Anderson Power Poles - Page 4 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 09-26-2010, 01:57 AM
  #76
Originally Posted by Liquidity View Post
Anyone here using Anderson Power Poles for connectors between batteries and ESCs?
I have decided to slowly make the switch. I have a few lipos that use some heavy duty gauge wire. It is a pain to solder them to Deans.
My buddy just switched over and I have to say I am an instant fan of them.
Check out www.mouser.com, per my thread below:
http://www.wattflyer.com/forums/showthread.php?t=46890
Amp 45 Amp Pins
http://www.mouser.com/ProductDetail/Tyco-Electronics/1445962-2/?qs=1YZG3VvBVY87N04jT5t1Uw%3d%3d
Amp Shells (Also have 1445957-2, -3, -4, -5 for different colors)
http://www.mouser.com./ProductDetail/Tyco-Electronics/1445957-1/?qs=1YZG3VvBVY9fViIg5c49hw%3d%3d
Amp sells these connectors in "Series 15/30/45" that is very similar or the same as the APP connectors. The Amp Connector pin (Only) number for the 45 Amp unit is #1445962-2. This is rated for #10, 12 and 14 wire sizes. Mating with this is the #1445957-1, -2, -3, -4, and -5 plastic shell (for different colors). The Mouser photo shows the 15 Amp pin, but if you go through the Mouser documents for the 45 Amp pin, they show the familiar "Clam Shell" crimp type of connector.
Looks like they sell one set of 45 Amp Anderson Power Pole connectors for about 20 cents for each 45 ampere pin, and 44 cents for each shell. I purchased 100 pins several years ago, and still have some left. (Got the shells from work, they were using well over 3000 per month in power connectors we used in $25,000 high voltage circuit breakers.)
Mouser sells to anyone with a credit card. I've made many orders (Both at work before retiring and at home) to them over the past decades, and have been happy with their service.
Old 09-26-2010, 02:04 AM
  #77
simibill
General Factotum
simibill's Avatar
I've used powerpole's for years on all my airplanes. I buy from http://www.powerwerx.com/
simibill is offline
Old 09-26-2010, 02:28 AM
  #78
ministeve2003
Class Clown
ministeve2003's Avatar
I've been a fan of those connectors for quite awhile... but I've been swiching out my stuff for the new XT60 connectors due to price... the xt60's seem good enough for my likeing... and are fine to solder...
SK
ministeve2003 is offline
Reformed Nitroaddict
07-29-2017 09:15 PM
Warden
15
01-27-2010 08:39 PM
cyclops2
Brushless Motor Construction
14
05-14-2008 03:36 AM
simibill
36
03-31-2008 07:28 AM
FlyWheel
Support & Suggestions
13
01-15-2008 03:50 AM
Quick Reply: Anderson Power Poles
Page generated in 0.08872 seconds with 12 queries
