TrueRC Batteries balance plugs - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 12-31-2008, 09:18 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
Default TrueRC Batteries balance plugs
I bought a couple of batts from TrueRC awhile back but never used them. I went to put them on the charger and I just realized the balance plug is a 5 pole instead of a 4 pole for both 3S packs. I am wondering if I should swap the plugs for the correct 4 pole plug or is there some sort of reasoning behind this?
For the record these batts are:
3S 2100mAh 15c and
Tx pack 3S 2500mAh 8hr discharge... no C rating.
Any comments would be welcome as I am at a loss as to why they are wired like this...
xuzme720 is offline
Old 12-31-2008, 10:27 AM
Twmaster
Registered User
Twmaster's Avatar
Gary,
Without seeing the other side of that plug I'd say it looks like Polyquest/Hyperion type tap. Adapters aren't too hard to get.
EDIT: I just checked the list I have for adapters. True RC uses the same plug as Hyperion and PolyQuest (and others)
Twmaster is offline
Old 12-31-2008, 04:57 PM
xuzme720
c'mere Monkey
xuzme720's Avatar
But, any idea why these have this plug? It's a 3 cell pack with a 4 cell plug...
If I plug them in like this, the balancer would think I have 2 dead cells, won't it?
xuzme720 is offline
Old 12-31-2008, 05:03 PM
gfdengine204
gfdengine204's Avatar
Not if you use it with the proper adapter. It will work just like any others.
Just an example of how these things are not standardized.
gfdengine204 is offline
Old 12-31-2008, 05:07 PM
xuzme720
c'mere Monkey
xuzme720's Avatar
I see. [sigh] I really need to pay more attention...
off to buy more stuff, I guess!
xuzme720 is offline
Old 12-31-2008, 05:12 PM
gfdengine204
Yeah, the first time I bought batteries with PQ taps, I didn't know it at the point of purchase. So I had to order adpaters, and pay shipping AGAIN.
Old 12-31-2008, 05:59 PM
xuzme720
c'mere Monkey
xuzme720's Avatar
I think I'll just change the taps out. I really don't need another cord to keep track of! lol
xuzme720 is offline
Old 12-31-2008, 06:07 PM
gfdengine204
Not a bad idea.
Old 01-01-2009, 01:09 AM
rwsrc2
I have the polyquest batteries and changed them to the align connectors by moving the single black wire over to the other three wires and cut down the plug and shear off the alignment tab. Worked great for me.
rwsrc2 is offline
Old 01-01-2009, 01:15 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
I actually thought of doing that, too, but now I have some taps ordered. I'll probably just wait
xuzme720 is offline
Old 01-01-2009, 03:31 AM
dfemmert
dfemmert
X
I have a Hyperion charger and balancer. Only my E-Tec and Hyperion packs have the polyquest connector so I made some adaptors using parts found here...
http://www.bphobbies.com/view.asp?id=B3805280
They now have the adaptor already made for 3S packs...
http://www.bphobbies.com/view.asp?id...C1516872&img=l
You should have one, you'll need it if you get these lipos;
Dualsky Xpower
Rhino
E-Flite
E-Sky
Tenergy
Outrage
HXT
Zippy
Fullymax
and several others.
David
ID:	88660   Click image for larger version
dfemmert is offline
Old 01-01-2009, 04:23 AM
MYHELIGUY
Global Mod.-bladecprepair
MYHELIGUY's Avatar
Works for me. just don't touch any of the wires together,lipos are very sensitive,they will catch fire. but i had no problems switching that wire and cutting the end of plug.
MYHELIGUY is offline
Old 01-01-2009, 04:40 AM
Twmaster
Registered User
Twmaster's Avatar
It's about the profits man! They couldn't possibly have you using somebody else's gear now can they?
Originally Posted by dfemmert View Post
X
I have the EOS 1210i with two LBA10net+ balancers networked together. Magnificent charger.
What I did after I made my first set of adapters to use my E-Flite and Vampower batts with the charger was to buy one each of these adapter boards (click brand to see board) for PolyQ/Hyperion, TP and E-Flite et.al.
Also there's the breakdown of what is compatible with what on each of those pages.
Twmaster is offline
Old 01-01-2009, 09:01 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
Hey no worries there! I work in the main switch Houston, for AT&T, installing -48v equipment. Long story short, I don't short anything, my job depends on it!
xuzme720 is offline
Old 01-01-2009, 09:06 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
Thanks, man! As it turns out, when I ordered my Taps, I actually ordered the adaptor for the hyperion to eflight without even realizing it.:o The taps I needed were out of stock, the adaptors were close to the same price and I just planned on pulling and swapping the contacts...
I love it when I screw up like that!
xuzme720 is offline
Old 01-01-2009, 05:33 PM
Twmaster
Registered User
Twmaster's Avatar
Pure blind luck!
Twmaster is offline
Old 01-01-2009, 06:58 PM
xuzme720
c'mere Monkey
xuzme720's Avatar
Even a stopped clock is right twice a day! It was bound to happen eventually!! lol
xuzme720 is offline
hillbille
11
01-24-2009 02:43 PM
Lancifer
08-13-2008 02:26 AM
frvrngn
03-13-2007 11:25 PM
joeycoates
8
12-22-2006 04:44 AM
frvrngn
11
07-29-2006 05:12 AM
Quick Reply: TrueRC Batteries balance plugs
Page generated in 0.13563 seconds with 16 queries
