
Prop: ??? I need help with this
Corsair Prop retainer with T-28 hub
Aileron/Elevator/Rudder Servo: ??? absolutely no idea on this either. Help here too.
Sorry for the long post but as I said I am a newb so I'm gonna ask dumb questions. Thanks in advance for your help. Cheers Paul
The Fast Trojan
Receiver: AR6000
#802
Master of Bisaster
Sounds good on the fast one. I just got a letter that my Turnigy Motor/ESC, etc. is at Customs, I will go pick it up on Monday, and hope to post some info regarding the setup.
I thiink Robjinhouston uses the 11x7E prop with the 35-36C with excellent results. As for servos, use Hobby City servos and order them now, it takes a few weeks for delivery. I believe the HXT 900's are the ones you would use for the Trojan, but I don't use them (yet) so someone else will have to help you there.
http://www.hobbycity.com/hobbycity/s...wer_Search.asp
And DO learn on the SC first like you said. The stock Trojan will keep you satisfied for quite a while too though.
#803
First crash on the trojan. Came in short on a landing and clipped the edge of a roof separating the body from the wing.
The only real damage is that it pulled the mounting plates out of the fuse and I could not locate the rear chunk of foam and the rear plastic insert that goes into the fuse. (I reinforced the rear mount on the wing so it was fine and the front fuse mount was still attached to the wing with a screw.)
Q1 - Do they sell replacement parts to repair the wing / fuse otherwise I will have to fabricate my own.
Q2 - Wondering out loud if I should have used a nylon attachment screw that might have sheered in the crash and caused less damage.
#804
Hey Clint,
I've had the wing pull out, it seems to be a common occurrence. I posted some pics on how I reinforced the area in this thread, somewhere.....
I don't think a nylon bolt would help much, since the bolt goes thru a plastic housing. But, YMMV.
You can get a new wing from Horizon: http://www.horizonhobby.com/Products...ProdID=PKZ4420
#805
Hey Clint,
#806
I also used a little epoxy to snug up the tail section of the fuse that had begun to separate.
I am going to let it cure overnight but I belive it is ready to fly.
Clint
#807
hmm... I run that 35x36x910 motor on 4cell and 12x6, 11x7, 11x4.7sf props.. on 3cell I'd prob go with the 1100kv version and run the same props...
I'm running hxt900 servos on all surfaces... If you want good stuff, you can either use midsize - hitec hs82's or smaller - hs65's... I think the hs82's are better because of cost...
SK
SK
#808
Since none of the electronics are inside, I didn't see the need to take the wing off... Glueing it helps reinforce it too...
SK
#810
Master of Bisaster
Has anybody successfully used a 2S battery with the stock Trojan ESC? If so, how?
I have the ESC in my Depron foamy now, and the 3S I have is too strong for the motor, and so I have to use 2S, but it does not recognize the 2S because of the LVC. In the directions it only states how to initiate the LVC, but not how to get rid of it...
Any ideas?
Thanks in advance,
//Numb
EDIT- I only have 9x 4.5 props now, and with an 8x4 prop the Amp draw is perfect, but on Sundays everything is closed here in Germany and I am dying to maiden the foamy hehe!
Any ideas?
Thanks in advance,
//Numb
#811
I upgraded my T28 with the same motor (Turnigy sk 3536-910 and it works great. I actually used the same prop that came with the original plane (9.5x7.5), but you could easily run an 11x4.5 or 12x6 with the 40A ESC. May need to check the clearance with the 12x6
#813
Master of Bisaster
Just got my SK 35-42 and 60A ESC and 30C 3000Mah batts from HC. Can't wait to get her set up this week. Already got the motor mounted on the original mount (just had to drill a couple extra holes).
EDIT---The original mount was shredded by the SK 35-42 on the first Watts UP test. I then made a new mount out of plywood that you can see in the video. Took me about five minutes with the Dremel.
Here is a video of the WattsUp testing. Was my second time using it and at first I only did one second full throttle, then I did it again (only the result shown in the video) holding it for three seconds.
http://www.youtube.com/watch?v=JcNpQr-CD9k
30C Turnigy battery and 11x7 (TGS Sport) Prop at three seconds full throttle:
491Watts---41.09A
20C Himmelsturmer battery and 11x7 (TGS Sport) Prop
411Watts---35.9A
Looks like it will be fun hehe.
Video of test flight will be posted as well.
//Numb
491Watts---41.09A
411Watts---35.9A
//Numb
#814
Master of Bisaster
So, here is the short test flight with the motor. Short and sweet. Rain unfortunately hindered being able to test it with the 30C 3S battery. I was able to test it later though(no vid though) and it just screams. Way more punch than what you see in the video here.
[media]http://www.youtube.com/watch?v=gb_nJ80GA3g[/media]
Enjoy!
Enjoy!
#815
[media]http://www.youtube.com/watch?v=gb_nJ80GA3g[/media]Enjoy!
GRU
#816
Master of Bisaster
GRU that set up simply rocks. I got another few packs in after that video and the unlimited vertical is just so damn nice. The 30C pack really shines there. My last pack I spent going straight up until I could hardly see it and then just killing the motor and gliding down nice and slow.
Kife edges at less than half-throttle are a hoot as well. Great recommendation!
//Numb
Edit, here is the plane with the 30C battery, big diff...
http://www.youtube.com/watch?v=lHQAAIlf-7Y
GRU I have switched it out for the 35-36C, it has 23.5% more power according to my Watts Up tests...it is noticeably stronger. I have both motors and tested them side by side with exactly the same set up.
//Numb
#817
Its been a year since i started this thread, and im glad to see it still going strong
. Im back once again people, i bare great shame. The Trojan has crashed, today
. I'm not boasting, but i feel i am now a very advanced pilot, with almost 4 years under my belt. But today, it all happened so quickly, wrong stick input sent her flying into the ground. Need a new motormount, cowl, and to glue my wing on again, and to get my white electrical tape and patch her wounds up. Ordered another skeleton for my Spit as well, i hope by the weekend i can get them both skybound. Would love another plane, but im saving for a more powerful motorbike for when im 17.
happy flying
joe
oh yeah forgot to mention anybody got any info on this 3 blade prop ive seen for the trojan and corsair on squadronleader.co.uk
heres link: http://www.squadronleader.co.uk/prod...x_6%29_PKZ1015
might get one it looks sexy >.<
happy flying
joe
#821
Master of Bisaster
Hope that helps!
#822
I have tried this and it works but obviously not the primary control to bank. If you set it up on low rates with minimum control throw on ailerons, you will not have any trouble if you have mastered some other 3 channel plane like AB3 or SC.
Note: AB3 is a great step toward ailerons. In beginner mode it is docile adding in up elevator when turning. In expert mode you can stand it up on edge in a turn.
#823
I've seen some on here that have flown the T-28 with no previous experience and want to know the unknowable; can I do the same?
#824
#825
Jumping from Micro to T-28 is a huge stretch. Issue is not the ailerons, rather the speed of the plane and judging an appropriate flight circuit at your field.
Aileron is no big deal - flies just like a 3 channel but is more responsive. (you don't need to even consider the rudder except on the ground) Moving from AB3 to Swift was easy for me except that the Swift must be flown faster and I kept stalling the Swift (while blaming it on radio and defective servos. Swift flies great but has an unforgiving stall characteristic in sock trim.)
The fact that you say you have only flown a micro 4 channel a little bit and you are overcontrolling the plane suggests your attempt at a T-28 would be a very short flight.
Get a more forgivng 3 channel plane like the SuperCub or AB3 - learn to fly circuits and then move up to a T-28 when you are ready for more speed and aerobatics. (What you save in repairs will more than pay for the SC or AB3)
Clint
Clint
