Forsale Esc for brushed motors - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Motors and Speed Controllers for sale & WTB List your brushless or brushed motors and speed controllers for sale in here
For Sale Esc for brushed motors
Old 09-10-2008, 02:17 AM
lovetofly2
Default Esc for brushed motors
Because I’m going mostly brushless, I have a bunch of ESC for brushed motors that are useless for me now. Some of them are brand new others are a little used with plugs connected but ALL in perfect working condition.. From the picture of each one you can see the type. Remember again, these ARE FOR BRUSHED MOTORS, used with Ni-Cad, Ni-Mimh or LiPo batteries but if used with LiPo need a LipoShield or Lithium Cutoff device. (sold by Dimension Engineering). All comes with instructions. All prices are with shipping. Please, NO PM messages and NO reply in this forum, all the questions directed to: [email protected] All payments ONLY with Postal Money .Order. Thanks for your attention and thanks for looking. ALDO
TEKIN – TSC410S – Brand New. Digital ESC with BEC output 5.7V – Limited
current 20-140A - Voltage 4-10 cells – Variable adjustable torque control
Regenerating battery recharging – High power Mosfet output transistors. Decals
and extra heath sink. - $ 40-
MPI - MX 9170 – Voltage Range 7.2V to 24V (6-20 cells) – Current: 45A continuous
200A instantan. – High frequency switching – Arming switch - $ 25
MPI – MX 9145 – Voltage range 7.2V to 12V (6-10 cells) – Current 50A continuous –
200A instant.- BEC when used with 6-7cells – Built-in brakes – LED indicator
for neutral point and operation status – Main power switch. $ 20
ASTRO FLIGHT (2) ESC – Mod # 217 – Volt. Range 25V – 14 cells – 30A max –
Switching frame rate 50Hz – NO BEC – NO BRAKES – Require 4.8V – No
Adjustments are necessary. - $ 10
GWS – 100 – BEC – Auto cutoff – NO Brake – Current 5A – 5-8 cells $ 8
GWS – 400 – BEC – Auto cutoff – Reset switch – 5-8 cells – 15A current - $ 10
GWS – 600 – BEC – Auto cutoff - Brake – Reset switch – 30A current – 6-10 cells –
High frequency rate at 2.8 KHz - $ 12-
DYMOND – D20 – BEC 5V / 1A – 26A current – Over temperat. Cutoff – NO setup
need – Brake system – On-Off switch – Voltage 5-10 cells - $ 11
WATTAGE – IC 550 – ESC for 400/600 motors - 6-10 cells – 30A current – 6/10 cells – On-Off switch – BEC - Auto cutoff - $ 18
Name:	Tekin ESC mod.2 jpg.jpg
ID:	77660   Click image for larger version
ID:	77661   Click image for larger version
ID:	77662   Click image for larger version
Name:	Astro ESC 2.jpg
ID:	77663   Click image for larger version
ID:	77665   Click image for larger version
ID:	77666   Click image for larger version
ID:	77667   Click image for larger version
lovetofly2 is offline
Old 09-27-2008, 05:52 AM
himeros
I am looking for a brushed lipo safe 20 amp esc. Would you have one of those? Thanks
H.
himeros is offline
jtcarn
09-09-2008 02:56 AM
Q-Hunter
06-09-2008 09:13 PM
JPilkinton
04-10-2008 11:50 AM
swapdaddyxx1
10-07-2006 02:17 PM
Rhondas
06-14-2006 04:02 AM
Quick Reply: For Sale Esc for brushed motors
Page generated in 0.05619 seconds with 25 queries
