What glider/sailplanes are you flying? - Page 5 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 03-24-2006, 02:41 AM
  #101
Epoxycup
Epoxycup's Avatar
EDF
I thought of one other thing, on my Ascent the stock prop was junk. I changed to the black Graupner 6X3 Cam and it was like a new supercharged motor . If you have not tried that you will at least find it is way more efficent.
Looke and finding a scale glider to build from plans is going to be tough. Builders these days are a dying breed, something to do with immediate gratification I guess
Epoxycup is offline
Old 03-24-2006, 02:55 AM
  #102
edffanatic
Crash Caley
edffanatic's Avatar
Epoxy, I actually had no folding props. so I used a APC 6x4 and it worked fairly well, for about a year. A few weeks ago the stock motor that came with it finally gave up the ghost. I guess with close to 40 flights and running higher amps, it was bound to happen. I'm now running a HET Typhoon 6/20 brushless and Tsunami-10 ESC with same prop and is drawing about 7amps at max throttle. Now if I can only get it to fly again. I tried today and it wouldn't trim out. May be the stronger motor. Put a little more right and down thrust and rechecked the controls. Will try again tomorrow. Maybe have someone trim it for me as I'm absolutely terrible at doing so. But from what I can see the present setup will fly with about the same authority as the stock setup I had
edffanatic is offline
Old 03-24-2006, 07:01 AM
  #103
panzerd18
panzerd18's Avatar
I'm going to use a Graupner 8.5x4 Cam folder on my speed 540 motor.
panzerd18 is offline
Old 03-29-2006, 08:14 AM
  #104
oracle_9
Hi,
Just decided to post my 2 meter electric sailplane too.
Its a Windex 1200C scratch build from plans. It was designed by Nick Ziroli and the plans are from Model Airplane News.
Its a balsa constructions. The fuse is planked. The power system is a small AXI motor direct drive 6x3.5 folder prop. and 3 cell lipos. Whole thing weighs 21oz. Its my first electric power glider, and I like it. The climb rate is good too, about 30-40 degree.
Just to add, yes, the motor is indeed on the fin.
oracle_9 is offline
Old 04-01-2006, 01:47 PM
  #105
Jason T
Electron Liberator
Jason T's Avatar
I like where the motor is mounted. This is a really cool design IMO.
Jason T is offline
Old 04-01-2006, 03:27 PM
  #106
oracle_9
Thanks. Also the good thing about it, if the plane crashes, the last thing to go is the brushless motor.
oracle_9 is offline
Old 05-05-2006, 01:13 PM
  #107
flyranger
I Crash Things!!
flyranger's Avatar
My scratchbuilt from 1985 plans by Bob Boucher, the Astro Challenger 70. AUW including a 2100ma 3s1p Lipo is 23oz. WS is 70 in with area of 630 in sq giving a wing loading of about 6oz per ft sq. Two eflite S-75 servos and a FMA Direct dual conversion receiver provide the controls. Dragged aloft by a Eflite Park 400 outrunner, 10x7 eflite prop w/ prop saver (can't afford the folder yet), and Castle Creations-25 ESC. Fuse is covered in white super monokote, wings and tail feathers are transparent red and yellow monokote. First flight was yesterday. Needed lots of down trim, will change incidence angle of wing trailing edge today. The fuse is roomy (about 2in wide) and will take anything you care to install. The Park 400 is lighter than the Astroflight 05 it was designed for, so extended the nose moment by two inches to help with the balance. No additional weight needed. The elliptical wingtips were a new building experience for me, but made no changes except substituting bals for the hardwood spars. Wing trailing edge substituted 3/16in stock for 1/8in. Fuse sides are hard 1/16in balsa instead of 3/16in balsa. Flies like a Ohio Turkey Buzzard!!:p
ID:	11013   Click image for larger version
ID:	11014   Click image for larger version
ID:	11015   Click image for larger version
Name:	decorated wing1.jpg
ID:	11016   Click image for larger version
Name:	decorated wing2.jpg
ID:	11018   Click image for larger version
ID:	11019   Click image for larger version
flyranger is offline
Old 05-18-2006, 04:25 AM
  #108
gtxkid
Spectra with a 78 inch wing.
I put a FMA Co-Pilot on it
Greg
gtxkid is offline
Old 05-23-2006, 07:15 AM
  #109
pelon_mx
somebody did put a motor on the spirit 100??, ho does it works?
pelon_mx is offline
Old 05-24-2006, 10:45 PM
  #110
Red Scholefield
Batteries/Chargers
Red Scholefield's Avatar
I'm still flying an old Gruapner Electro Jr, must be nearly 20 years old by now. I've worn out 3 or 4 speed 600s in it and it just keeps on going and going and going. The Vengance (is going on 15 years), a vintage powered sail plane design kitted by Ted Davey, forrunner to the Slick. The baby in the bunch, only two, is the Mini Phoenix, a great little sailplane that will hold its own with the bigger ones, unfortunately it suffers some real quality problems in the fuselage molding - egg shell thin and just as brittle. Now discontinued.
Red Scholefield is offline
Old 05-25-2006, 02:36 PM
  #111
Jeremy Z
Wind Warrior
Jeremy Z's Avatar
Maybe you should reward its long-standing good service with brushless power the next time a speed 600 runs low on brushes?
Jeremy Z is offline
Old 05-25-2006, 03:52 PM
  #112
BillM
Red S.
It's nice to see there are others that feel some planes don't need brushless motors to be enjoyed. Although the larger and more performance oriented sailplanes in my hanger are brushless equipt--my more sedate models are fitted with Cobalt and good old Graupner can motors.
There are times when I prefer to actually see my planes in the air rather than a Monokoted blur as they fly past.
BM
BillM is offline
Old 05-25-2006, 06:58 PM
  #113
Brushless does NOT mean high power. Brushless mean 50% better utilization of the battery. Smoother operation. Longer lasting motor.
You can put a brushelss in that is no more powerful than the speed 600 can motor. YOu will just get 50% longer battery runs or you can go down in battery size, giving you a lighter plane for lighter wing loading and better thermaling.
Oh yes, and a motor that is not likely to ever wear out. That too!
Brushless is not just for hop ups!
AEAJR is offline
Old 05-25-2006, 08:40 PM
  #114
Franny
Stupid Gravity!
Franny's Avatar
Default Bird of Time
Hi All,
I just finished a Bird Of Time conversion to electric with an AXI2820 in the nose. I hope to maiden it soon. We've had a bit of wind.
Franny
ID:	12075   Click image for larger version
ID:	12076   Click image for larger version
Franny is offline
Old 05-25-2006, 10:38 PM
  #115
Red Scholefield
Batteries/Chargers
The Bird of Time is one classic glider, beautiful lines and you appear to have done it justice.
Old 05-26-2006, 07:43 AM
  #116
Franny
Stupid Gravity!
Franny's Avatar
Awww... Thanks! I'll let you know how it flys. Should be schweet! I have a little build/modify thread here: http://www.wattflyer.com/forums/showthread.php?t=3234
Franny
Franny is offline
Old 05-28-2006, 05:18 AM
  #117
Big Oakden
Life is flying a Pitts
Big Oakden's Avatar
Well all, I have just about finished my Discus 4m, converted to Electric.
I have a thread here on Wattflyer, and am part of another on RCU.
both are listed as 157" Sailplane.
I will know if this bird leaps out of my hand in two weeks. I should not have trouble getting her airborne at just over half throttle. AUW will be about 9-10lbs. When I get her done this week, I will weigh her for the final time. Only thing left to do is mount the last spoiler servo, the coverplates, switch, and ESC.
Am also trying to figure out how and where I will put cooling vents for the motor, ESC and the batteries.
Big Oakden is offline
Old 05-28-2006, 08:36 PM
  #118
Franny
Stupid Gravity!
Franny's Avatar
Hi Big,
What I did for my BOT was to hinge the back of the canopy and add a micro servo controlled by the throttle and hooked to the front. When the throttle goes up, so does the canopy and it acts like a scoop. Then, when you are soaring about, and the throttle is down, so is the canopy. It seems to work pretty well, but I haven't flown it yet. Check out my last couple of posts in my link above. Bench test seem to go well. Just a thought...
Franny
Franny is offline
Old 05-29-2006, 08:53 PM
  #119
mars
I'll add my newest.
Windrider Bee, modded.
Windrider Bat, heavily modded.
LEG Mig3
LEG H1
mars is offline
Old 06-09-2006, 04:00 AM
  #120
cebola
cebola's Avatar
This is Hyperbolic Lady, my own design.
The models has 117" of wing span, is powered by a 400 QRP Hyper, and wheigts only 20oz.
Name:	hyperbolic pouso a.GIF
ID:	12640   Click image for larger version
ID:	12641   Click image for larger version
ID:	12664   Click image for larger version
ID:	12665   Click image for larger version
cebola is offline
Old 06-09-2006, 07:02 AM
  #121
ericthetree
ericthetree's Avatar
nice looking bird
ericthetree is offline
Old 06-09-2006, 01:15 PM
  #122
Wow! Woul you tell us about that plane? 117" and 20 oz would be amazing without the motor but with! Amazing!
AEAJR is offline
Old 06-09-2006, 01:16 PM
  #123
Jason T
Electron Liberator
Jason T's Avatar
cebola,
Wow, 117" wingspan and 20oz. Very nice!
Jason T is offline
Old 06-09-2006, 05:30 PM
  #124
cebola
cebola's Avatar
I may confess that this motor is a old vertion of brushed's, but has enough autority to climb Hyperbolic Lady.
In fact there are big differences betwen models for Brushless engines and brushed one's.
But at this mommet I am building another one for Brushless, whit wing spars in Carbon Fiber.
Cebola
Brazil
cebola is offline
Old 06-09-2006, 11:26 PM
  #125
Red Scholefield
Batteries/Chargers
Magnificent!!!! Do I count THREE dihedral changes in just one wing panel - not counting the center? I see where you got the name.
20 oz is really light - any special techniques employed other than lots and lots of holes?
Red S.
Quick Reply: What glider/sailplanes are you flying?
Page generated in 0.16644 seconds with 30 queries
