Hobby Lobbys new FlyCamOne v2
Absolutely right. FCOv1's had no such film. In addition, there's no indication I could find that the film is present. Nothing in the micro instructions. There was no tab at the edge. The film wasn't thick and heavy. In fact, mine was thin and stretchy. The matte finish blended in perfectly. I hesitated to say something, but some of the posted pics looked like my first batch, with the film in place. I'm using a Sandisk Ultra II 2 GB card. It seems to work fine with my Mac. The USB cable works, but it's only USB 1.1. Removing the card and using a card reader for downloads gets me USB 2.0. I upgraded Quick Time to QTPro for a few dollars. It allows one click flipping horizontally and vertically, and 90º rotations. It also does brightness, contrast, tint, and saturation easily. Now, I just need to get my RCdisc built to put it in.
Thank you very much for pointing out the lens protection film!
--Dave
I sent mine back.I tried 2 sd cards,sound and video not in sync,and blue and red flashes in video.The directions should say that you need a high speed card,and to remove the plastic film on the lens.I did'nt notice that.I'll follow this board and maybe get a new one later.Dissapointing.
Mine came yesterday and it's not working. Plugged it in to charge it and the WC is on the display comes on (webcam) but when I remove it from charging I get nothing when turning it on
Help,
. I flip the switch and press the 2 (shutter) button but still nothing 0n the display telling me it's on. could I be doing something wrong, tried everything
--Dave
Flew today minus the lens protector!
Was better!
I've come to the conclusion, the people saying you need a fast card are right.
I noticed when I first used the cam, the audio was slightly out. Today it was way out.
The trouble is the video cuts out when you play it on your pc, when the sound stops. Which was way before I landed!
Paul.
Was better!
Paul.
ACME just put up their second new firmware update for the FCO2. The main change listed in the readme is that it now can record video in 320x240 format.
It is too dark here to try it outdoors, but it does work as advertized in doors, except for one little detail. The readme says that a new menu item "LE" has been added for low resolution recording, but the actual menu item that I see is "LP". With the quarter size video recording comes a corresponding quarter size video bit rate, so it should give much longer recording time on smaller SD cards as well as probably working with some slower cards. Here is the GOM Reader analysis of the AVI file produced by my first low resolution trial.
Basic File Information
File Name : PICT0001.AVI
File Format : AVI format
File Size on Disk : 2,137,788 Byte (2.0 MB)
Data Size : 2,129,360 Byte (2.0 MB)
Playback Time : 00:00:13 (13 Sec)
Average Bit Rate : 1.22 MBits/Sec
Video Stream
Codec Type : Microsoft - Motion JPEG DIB Format (MJPG)
Image Size : 320 x 240 ( 1.33 : 1 )
Average Bit Rate : 1.15 MBits/Sec
Frames/sec : 26.54 Frames/Sec
Total # of frames : 371
Audio Stream
Codec Type : PCM AUDIO (0x0001)
Bit Rate : 64.00 KBits/Sec
Sample ratio : 8,000 Hz
Channel count : 1 Channels (MONO)
Key Frame
Index Status : The index of the file is valid.
Total Key Frames : 371
Average Interval : 0.038 Sec
Maximum Interval : 0.038 Sec
Minimum Interval : 0.038 Sec
Standard Deviation : 0.000 Sec
=========================[ By GomReader ]==========================
Video Stream
Audio Stream
Key Frame
No.
Possibly, but not likely. The FCO2 uses a standard recording format, not like the eDVR with the ST Labs chip and it's proprietary recording format. I suppose that it may be possible to program the ST Labs chip to use a standard format too, but none of the chip markings that I can see in the FCO2 say "ST Labs"
The same as it does in 320x240. It's the standard frame rate for PAL television, and it was designed in a PAL TV standard country, so it seems like the most obvious frame rate to use?
--Dave
Originally Posted by salat
What chip is in it? ST Labs?
What FPS it gives in 640x480 mode?
--Dave
Help,
My camera won't stop recording about 70% of the time. I put it in the "UR" mode, hit the start button, fly around a bit, hit the button to stop and it just keeps recording. I have to turn it off to stop it, which deletes the video.
It only does this while on the helicopter.
Edit:
I just tested the cam and it will do this when not attached to the heli. I'm going to try to exchange it.
Edit:
No.
--Dave
--Dave
Can you please post close picture of circuit board? Or write down chip names?
Thank you,
Kostya
I got mine out of the box today. It seems to work fine and I removed the lens protector first
. It doesn't like the indoors at all, I tested it outdoors and it seems pretty good for a little camera.
I noticed in PIC mode you can choose a picture to be taken every 3 seconds. Anyone use this mode yet
If the wind dies down I'll try it tomorrow
Pretty cool camera
, I used it on my RC truck and I thought the video was pretty good. I like how easy you can add a servo with the supplied horn for tilt and then you could put the camera on another servo and have pan
I love mine. It seems to work great. I took it out side and did a sample video, it loaded very easyly in to my laptop. The quality of the video was great for what the thing cost. I can not wait to get onto my plane.
-Andrew
-Andrew
This little camera is pretty good outdoors. I attach it to my Trex 450 which is a vibration nightmare do to a bent main shaft, dented tail boom and a few other minor things but a good test platform
and I was surprised once again on how well this little cameras quality is
. I'm not sure about stills though
better to use it for video only
. The pictures above my house are lifted from the video so don't expect much quality but you get an idea how good the colors come through.
I got a nice clear video with it being late afternoon
By getting the update I will still be able to chose 640 format still. Are there any advantages that you see in upgrading the firmware if you plane on using 640x480.
Thanks,
Jeff
Thanks,
Jeff
Video Stream
Audio Stream
Key Frame
Video Stream
Audio Stream
Key Frame
--Dave
It is free, so if you want to try it you can get it here:
http://www.headbands.com/gspot/
--Dave
