What glider/sailplanes are you flying? - Page 8 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-17-2008, 03:04 AM
  #176
cbatters
cbatters's Avatar
Originally Posted by Henry Sistrunk View Post
I fly both of these gliders with the supplied brushed motors but with a 2 cell 3200 lipo. Don't really try for long flights. Just go up with power, glide down, then go up again with power.When I get tired after about 30 mins, I land. Really relaxed flying for an old guy.
How does the 2S LIPO compare to a 6 or 7 cell NICAD. (Weighs less with more MAH but likely has less voltage than a 7 cell NICad so what is net performance.)
Clint
cbatters is offline
Old 10-17-2008, 04:07 AM
  #177
jecchile
jecchile's Avatar
Originally Posted by cbatters View Post
How does the 2S LIPO compare to a 6 or 7 cell NICAD. (Weighs less with more MAH but likely has less voltage than a 7 cell NICad so what is net performance.) Clint
LiPos are much lighter than NiCads or NiMHs.
As far as voltages, NiMH and NiCad cells are 1.2 volts per cell - LiPos are 3.7 volts per cell - so, in order to have somewhat the equivalent Volts (which is what "pushes" amps through the circuit) you will need 6.16 heavy cells vs 2 lighter LiPo cells for the same amount of power if the amps are the same (P=IE)...
Performance should be better in the lighter airplane...
jecchile is offline
Old 10-17-2008, 04:23 AM
  #178
cbatters
cbatters's Avatar
However - 7 cell NiCad with 8.4V will provide 28% more watts than 2S 7.4V LIPO.
So the question is whether the reduced weight of LIPO offsets power loss of lower voltage.
Clint
cbatters is offline
Old 10-17-2008, 05:27 PM
  #179
jecchile
jecchile's Avatar
So the question is whether the reduced weight of LIPO offsets power loss of lower voltage.Clint
Test it... it has been my experience that lighter weight improves performance a lot more than a few volts extra from the Nicads. Also, the delivery of power from a Lipo pack seems to be better.
Have fun...
jecchile is offline
Old 10-19-2008, 03:02 AM
  #180
lextek
Multiples EZ Glider Pro with Scorpion, CC Phoenix and 2200 pack. First sailplane and loving it. Nice and relaxing after flying the helis. Love the way it go vertical.
lextek is offline
Old 10-22-2008, 09:52 PM
  #181
Leadchucker
Curmudgeon
Leadchucker's Avatar
Just finished a BOT ARF conversion to electric and it's ready for shakedowns. The Watt-BOT was a scratch and dent special and needed a bit of work other than the conversion. The covering was messed up in quite a few spots on the wing and I didn't care for the original color scheme. So off it all came from the wing and horizontal stab and on went new. The servo for the flying stab was moved forward to under the wing with the rudder servo and a new pushrod and bellcrank setup installed.
Spoilers were cut into the inner wing panels before recovering and each has a micro servo for opening them. Power is a Head Up R/C 3542-10 BL outrunner with 40 amp ESC swinging a AeroNaut Cam 11 x 6 folder. Amps are supplied by a Maxamp 2100 maH 25 C LiPo. A couple test flights with this setup proved this to be plenty of power. She isn't a rocket,but don't waste any time either. The transparent yellow with red trim Mono-Kote is easy to see with the yellow almost glowing when backlit a bit. Balance was no problem requiring only 2 oz. to bring her to specs. She weighs in at 70 oz. putting her 10 oz over the stock weight,but still only has a wing loading of 8.5 oz./sq.ft.
Leadchucker is online now
Old 10-23-2008, 01:31 AM
  #182
CygnusX1
CygnusX1's Avatar
Beautiful BOT!!!
CygnusX1 is offline
Old 10-23-2008, 01:52 AM
  #183
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
Originally Posted by BillM View Post
15. Sprinter (the Brown Airplane Delivery Truck stopped by today)
BM
Otherwise known to your signifigant other as the BAD truck...
FlyWheel is offline
Old 10-23-2008, 02:02 AM
  #184
Leadchucker
Curmudgeon
Originally Posted by cygnusX1
Beautiful BOT!!!
Thank you,thank you very much (In my best Elvis voice)
Old 10-27-2008, 08:14 PM
  #185
caltrop
Can't Help Myself
caltrop's Avatar
Default Condor
I got an old Scorpio Condor Magic 29 at a swap meet early this year and am just now getting some parts to get it going.
It needs a motor and a servo and some slight repairs. I'm adding a wheel and some skids on the wing tips and tail. I'm also going to beef up the wing attachment points. Then I might add some paint instead of the plain white that it is.
I plan on putting an E-flite Park 480 with an 11x7 folding prop in this glider. The chart says it should fly with this.
Hope it flies good... It's a big one - 2.9 meter wingspan.
Name:	_My Planes.jpg
caltrop is offline
Old 10-27-2008, 08:28 PM
  #186
50+AirYears
Since my last entry, I purchased a 74" span glider which I believe was kitted by Airtronics a numbr of years ago. The person I bought it from has had to get out of the sport/hobby with advanced CPD Has a Medallion .049 in the nose.
Maybe not technically a glider or sailplane, but I've started to recover my old Lanzo R/C Stick. 9' span, about 1184 square inchs area. Used to have an old Fox .59 on it, but I will be replacing the Fox with an older Saito .52. The chart says the Saito should spin a 13 -4 prop about the same RPM as the Brown Jr I believe Lanzo used back in 1936. I've seen these planes get hour+ flights with only about 5/8 ounce fuel at SAM contests.
50+AirYears is offline
Old 11-03-2008, 07:18 AM
  #187
Captain_Nifty
Zulu 001
Default My babies...
I live near a somewhat massive soccer field, my hometown glider is none other than the Speedo 1200mm from Revolution shop, I have been wanting to do a proper review on it, however, I 've got a really good camera but I fly solo and the winds are not very forgiving at low levels... I'll do a full write up later at some point to help out other owners.. great little thing, handles wind like a champ, I'm using a Futaba 9CAP with zero speed offset (its an RG15, its going to get a little draggy for sure) however, fast fast fun...
Now if and when I end up at a bigger field, I use two more Revolution shop gliders, the passer-x, it floats, quite simply its beautiful, sleek, and zooms and loops and does all the fancy stuff...
The other one I fly is actually, thanks to the courtesy of Revolution shop, the prototype Bulero Pro Hi-Wind... its a very casual flyer, VERY capable, fun, light, and beautiful... I have landed this one during sunset, beautiful, final approach looks like a hawk coming in... this one I will recommend like crazy to anyone, its not a euro glass slipper, but oh my, delightfully ol skool yet so contermporary at the same time..
Keep in mind, none of these are dlg type launch gliders, they're easily adaptable to ol' high start however, they're pretty much enjoyable in javelin toss form...
Once again I'm terribly sorry, I fly alone, ergo no in flight pics...
Last edited by Captain_Nifty; 11-03-2008 at 07:22 AM. Reason: cleared up some wording .. oy i am tired!
Captain_Nifty is offline
Old 12-01-2008, 11:27 PM
  #188
nathanthepilot
nathanthepilot's Avatar
Originally Posted by Spacey View Post
I'll add my thermal fleet. Sorry only two of them are EP at the moment but one is in consideration and the DLG is getting a EP fuselage version soon.
The red and yellow plane is my F5J comp glider which is a Poly Sergio 2.2meter with a speed 400 and comsmotech planetary gearbox running on a 8 cell Kan 1050 or GP1100 pack.
The blue and yellow plane is my 2meter Electra ARF with a Graupner speed 600 race also running on 8 cells but a Sub C pack.
The big white scale thingy is my 5 meter Nimbus. Still haven't figured out how to get that one in the air but she'll probably get a slimer on a pod or something.
Then the in flight yellow and balsa colored one is my Quickflick IID scratchbuilt discus launch glider designed by my good friend Paul Daniels in Aus. More info on this one can be gotten from me as short kits are now available for the lucky folks in the states. I am working on a Eflite park 370 outrunner powered fuselage for this one.
Other than these I fly a bunch of slope gliders mostly wings.
Sweet gliders! Do you have any video's of them flying?
nathanthepilot is offline
Old 12-02-2008, 12:16 AM
  #189
tramp8754
tramp8754's Avatar
My latest sailplane is a Spirit 100 converted to electrical power. The battery will sit on a platform under the canopy and above the servos. The plan for this conversion was not to gain long duration cruise but to use the motor instead of a High Start to boost the acft to sailing height. Using a 1300 mAh lipo, the hope is to get 2 to 3 boosts/battery. Conversion's AUW added just a very few oz's to the unpowered version's. CG fell right into place with no adjustments (dead weight) needed. Still need to add cooling provisions. It has the capability of deploying crow configuration.
ID:	85407   Click image for larger version
ID:	85408   Click image for larger version
ID:	85409   Click image for larger version
tramp8754 is offline
Old 12-02-2008, 01:37 AM
  #190
Red Scholefield
Batteries/Chargers
Red Scholefield's Avatar
Here are mine. The Graupner Electro Jr. was my first. It is ancient by model standards.
ID:	85417   Click image for larger version
Red Scholefield is offline
Old 12-02-2008, 09:31 AM
  #191
Up&Away
The Original Flying Pig
Up&Away's Avatar
I can't believe I haven't posted my e-BoT here!
So here she is. I electrified her with a AXI2820/10 in the nose, swinging a Graupner 12x6 CAM, getting juice from a 3S2250 Zippy through a JES40 ESC. I also installed 2 spoilers with a micro servo each.
I added some blue stripes to the bottom of the wing, the elevator is removable for easy transportation, and both elevator and rudder servos are up front.
She flies like a dream.
ID:	85444   Click image for larger version
Up&Away is offline
Old 01-06-2009, 06:43 PM
  #192
rudynix
rudynix's Avatar
Just finished this one. May fly it this weekend!
http://www.flickr.com/photos/rudeman...7611238625418/
rudynix is offline
Old 01-07-2009, 07:09 PM
  #193
rubberducky
rubberducky's Avatar
Default What glider/sailplanes are you flying?
My wife say ... Too much
I think, my hobbieroom has 4 walls ... there is enough place for airplanes
I take one of my 50 gliders ... and i am happy
rubberducky is offline
Old 01-07-2009, 07:48 PM
  #194
Cool
I think your wife is right. You should pack up 5 of them and send them to me.
AEAJR is offline
Old 01-07-2009, 08:54 PM
  #195
rubberducky
hello AEAJR,
-----You should pack up 5 of them and send them to me.---
then i have only 45 gliders left ... and must take one of the 40 motor-planes
and what should i do if i am old and finish my job? (in 2 years)
may be ... back to the roots ...balsa woodcrafter
Old 01-07-2009, 09:08 PM
  #196
Bub Steve
Bub Steve's Avatar
rubberducky:My live'in room looks just like that,HaHaaa! (Were we separated at birth??) I'm put'in a big honk'in outie on mine as she's been out-o-action for awhile, bub, steve
ID:	89559   Click image for larger version
ID:	89560   Click image for larger version
ID:	89561   Click image for larger version
ID:	89562   Click image for larger version
Name:	petty an red 8783.jpg
ID:	89564   Click image for larger version
Name:	petty an red 8809.jpg
ID:	89565   Click image for larger version
Name:	petty an red 8786.jpg
ID:	89566   Click image for larger version
Name:	petty an red 475.jpg
ID:	89567   Click image for larger version
Name:	petty an red 634.jpg
Bub Steve is offline
Old 01-07-2009, 11:12 PM
  #197
Nice decor, in your living room.
AEAJR is offline
Old 01-07-2009, 11:15 PM
  #198
Bub Steve
Bub Steve's Avatar
Beats Paint'in!!!!!!!!!!!!!!!!!!!!!!bub, steve
Old 01-08-2009, 12:54 AM
  #199
Hodgehound
I Saw fatboy,Yak-ing!!!!!
Hodgehound's Avatar
I'm flying a 20+ yr old Gentle Lady with a Slimer .061 (throttled) on the nose and a Wright Brothers RC "Gambler" DLG. The GL is great for gettin high and thermalling and the Gambler is just plain F-U-N!!!!!!!!!!!!!!!!!!!!!!!
Hodgehound is offline
Old 01-08-2009, 01:02 AM
  #200
xuzme720
c'mere Monkey
xuzme720's Avatar
I have 3. An ARF I can't remember the name of, a GP Spirit, and a Riser. My first 2 meter was a Gentle Lady. She bit the dust when a strong crosswind flipped her on the high start! BOOM! Balsa confetti!
xuzme720 is offline
Quick Reply: What glider/sailplanes are you flying?
Page generated in 0.11243 seconds with 31 queries
