Lipos - Voltage sag under load??? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-03-2009, 03:27 PM
Buck Rogers
Default Lipos - Voltage sag under load???
How much should the voltage go down under load with a Lipo battery. I have some Dualsky Lipos that seem to sag a lot under load even though they only have about 20 - 30 flights on them.
They seem to drop about 0.5 V with a 3 amp load and over 2V with a 20 A load. Is this right? My other Loongmax Lipos don't seem to drop nearly as much.
Buck Rogers is offline
Old 01-03-2009, 04:02 PM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Well shucks. I thought the .5V drop is normal for batteries under load, but I can't find a chart to prove that.
Frank
Murocflyer is offline
Old 01-03-2009, 04:35 PM
slipstick
Can't say without knowing what capacity/voltage batteries.
E.g. if they were 4S 1000mAh 15C batteries and they only sagged 2V at 20A you'd be doing really well. OTOH if they are 2S 4000mAh 25C then they're terrible.
slipstick is offline
Old 01-03-2009, 05:39 PM
Buck Rogers
They are 1800 mah rated at 25C and up to 50C burst (allegedly). The problem is that with such a voltage sag I'm getting dangerously close to the LVC at WOT with over 50% capacity remaining in the battery.
Considering I'm only running these batteries at less than 1/2 their rated capacity I thought the size of this drop seems excessive.
Old 01-03-2009, 05:48 PM
Rodneh
Have you checked your connectors? Make sure that the drop is at the batteries and not due to some thing causing an increase in the external impedance between the load and the battery.
Rodneh is offline
Old 01-03-2009, 06:51 PM
everydayflyer
Southern Pride
everydayflyer's Avatar
http://www.wattflyer.com/forums/showthread.php?t=41023
Charles
everydayflyer is offline
Old 01-03-2009, 06:56 PM
jooNorway
All my setups draw appr 10-14C. Then I usually read 3,5 - 3,6 V/Cell at load.
jooNorway is offline
diverdon
20
12-08-2008 04:04 PM
bhatch21
16
09-06-2008 05:19 PM
onesubdrvr
10-17-2007 05:22 PM
Lysander
03-02-2007 02:51 PM
Flyboy Dave
Humor
08-29-2005 04:15 PM
Quick Reply: Lipos - Voltage sag under load???
Page generated in 0.09336 seconds with 13 queries
