Hobby Lobby "Miss Stick Junior" Build Thread
#102
It is looking good Kev!
I have no doubt you are learning much more building this plane that a LASER cut kit. Those tend to spoil you. The second model I ever built after getting back into the hobby was a Soarwatt. When it came in the mail all that was in the "kit" were plans and a bunch of 1/8" x 1/4" sticks! I said to myself "this is a kit?!" It taught me a lot though. Much more than gluing LASER cut pieces of wood together.
Keep up the good work.
Frank
Frank
#103
Frank
Frank
#105
I didn't reinforce the dihedral joints and all is well. I mount my batteries on the wing so the wing attachment is less stressed. It does inside and outside loops and it rolls well once I figured out how to best do them. It is on its second season.
#108
#109
It is a nice looking model; I agree a little larger would be cool. I'd like to find a nice 182, and make a replica of the planes we use on the State Police.....
Thanks Jeff. I think I will do that as well. Did you use epoxy? I am debating epoxy or white wood glue......
#111
I'll ask you too, and anyone else who wishes to add their 2 cents: epoxy, white glue, or another adhesive? opinions? ideas? taunts? LOL
#112
Kev,
If the two ribs have a good tight fit, you can use Titebond wood glue or Elmer's Carpenter's wood glue. Spread an even film of glue on the ribs, clamp them with clothes pins, wipe off the excess glue with a damp paper towel and let dry.
If glued correctly, the glue joint will be stronger than the wood itself. You can use epoxy but it's not really needed.
I wouldn't use regular white Elmer's glue.
#113
Kev,
#115
With the joint out that far from thr center, the bending loads are not large. In the 1960's I flew a couple of .60 and .49 powered pattern ships with no plywood at the dihedral joint in the center. We didn't use fiberglass then. Just linnen pinking tape with Ambroid cement. We used that glue for everything. The dihedral joints survived. Even crashes.
#117
Frank
Frank
Kev, that Miss Stick is looking good!!
#119
You guys have forced me to dig out several of the Tom Hunt 'Stick" plane plans I have. It looks like I will be building the Twin Dimwatt after the current build (SA SHAFT 400) is off the table. I also plan to make my own strip wood. I've got a Master Airscrew balsa stripper here and a small pile of 1/8" sheets. Beats buying 1/8" sq. by the stick!
From what I am seeing so far, I agree!
#123
OK folks, I started covering.....not a lot, but wanted to post the first pics.
Got the control surfaces (in this case, rudder and elevator), and the vertical stab done. I had done the horiz stab, but I messed it up and need to redo it.
So far I seem to be doing ok.
Steve got one half of my wing glued and clamped; I will let it sit overnight and do the other side tomorrow. Should be ready to cover by Monday or Tuesday, barring any new crises....
#124
Hey, Kev, great job! Covering's not that hard, once you try it. I think it's good to start on the tail, it's small, if you have a problem just pull off the old piece and try again.
Looks like you got the hang of going around the edges and the overlaps, nice work. The wing will seem easy after this.
Keep us posted!
Ron
Keep us posted!
Ron
#125
Just went down to check the wing; Steve had glued up the center panel and the right outer panel yesterday. It looks great! I just glued up the left panel to the wing assembly the same way he showed me, and tomorrow I will check it out, get it sanded and prepare to cover it.
