Question Ice 75 Controller Resistance - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Castle Creations discussion All things Castle
Old 01-30-2011, 03:31 AM
Merritt
Merritt's Avatar
Would like to know the resistance of the Castle Phoenix Ice 75 controller.
Thanks!!
Merritt is offline
Old 01-30-2011, 06:22 AM
Thanks!!
Interesting, CC doesn't publish that. But, the www.motocalc.com lists the Castle Creations Phoenix 75 Amps resistance as 0.0012 ohms, so suspect the ICE line is in the same area.
I've got a CC 80 Amp HV ESC, they wired this thing with #10 wire.
Since the motor windings are usually 5 or 10 times that 0.001 ohms, the actual power loss in the ESC it self would be pretty low in comparison. In fact, a lot of ESC's don't even use heat sinks on the power Fets that control the high currents involved. The ICE lines do have heat sinks, making them less vulnerable to instantaneous failure due to momentary severe current overloads.
Old 01-30-2011, 09:15 PM
Merritt
Merritt's Avatar
Default ICE 75 Resistance
Thanks for the info. I'm using the factor for a Motocalc prediction myself. I spent the better part of one evening searching for the ICE spec. I wondered if the data logging apsect was creating higher than normal resistance for the ICE series, soooooo they left that spec out.
I like my CC, just speculation
Merritt is offline
Old 01-31-2011, 12:28 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
I dont think thats the case. The only logging item that could even conceivably cause a higher resistance would be the current logging - and they use Hall Effect sensors for that, so zero additional resistance in the circuit. All other items are either calculated or based on voltage readings and fluctuations, so no added resistance there.
Also, based on my personal experience with how cool the ICE units run - even at full rated loads -Im guessing the resistances are at least as low if not lower then lower than the equivalent Phoenix series controllers.
You will be in the ball park at least using the P80 resistance. Its likely your connectors have higher resistance anyway
Larry3215 is offline
Old 01-31-2011, 03:40 AM
Merritt
Merritt's Avatar
Thanks for the encouragement on the ICE 75. I'll most likely never be above 50 amps so I expect it to run cool.
Merritt is offline
Old 01-31-2011, 05:05 AM
If you're running the CC ICE with the heat sinks, not the ICE Lite, doubt if that thing will ever be more than slightly warm at 50 Amps. I regularly run my CC Phoenix units right up to their maximum current ratings, and with some air cooling, have never had an issue with temperature rise.
Old 01-31-2011, 05:36 PM
Merritt
Merritt's Avatar
Thats good to know.
Merritt is offline
Batteries & Chargers
12-12-2010 05:50 AM
Quick Reply: Question Ice 75 Controller Resistance
Page generated in 0.06038 seconds with 13 queries
