What glider/sailplanes are you flying? - Page 3 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-22-2005, 04:45 AM
Jason T
Electron Liberator
Jason T's Avatar
Richard,
Welcome to Wattflyer!
Jason T is offline
Old 11-22-2005, 11:50 AM
ragbag
Mine are:
Alpha 180, Polk Hobby, 72"
Mini Phoenix, Cremark
Skimmer 400, bought this one at a meet.
Ascent, just got a receiver for it last night, not test flown yet.
By George
ragbag is offline
Old 11-23-2005, 08:58 AM
brewer
Aspire EP bone stock other than a oversize prop. This one came with a Quattro 4 channel tx that i like. I purchased this plane saturday eve. Sunday morning i was launching. What a great fealing, what a great plane. Have been leaving the brewery early every day so i can fly before it gets dark. I think i'm hooked.
brewer
brewer is offline
Old 11-23-2005, 04:09 PM
sierra-gold
brewer
Hangar 9 Aspire is a great 2M glider. I converted one to EP back when the ARF glider version was still offered. Still one of my favorite planes.
I run a Hacker B20 L18 with 4:1 Maxon GB, 3S 2100 lipo, and a 12x6 folder. Climbs out at 60-70 and the AUW is 38oz.
Brewer - are you the pilot I sold the Estarter to on your move back to Utah?
If you don't have a gear box on the Aspire, add one and get a larger prop. You will pleased with the added climb out power.
SG
sierra-gold is offline
Old 11-25-2005, 07:37 AM
brewer
Sierra-gold I am not the person that moved to utah. I am close to Coloma. Sometimes i fly out on highway 49 acrost from Venezzios vinyard. thanks for the info on adding a gear box. If you find yourself in Coloma, stop by Gold Hill Vinyard & Brewery. I'll buy ya one
brewer
brewer is offline
Old 12-01-2005, 02:32 PM
Geoff_Gino
Geoff Ogden
Geoff_Gino's Avatar
Hi
Here's my entry into the world of thermals.
Thunder Tiger Soaring Star.
2 metre wings
4 channels (airelons - on seperate channels for spoilers when needed)
40 amp ESC from Cape Sailplanes
540 brushed motor - direct drive
2S1P 2,2 amp LiPo
Was very impressed with one of our members who stayed up for 67 minutes one Sunday.
Should be ready for maiden this week-end
Geoff
Geoff_Gino is offline
Old 12-01-2005, 10:10 PM
EnterTheHaggis
EnterTheHaggis
Let me know how it flys, My longest flight on mine is 30 minutes, although I had to leave several thermals because it was getting pretty far out there.
Hint: keep it fast near the ground on turbulent days.
EnterTheHaggis is offline
Old 12-02-2005, 06:38 AM
Geoff_Gino
Geoff Ogden
Geoff_Gino's Avatar
Will do and thanks for the hint.
Did all the final work last night and found I had to add a flight battery as the CG was way off. Did the trick and with the final charge and check, I am ready for the maiden tomorrow.
Geoff
Old 12-03-2005, 03:10 AM
ragbag
Originally Posted by ragbag View Post
Mine are:
By George
Add a Cermark Easy Electro 72. A friend strained his through a pine tree and I ended up with the fuselage.
Cermark discontinued the Electro, but still had a wing in stock. Copied the tail feathers off of the Alpa 180 and put a new prop on it. Working on the radio gear now. Took a little break, don't think I'll have it ready for the AM though.
Might wait for the Berg 4L to come in, save the 555 for something else, maybe another Kadet.
By George
ragbag is offline
Old 12-03-2005, 10:01 PM
EnterTheHaggis
EnterTheHaggis
Good luck, I use a 6 cell 2000mah nimh, I was wondering how the weight change for the battery would effect the cg. Let us know how it flew.
Old 12-05-2005, 07:01 AM
Geoff_Gino
Geoff Ogden
Geoff_Gino's Avatar
Hi All
The weight change was in my favour and balanced the plane out nicely.
Maiden on Saturday went well and my instructor stayed up with it for 12 minutes. No thermals early in the morning and left it for later.
Second flight was 13 minutes and all I can say is it flies great, still no thermals, but my other club has better potential and we'll see what happens there.
Geoff
Old 12-06-2005, 05:10 AM
brewer
Default Thank you for sharerd knowlage.
SG
sierra gold many thanks for the advice on adding a gear box to my aspire. i have done so. used a park zone p51 mustang motor and gearbox because i had one. had to add little weight to make up the differance. figured this out at my first test flight. also purchased a better nim hi battery. local hobby shop did not have a lipo. also added larger prop. you are right, i am extreemly pleased with climb power plus,flight time under power has increased ten fold.. thank you, thank you, thank you.
with respect brewer
brewer is offline
Old 12-06-2005, 11:02 PM
  #63
Silverhawk
It's always interesting to see what others are flying.
My "flyers" are":
Castor 2.5 - F10LMR, 7 or 10 cell CP1700's, 14x9.5 or 13x7. Just finished.
XL3200 - 1409/2Y, 3.7:1, 14 CP1700's, 16x10
Sophisticated Lady V-tail, S400, 3.8:1, 8 to 10 cells (600AE or 1700AU), 11x8. This one will be getting a BL soon.
SOBOX Storm - 1409/2Y, 3.7:1, 10 - 2000's, 13x7
The Lady is my favorite to just go out and "fluff around" with. On a nice day she gets a 2 minute motor run climb and then I can just about put down the radio and watch for at least 15 minutes.
I'll not get into the in progress bunch. Like the AVA-E fuse and the Aquila wings.
Silverhawk is offline
Old 12-07-2005, 12:49 AM
  #64
qban_flyer
Guest
Posts: n/a
Lightbulb
All time favorite of mine is my ancient Astro-Flight "Challenger". Still being flown with its original geared Astro 05 FAI on seven cell SANYO 1700 SCRC packs, spinning a 12X6 folder. ESC is an Astro Flight, servos are Hitec HS-101 and RX is a trusty, old FMA Fortress. Heavy? By today's standards, yes, but it still flies superbly nice when one considers it doesn't have ailerons. It does have flaps though.
Also have an Omega 1.8 powered by a direct drive long can Speed 400 motor spinning a 6X3 folder prop. A four channel affair that soars with the best.
Ground guidance is provided by a Futaba 8 "Super" TX on both.
ID:	4404   Click image for larger version
Last edited by qban_flyer; 12-08-2005 at 01:10 PM. Reason: Adding photos of the Omega 1.8
Old 12-07-2005, 08:43 AM
  #65
Strati
Default What I am Flying
Hi All
I have been flying a Lee Falcon for some 12 months and have now bought and assembled a Multiplex Easy Glider Electric, looks great and am looking forward to flying it when I get home. I live in Queensland OZ and am currently in Perth Oz working.
I will let you know how I get on.
Strati is offline
Old 12-08-2005, 09:49 AM
  #66
Strati
Your sailplane looks great and the setup is a good one, mind if i borrow some of the setup as I have ordered my Omega 1.8 today.
Kind Regards
John.
Strati is offline
Old 12-08-2005, 01:13 PM
  #67
qban_flyer
Guest
Posts: n/a
Nice looking sailplane Geoff. If it flies as good as it looks, you have a winner there.
Old 12-08-2005, 01:38 PM
  #68
Geoff_Gino
Geoff Ogden
Geoff_Gino's Avatar
Hi Qban
Thanks, only problem at the moment is, I can't get it into the air.
You've read the post about our Hobby shops and my comments.
(Now what can be said for a LHS that has a plane on it's shelf without the necessary parts needed to complete the project, and woe is me with a broken folding prop for the Soaring Star and a 60" Hanger 9 Corsair that I can't find a 15"x8 3 blade prop for. Proper hanger queen it has become.)
Geoff
Old 12-08-2005, 06:35 PM
  #69
qban_flyer
Guest
Posts: n/a
Originally Posted by Geoff_Gino View Post
Hi Qban
Geoff
YUP!
Really a shame to have a product on display for sale and not to have the supporting equipment for said merchandise. Too bad, but it is the norm with some hobby shops rather than being the exception.
Take care
Old 12-09-2005, 06:49 AM
  #70
TeslaWinger
OK, I am impressed! Here's my humble harem of lovely thermal hounds
Newest is the 100 inch span Queen Bee- see my post in Deltas- undergoing a Phasor15/4 nosejob- until I got on here tonight, that is... Nicknamed GLIDEZILLA!
A converted 10 foot Bird of Time with a Marathon outrunner and an 8 cell Zagi highrate NIMH pack. Elegant!
An Aspire 2 meter converted to electric with LIGHTNESS in mind- until I got annoyed with the S400 w redrive minimal climbrate. An MP Jet Speed 600 class redrive brushless will soon improve the departure angle of this graceful thermal angel.
A V-BAT converted to a rocket plane VTO! Whoa! A wee bit of hangar rash.. oops.. has it on the back burner at the mo...
A Candy with a towhook added for high-start ooomph.
and last... but definitely least...
A mere fond memory of my recently departed Ascent- eaten by a vulture laden Godzilla Thermal- But hey! Whatta way to GO! Straight up till it disapeared in a BUZZARD BOOMER! A tear and a grin all at once... Gonna miss that lil bird... but what a last flight!!! Sure felt weird with a TX in my hands and nothing left to steer in sight... :O
TeslaWinger is offline
Old 12-09-2005, 03:21 PM
  #71
qban_flyer
Guest
Posts: n/a
Lightbulb
I feel your pain my friend.
I lost a single channel Ace High glider to one of them voracious thermals back in 1970. At first I was thrilled to have been able to manage to join in with the buzzards in the free climbing adventure of the thermal after the little .049 Cox engine had quit running.
After about ten minutes I realized the thing was climbing too fast for my taste. No amount of left or right rudder would get it out of that thermal, and away she went.
Devastated? Sure I was, but learned my lesson well. Stay away from sailplane eating thermals unless equipped with spoilers and or flaperons.
Old 12-10-2005, 03:52 AM
  #72
gliderman
Gliderman
Cool Mystery Glider!
I'm attaching a thumbnail of my latest "Mystery glider that was given to me, no Rx, but all servoes! Ailerons, Flaps and large "V" tail! High-start
only
gliderman is offline
Old 12-10-2005, 05:39 AM
  #73
Jason T
Electron Liberator
Jason T's Avatar
Looks nice! Unfortunately, I do not know which one that is.
Jason T is offline
Old 12-10-2005, 06:31 AM
  #74
kepople
Pure sail planes at the moment, I have a Sky sergio. I also have a Bonito, Mini Nyx. I fly 2 DLG gliders, Kennedy Composites Blaster, and Wright Brothers Gambler +.
I am working on an AVA E and an Elegant 700 for next season.
Kirby
ID:	4521   Click image for larger version
ID:	4522   Click image for larger version
File Type: bmp
kepople is offline
Old 12-10-2005, 09:45 AM
  #75
tim hooper
Single-task man
tim hooper's Avatar
The Omega range looks to be the same as the Highlight range over here in the UK.
I've been flying my Highlight Unlimited 1.8 poly for a few years now, and it really is a superb performer.
It started life with a geared S400 motor and 7 cells, but now it sports a direct-drive Mega 1615/5, 9x5 prop and 8xGP1100 NiMHs.
The biggest mod was to ditch that awful foam tail and substitute a home-made item from balsa. The V-tail is removable via single screw, and folds flat for storage as the halves of the tail are joined with a hinge. Not only that, but both servos are inset into the tail surfaces themselves which gets rid of those horrible snakes and gives more room in the nose for the powertrain.
tim
ID:	4525   Click image for larger version
ID:	4526   Click image for larger version
ID:	4527   Click image for larger version
tim hooper is offline
Quick Reply: What glider/sailplanes are you flying?
Page generated in 0.10352 seconds with 21 queries
