One or Two Batteries - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 12-05-2008, 07:05 PM
clt12981
clt12981's Avatar
Default One or Two Batteries
Need advice. Building a P-38 twin engine plane. 52" wing span, dual 480 motors, dual 45 amp esc.
My question is, can I run one single battery or do I need to run two batteries one for each motor?
Thanks Chuck
clt12981 is offline
Old 12-05-2008, 07:11 PM
Thanks Chuck
You can run one or two, either way will be fine. I run one 3s lipo in my 4 motor C-130 and it has been working well for almost three years now.
I run 2 batts in my 2 motor Eflite Super Airliner.
What ever will work out best as far as balance and weight goes should be the way to go.
Good luck!
Old 12-05-2008, 07:12 PM
Bub Steve
Bub Steve's Avatar
Thanks Chuck
I use two for balance but if your put'in it in the fuse one's fine, your bub, steve
Name:	petty an red 760.jpg
ID:	85740   Click image for larger version
Name:	petty an red 357.jpg
ID:	85741   Click image for larger version
Name:	petty an red 8777.jpg
ID:	85742   Click image for larger version
Name:	petty an red 676.jpg
ID:	85743   Click image for larger version
Name:	petty an red 592.jpg
Name:	petty an red 769.jpg
Bub Steve is offline
Old 12-05-2008, 08:02 PM
Old Fart
Lost at LAX
Old Fart's Avatar
I run a single battery on my GWS P-38, F-14 and two batteries on my Sonic Liner. The Sonic's system parallels the batteries.
Old Fart is offline
Old 12-05-2008, 09:18 PM
Mayday!Mayday!
Mayday!Mayday!'s Avatar
This is usally a matter of balance as stated above, however you may want to consider 1 battery to run the setup. If using 2, you could have an issue with one hitting LVC before the other, or 1 battery holding voltage better than the other causing 1 motor to use slighty more mah faster.
I would if using 2 batteries, make sure the motors are the same, batteries are the same and of same age and cycles just to keep things as close as possible.
Also, when setting up a dual motor setup, remember the rotation of the props are different. The motor on the right wing should rotate clockwise if looking from the front of the plane, and the left wing counter-clock.
Either way, one or 2 batteries will work. It's your call.
This artical may help.
http://www.castlecreations.com/media...03-Mar2006.pdf
Mayday!Mayday! is offline
Old 12-05-2008, 11:21 PM
Old Fart
Lost at LAX
Old Fart's Avatar
One of the reasons I like to parallel the batteries - it pretty much eliminates the possibility of one motor cutting out prematurely (unless you go really crazy and drop your LVC setting)
Counter-rotating the props is nice - I did that on all three planes. Really helped with the adverse torque rotation on takeoff. Prop selection isn't great (really wish APC would offer the 6x5.5 in RR). Oh, and if you do run one RR prop - it will ALWAYS be the one to break in a bad landing
Old Fart is offline
Old 12-05-2008, 11:27 PM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
I ran two 3S 2150 15C packs in parallel on my 52" P-38. I disconeccted the red wire on one of the ESCs so I only had one BEC working. The only reason I used two packs is because that was the only size I had and didn't want to buy any 4200 mAh packs. Either way is fine.
Grasshopper is offline
Old 12-06-2008, 12:22 AM
clt12981
clt12981's Avatar
Thanks all !!!!!!!!
Chuck
clt12981 is offline
Stan-the-Man
01-19-2008 11:07 PM
tomme
Batteries & Chargers
05-09-2007 03:17 AM
Aerial Photography
10
09-10-2006 05:04 AM
Twmaster
12
07-11-2006 10:55 PM
tjfarrar
01-30-2006 09:14 AM
Quick Reply: One or Two Batteries
Page generated in 0.06715 seconds with 20 queries
