Edomodels F-4 Phantom, ready to go! - Page 6 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-20-2008, 03:47 AM
  #126
BUCKSHOT
BUCKSHOT's Avatar
Sent an e-mail ...they have parts
BUCKSHOT is offline
Old 08-20-2008, 04:16 PM
  #127
superdude387
flight is therapy
awesome any idea as to the pricing?
superdude387 is offline
Old 08-21-2008, 03:44 AM
  #128
BUCKSHOT
BUCKSHOT's Avatar
E-mail or call william at www.turbofanelectrics.com
BUCKSHOT is offline
Old 09-02-2008, 07:25 PM
  #129
BUCKSHOT
BUCKSHOT's Avatar
Well after a full day of flying saturday,during the 3rd flight cut in & out landed, pulling 33 amps,4th flight found 1 fan blade touching shroud,think I'm gonna replace motor/fan unit/esc ....any ideas?
flying with 3s 2100 15/20/25 c
CK THAT .....FAN NOT TOUCHING
BUCKSHOT is offline
Old 09-04-2008, 01:49 PM
  #130
Joe 1320
Joe 1320's Avatar
Fans:
http://www.horizonhobby.com/Products...ProdID=EFL7007
http://www.bphobbies.com/view.asp?id=B2362524
For motors:
http://www.customcdr.com/cgi-bin/ccp...E:triplemotors
MMC5156 LittleScreamers "JetScreamer" Ducted Fan OUTRUNNER with 21mm Adapter
http://www.hobby-lobby.com/littlescreamers.htm
http://www.donsrc.com/cart/index.php...d&productId=52
I would step up to at least a 50A esc. (I use a 60A) At the moment, I'm using a 5200 kV Custom CDR after swapping out the 4500 LSJS. With all 6 blades it's amp hungry but it's a thrust monster. I'm going to clip 3 blades to drop the draw.
Joe 1320 is offline
Old 09-06-2008, 04:55 PM
  #131
BUCKSHOT
BUCKSHOT's Avatar
Flew today,started sputtering again ,decided to land throttled back on approach to about 1/3 ....it shut off about 10ft up.... Fell like a brick,it is repairable but sure am disappointed in the stock set up
BUCKSHOT is offline
Old 09-06-2008, 04:57 PM
  #132
BUCKSHOT
BUCKSHOT's Avatar
Also hey joe is this set up faster ,more torque ?,,
it needs both
BUCKSHOT is offline
Old 09-07-2008, 03:00 AM
  #133
The Don
Balsa Butcher
The Don's Avatar
I have flown mine on 3S and 4S. First was 3S on the Wicked 4800 motor then 4S on the Wicked 4000 motor. I personally like the 4S version much better but the 3S was nice (about 350 watts), 4S is about 550 watts. I now have custom made EDO rotor plugs for 3mm shafts. They are just like the stock ones but they fit a 3mm shaft so the Wikced motors when ordered with the EDO option will ship that way from now on so installing and removing the EDO rotor will be quite easy, no more press fit rotors.
Don
The Don is offline
Old 09-09-2008, 06:01 AM
  #134
BUCKSHOT
BUCKSHOT's Avatar
so will i still use the stock fan ?
BUCKSHOT is offline
Old 09-10-2008, 02:12 AM
  #135
The Don
Balsa Butcher
The Don's Avatar
I am using the stock fan.
Don
The Don is offline
Old 10-08-2008, 05:35 PM
  #136
BUCKSHOT
BUCKSHOT's Avatar
Still lost on this motor issue:
I want to stay with 3s 2100/stock fan......want to upgrade motor needs more power....stock just says 18l inrunner
help
BUCKSHOT is offline
Old 10-08-2008, 06:23 PM
  #137
Joe 1320
Joe 1320's Avatar
I think you need a Don's Wicked 4800. That would give you the performance you're after on that size pack.
Joe 1320 is offline
Old 10-15-2008, 02:17 PM
  #138
BUCKSHOT
BUCKSHOT's Avatar
Adding a 50amp esc today,motor will be next
not sure if the stock motor will hold up to a 4s either ?
BUCKSHOT is offline
Old 10-15-2008, 07:31 PM
  #139
Joe 1320
Joe 1320's Avatar
It would work great.... right up until about 2/3 throttle and then it would start a pretty wicked smoke show.
Joe 1320 is offline
Old 10-17-2008, 01:43 AM
  #140
BUCKSHOT
BUCKSHOT's Avatar
BUCKSHOT is offline
Old 10-20-2008, 01:24 PM
  #141
BUCKSHOT
BUCKSHOT's Avatar
anyone know the correct size to bolt up,like a bp or other inexpensize motor ?
BUCKSHOT is offline
Old 10-24-2008, 02:50 PM
  #142
BUCKSHOT
BUCKSHOT's Avatar
how would this motor work ?....more or less power & would it fit ?
http://www.nitroplanes.com/el4004brmo.html
BUCKSHOT is offline
Old 10-31-2008, 02:34 PM
  #143
BUCKSHOT
BUCKSHOT's Avatar
I ordered the dons wicked 4800, how much improvement should i expect ?
Still want top stay with 3s2200,
i also installed a 50amp esc
BUCKSHOT is offline
Old 11-05-2008, 10:49 PM
  #144
BUCKSHOT
BUCKSHOT's Avatar
Done...50amp esc,wicked 4800.....test tomorrow or saturday.....sounds faster
BUCKSHOT is offline
Old 11-08-2008, 06:24 AM
  #145
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
I know this one isn't in the same class as the EDO EDF F-4. But I built it in a couple days and it flys like a real jet. And I only have about $20. in it.Plus mine has the real amount of annahedral in the horz. stab anyway Gotta luv the the old war horse
Name:	3D planes 040.jpg
ID:	83055   Click image for larger version
Name:	3D planes 041.jpg
Alpea42 is offline
Old 11-09-2008, 03:08 AM
  #146
BUCKSHOT
BUCKSHOT's Avatar
Alpea42 IT LOOKS COOL TO ME
THE E DO IS A NEW PLANE WITH THE WICKED 4800,MOVES OUT PRETTY GOOD.....NOT UNLIMITED VERTICAL BUT LOTS FASTER THAN STOCK
BUCKSHOT is offline
Old 11-09-2008, 03:12 AM
  #147
Alpea42
Alpea42's Avatar
Here's a link to a vid. of a giant 3 lb. Shumate F-14 I maidened today. It had too much up elevator trim and might be a tad tail heavy but I got it down safe http://www.wattflyer.com/forums/show...3#vid-f51fb3b3
Alpea42 is offline
Old 11-23-2008, 02:12 AM
  #148
BUCKSHOT
BUCKSHOT's Avatar
I'm gonna try the exceed f4 next
smaller,lighter same fan & motor........= faster ?
BUCKSHOT is offline
Old 11-25-2008, 04:44 AM
  #149
Alpea42
Alpea42's Avatar
Cool Buckshot glad it's flying well for you. Flew both my parkjets yesterday http://www.wattflyer.com/forums/atta...9&d=1227488799 http://www.wattflyer.com/forums/atta...5&d=1227488683
Alpea42 is offline
Old 12-05-2008, 01:44 PM
  #150
BUCKSHOT
BUCKSHOT's Avatar
I had a friend give me a kyosho f16.....trying to figure out HOW TO INSTALL SOME LANDING GEAR ?
HOPE SHE HAS ENOUGH POWER
BUCKSHOT is offline
Quick Reply: Edomodels F-4 Phantom, ready to go!
Page generated in 0.10590 seconds with 14 queries
