How many lipo batteries do you own and how old is your oldest lipo batt? - Page 2 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-30-2008, 03:52 AM
themantoknow
themantoknow's Avatar
I have a dozen or two...The oldest is a Kokam that is 4 years old, it is starting to go flat. I have been really happy with the Commonsenserc products. They are reasonable priced and better quality than most. (I have also used TP packs.
themantoknow is offline
Old 07-18-2008, 06:13 PM
turokforever
update the green lipo in my picture won't hold a charge for more than a few days it is 2 years old and not used to much. and one of my TP . one cell has just gone dead while it was in a stored 11.3V state. i crashed it about 3 months ago and has been used 2 times since and all was fine. so i don't what happened as it has just been in storage. but i do check and top up & balance my lipos every 2 weeks.
turokforever is offline
Old 07-18-2008, 08:34 PM
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
I'm guilty of it too, but I recently read somewhere that we should not "top off" our already-charged LiPos...
Old 07-19-2008, 01:17 PM
turokforever
i mean i keep them at 11.3V but if they drop below that. i will bring them back up to 11.3V. i have tried to top up a lipo but it is a slow process as i only do it a low charge rate so the balancer is taking out almost as much as the charger is putting in.
Old 09-11-2008, 12:23 AM
turokforever
OK we don't care if you have 1 lipo but we want to know how old it is and what you do with it
Old 09-11-2008, 03:27 AM
Lieutenant Loughead
UNCLUB OWNER
Snicker snicker... No you don't.
Old 09-11-2008, 04:02 AM
ministeve2003
Class Clown
ministeve2003's Avatar
I have about 30 packs... about half of them are a year old with 200+ flights on each... a couple have been though mean crashes and been bent back to shape and are flying strong...
Brands
Loongmax, Zippy, Rhino, and 1 thunderpower which bit the dust way too easy...
Sizes...
3cell 2350
3cell 2250
3cell 1500
3cell 1000
3cell 500
4cell 2000
4cell 2300
SK
ministeve2003 is offline
Old 10-01-2008, 06:49 AM
jimweda
Default Batteries...
I started out with Thunder Power 3s-2200's and Flightpower 3s-2170's which are about a year old and still run strong. I still get 12.6 after a full charge and they hold their voltage. Then again, I don't go crazy with my batteries even on my fast 120mph+ birds. I have about 10 Thunder Power 3s-1320's and except for one slight puffing, they are all still going strong as well. My first step into bigger batteries was a used Impulse 4s-2500 that I bought only because I got a good deal on it. I still prefer Thunder Power and Flightpower. In the past 6 months, I bought 3, 4s-3300 and 3, 5s-3300's and am very happy with them. I did try a Lightning Power 4s-2500 but I had one of the cells swell up pretty bad but I also got a free exchange on it. I just recently purchased used, 2, 5s-4100 NeuEnergy's and I'm going to test them out and see how I like them. They have a 30c rating and I want to test them on my Sundowner 50 and/or Kyosho Kelly and/or Kyosho Fockewulf 50 on a Neu 1912/2Y, Hacker A50-14s, Hacker A50-14L Electric Turbine and see how they hold up. Personally, I'm still a big Thunder Power fan and will probably continue to purchse them unless I find a great deal on batteries that hold up as well.
Jim
jimweda is offline
Old 10-02-2008, 07:21 AM
Bill G
Super Contrubutor
Bill G's Avatar
Original TP blue lable 3s-2100, 3s-1320, and 3s-700 still seem to be working well, although the 2 larger packs aren't quite up to their original C spec, which was not that high to begin with. They would run at 5C or higher originally. Probably more like 3-4 now.
Bill G is offline
Old 10-03-2008, 12:57 PM
turokforever
i know that the extreme V2 lipos have a very good C rating but if used to close to there limit the punch soon goes. but if used in less demanding models they will last much longer.
Old 10-07-2008, 11:19 AM
vonveska
vonveska's Avatar
Well, I used to have 4, until one Saturday afternoon
http://www.varms.org.au/index.php/co...4579&g2_page=3 (see the smoke?) so now I have only 3
vonveska is offline
Old 10-08-2008, 09:39 AM
dumpsterjay
It's all in the thumbs
dumpsterjay's Avatar
I have 28 Lipos right now.
3- 2500-3S
8- 2100-3S
4- 1500-3S
5- 1250-3S
5- 910-3S
3- 640-3S
The oldest batterys that I have right now are 2-four year old Kokem 1500's and two Impulse 2100's. I use balancers and check capacity often. I replace them as needed. Some of them go four or five years, and some only go a couple of years. It just depends on how hard and how often I use them.
Jim
dumpsterjay is offline
Old 10-15-2008, 09:01 AM
BEX
BEX's Avatar
I have 10 Lipos , all of them Aplus
3 x 3S 1350 mAh 20C 9 months
2 x 3S 1800 mAh 25C 9 months
2 x 3S 2200 mAh 25C 9 months
2 x 3S 3300 mAh 22C 18 months
1 X 5S 4500 mAh 22C 6 months
I have had no trouble withthem , the 3300 mAh's that i got first has taken about 100 charges each and I have yet to find any problem with them.
I have abused one of my 1350 mAh lipos in a model once pulling its max rated A for the full flight. It was hot and a bit soft when i removed it from the model and for the next 2 days I treated it as if it was a snake. It was fine once it cooled and I still fly it regularly with it taking a full charge.
BEX is offline
Old 10-15-2008, 03:35 PM
turokforever
so it got hot but never puffed up
Old 10-15-2008, 03:57 PM
BEX
BEX's Avatar
Yip , hot and a bit soft , but not puffed.
BEX is offline
Old 10-20-2008, 08:01 PM
turokforever
i was given a faulty 6cell 11.1V lipo it uses 2 packs of 3. i was going to try and use just one set of cells. yes im tight. so i cut the plastic off the pack and i found out that the MAH is a lot lower than stated. and this is not some cheep pack but a top of the range. if i had paid for this pack i would not be very happy.
Old 10-20-2008, 08:39 PM
ministeve2003
Class Clown
that would be a 3s2p pack, and each would be half the stated capacity... and there would be nothing wrong with it...
SK
Old 10-21-2008, 02:24 PM
turokforever
each pack is rated way under half of the total on the main sticker
Old 10-21-2008, 06:18 PM
Bill G
Super Contrubutor
Bill G's Avatar
My GenI TP 3s-730 (4 yrs old) finally kicked off a few days back. Flew a month or so ago on it, now good for 30 second flights.
Bill G is offline
Old 10-21-2008, 06:40 PM
ministeve2003
Class Clown
The only pack I got that I was extreemly dissapointed with... was a commonsense pack, and I've heard the same from several people, the ones around here total garbage... they aren't even comparible to Nimh packs...LOL
I finally had an old longmax pack die on me this weekend... I decided to make it work at peak for a change.... had about 200+ flights on it pulling max C ratings for its whole lifespan... that was a good $20 investment...LOL
SK
Old 11-12-2008, 03:12 PM
turokforever
well what a summer we had in the UK. my 40 odd lipos had very little use. so i will have to see how they last the winter. i will be keeping a eye on them just in case any drop voltage or something. im still on the look out for a old AMMO box as i keep them indoors.
Old 11-12-2008, 03:26 PM
BEX
BEX's Avatar
40 odd? wow
You can always send them over to me for storage through your winter, I will take tender loving care of them , cycling them every now and then to make sure they are happy .
BEX is offline
Old 11-12-2008, 03:36 PM
turokforever
if i send them i will have to tag along lol
Old 11-12-2008, 03:42 PM
BEX
BEX's Avatar
AS weak as our currency is at the moment you could have an inexpesive warm flying holiday here.
BEX is offline
Old 11-19-2008, 12:36 PM
turokforever
just added 5 2cell lipos to my collection
Quick Reply: How many lipo batteries do you own and how old is your oldest lipo batt?
Page generated in 0.10253 seconds with 13 queries
