$100 EDF Scratch Build Contest Flying Wing
Old 10-28-2014, 04:46 AM
Now, Lets See if I can Make this hot wire bow cutter into a Gravity feed Cutter, I have a PHD in Watching others people do these things on You Tube LOL, Lets see, I need 4 screen door rollers and some nylon cord and I think i have every thing else. I am Not Afraid to Try I Fail My Way to Success LOL, I will post some video of it Gravity Cutting if it works out, Take care and have fun, Chellie
[media]http://www.youtube.com/watch?v=S2TfNYSYLC8[/media]
Old 10-28-2014, 04:37 PM
road king 97
old hat
road king 97's Avatar
That wire looks hot enough now Chellie ! Good work with the AC ,Trust me i did not get mine working right away either it took me some time and burnt fingers .lol joe
road king 97 is offline
Old 10-29-2014, 04:25 AM
Hi Joe The bow cutter gets nice and hot, maybe to hot its hard to control the Wire heat with A/C and a dimmer switch, might have to go to a 24V- 5 amp transformer with a dimmer switch, It keeps burning up the Formica patterns, I may need to use sheet metal patterns too, as the bow wire tends to burn notches in the Formica patterns, Oh well, Its all a Learning experience, I Will get it to work, the problem I am having right now, is that the Gravity feed foam cutter requires me to leave the bow wire on the pattern, untill the wire starts to cut the foam, and during those few moments, the wire eats into the Formica pattern and hangs up, I wanted to use a gravity feed cutter to Minimize Human Error during the cutting as this wing goes from 12" in the middle to 5 1/2" at the end of the wing and a gravity feed cutter will compensate for the wide and small end of the wing during cutting, Thats the plan anyway I made a Redneck Gravity Feed cutter, it works good as far as the difference in area it will cut, large to small, just need to better regulate the heat on the wire, as to hot of a wire is not good, Take care, Chellie
Old 10-29-2014, 05:29 AM
Abuelo
Abuelo's Avatar
Chellie,
Put a 'tail' on the formica pattern at the trailing edge, quarter inch by two or three inches is enough. Start your cutting on the tail and if the pattern starts to burn, nothing is lost. You'll cut the foam tail off at the trailing edge.
Good luck.
Abuelo is offline
Old 10-29-2014, 06:08 AM
Originally Posted by Abuelo View Post
Chellie,
Good luck.
Thank you for the info, That might Do It
Old 10-29-2014, 03:42 PM
pmullen503
I'm on the road right now or I would send you a photo, but I've used a piece of copper wire epoxied to my template as an "on ramp".
RE. hand guided cutting. I have had some success cutting highly tapered wings by starting in the center and cutting out towards the ends. I'd make a plunge cut at the 30% and cut either forward or backward. The area where you plunge in always has a ridge from changing direction but I was cutting a slot for a spar with a router on that line so it didn't matter.
I've also built a gravity cutter which is fine but fiddly to set up. I just cut by hand mostly. Put marks every 10% on the root and tip to help keep you straight as you go. Practice the cut with the wire above the blank a few times to get a feel for how much one hand has to move relative to the other. You should end the cut with your body relaxed and in balance. It's always better to start off less balanced and end relaxed than the other way around.
It helps to count while you cut. You should hit every 10% mark at the roughly same interval.
pmullen503 is offline
Old 10-29-2014, 10:31 PM
road king 97
old hat
Yep yours might be to hot ,mine gets hot but not that glowing red hot and it cuts slow but smooth . joe
Old 10-29-2014, 10:48 PM
Thank you for the info I have a metal wire ramp on the formica pattern, right where the wire ramp and formica meet, is where the wire burns into the pattern, Like Abuelo suggested, i may need to make the end of the pattern from sheet metal to get the cutting started, and with the wire not being to hot with a 24v system, that should work out ok Its all a learning experience
Yes, looks like i will need to use 24v rather than 120v, easier to control the heat
Old 11-04-2014, 08:29 AM
Default I Am Winning , Almost Got it Down
Hi Everyone I am Winning, not quite there yet, I made a Red-Neck Gravity Feed for the Bow cutter, I hooked 2 - 12v car batteries together for 24V and used my 12/24 volt 30 amp DC motor speed controller, and I have great Control on the heat on the bow now, works like a Charm, I can set the heat perfectly now, My Bow, I found out is not Deep or wide enough, I am cutting foam at a angle, and I need a wider bow, the foam is 20" long, I made my bow 30" wide, but cutting at a angle, requires a wider bow, also, I did not make the bow deep enough, it hung up as I was making a Gravity cut, and it melted the foam a little more than it should have I am Learning I almost got a perfect cut, and might have if the bow did not bottom out on me and hit the weight I was using to hold down the foam with, Live and learn, I need to get some more foam, I messed up the foam that I had Learning to hot wire it I will succeed, If they can do it on You Tube, then I can Do It too LOL, I used model air-plane wheels with the rubber wheel removed for the pulleys, Now how Red Neck is that LOL, Off to lows tomorrow for some birch wood for a new bow and some 1/4" eye bolts for the wire, Take care and have fun, Chellie
Practice Makes perfect, I am Not Quite there yet, but Close you can see where the bow hung up at on the trailing edge, and burnt into the foam towards the rear. I need to make a new Bow thats deeper and wider, so the silly thing does not get hung up and mess up my Foam
ID:	178224   Click image for larger version
ID:	178225   Click image for larger version
ID:	178226   Click image for larger version
ID:	178227   Click image for larger version
ID:	178229   Click image for larger version
ID:	178230   Click image for larger version
Old 11-04-2014, 03:23 PM
riverrat
circa: 1946
riverrat's Avatar
Didn't I say Tenacity??
Your getting there!
riverrat is offline
Old 11-20-2014, 09:42 AM
Default Yaaaaaaaaa Finally Got Me A Flying Wing Cut Out
Hi Everyone Finally Finally Finally Got My Hot wire Wing Cutter to work Here are some pics, un retouched just the way they came out of the Shell, They need a little Light sanding and trimming, But I am, Very Happy the way they came out trying to hot wire cut foam wings is not easy at all, Its right up there with with learning to fly RC Airplanes, after a Ton of Trial and Error , I am happy with the results here is what worked for me.
1. made 2 aluminium wing cord Patterns , used 3m 77 and small nails to hold the patterns to the foam. It Took me a Full Day to make those 1/8" thick Aluminium Patterns.
2. 24V, I used 2 car batteries in series hooked to a 12/24 Volt, 30 Amp DC motor speed controller with 20 gauge Ni Chrome wire.
3. Used a Tethered hot wire, one end is stationary and the other end follows the bigger wing cord pattern, inboard and outboard wing cord patterns were used,
4. Lots and Lots of Stubborn Determination to learn how to Hot wire Foam Wings , I Win Again
ID:	178441   Click image for larger version
ID:	178442   Click image for larger version
ID:	178443   Click image for larger version
ID:	178444   Click image for larger version
Old 11-20-2014, 10:53 AM
Good work Chellie! Looks just like the pros. I like the shape of that wing.
Old 11-20-2014, 01:34 PM
  #63
Good work Chellie! Looks just like the pros. I like the sharp of that wing.
Thank you Mech It came out better than what i thought it would too now to mount all the electronics and braces, the Foam is really strong too, i dont think i need to brace it, but i will anyway the foam is lighter than EPP foam too, I am a Happy Camper now the EPP foam was a Bear to hot wire, and I did not know what I was doing at first, but now that I found this Extruded Poly Foam, it will be easy to make new wings, as the EPP foam would make stringers when cut with a hot wire, I wasted a 4' x 4' x 2" sheet of EPP foam learning to hot wire foam, and what i learned is that EPP foam is a Pain to work with, I wont be using EPP Foam any more, Take care and have fun, Chellie
Old 11-20-2014, 01:58 PM
  #64
riverrat
circa: 1946
riverrat's Avatar
Chellie
Good JOB!
Jimmy
riverrat is offline
Old 11-20-2014, 08:07 PM
  #65
Originally Posted by riverrat View Post
Chellie
Good JOB!
Jimmy
Thank You Jimmy
Old 11-20-2014, 09:45 PM
  #66
pmullen503
Extruded or expanded polystyrene will be much easier to work with.
Now that you can cut your own wings you'll realize the possibilities that skill gives you.
Old 11-21-2014, 12:51 AM
  #67
Love my Stinger
Fishbonez's Avatar
Great job Chellie you should make a demo video on youtube
Fishbonez is offline
Old 11-21-2014, 03:16 AM
  #68
Congratulations!
Old 11-21-2014, 01:37 PM
  #69
Bobdaeronort
Bobdaeronort
Excellent!
Bobdaeronort is offline
Old 11-21-2014, 04:22 PM
  #70
hkeelljr
Great job!
hkeelljr is offline
Old 11-21-2014, 11:38 PM
  #71
Thank You Everyone for the Complements Hot wire cutting a wing is not easy to do, as I just found out Take care and have fun, Chellie
Old 11-21-2014, 11:44 PM
  #72
Good idea After I practice a little more , I will do that
Old 11-21-2014, 11:52 PM
  #73
riverrat
circa: 1946
riverrat's Avatar
What I said?
TENACITY!!!!
That is the definition of Chellie!!!
Regards!
Jimmy
riverrat is offline
Old 12-02-2014, 10:30 PM
  #74
Ok Getting back to the build, Finally this Stupid Cold I have been Fighting off is getting better, Making some rough cuts on the foam to get the placement of everything and to get the CG, the ESC and lipo will be inside a vented cut out in the wing with a hatch cover to keep the airflow as clean as possible, I am using a 70mm edf, 60 amp esc and a 4 cell, 2200mah lipo, its getting there, I have to cut a slot for the wing brace, and esc and lipo, then, cover the wing with colored packing tape, the winglets and the middle skid will be the last things to be attached, hope to fly it this weekend if the weather is nice, Take care and have fun, Chellie
ID:	178593   Click image for larger version
ID:	178594   Click image for larger version
Old 12-03-2014, 10:59 AM
  #75
RepRapper
Default Free Plans for A Foam Wing Cutter
First of all its good to see you cutting foam wings! They look great! Sorry you had to go to so much effort. Cutting foam wing should not be that difficult. I have been doing it for 37 years now. Maybe this link might help anyone trying to build there own cutter.
http://www.utahflyers.org/build-main...m-cutter-plans
RepRapper is offline
Page generated in 0.16070 seconds with 33 queries
