Hobby Lobby "Miss Stick Junior" Build Thread
#176
Kev, It looks good.
Good luck on the test flight.
On your pushrods, I usually put the screw retainer on the control surface horn and the bent wire inside on the servo.
That way I can adjust the pushrod without removing the wing.
Paul
Paul
#178
Here I have a micro clevis holding the pushrod on the control horn. It was pointed out last night at the club meeting I should bend that wire to keep it from coming out of the control horn; I remembered I had some of these doodads in the shop, and decided to use them. Looks much cleaner to me.
#179
If I get to do it tomorrow, I hope so. Thanks. If not, I will shoot for a day soon, and bring the camera.
#180
Today was a picture-perfect March day, with temps in the upper 50's and light-to-no wind. Mostly sunny skies, some clouds here and there. Like I said, picture perfect.
So where are the pictures, you ask?
Well, none were taken. If I had taken pictures, all you would see today are pics of my wife sitting in the doctors office, with either flu, or menengitis, or a fibromyalgia flare, or God knows what else. I felt bad for her; she felt bad for me. But what can you do? All I know is, fate was NOT on my side today to fly my little masterpiece. And today was my Sunday. No days off til next Friday. But that, my friends, is the first of my 3-day weekend.
So, sorry for the delay, but I am sure you all can understand. Despite what she may say, the wife does come first.
#181
Seriously though, sorry to hear about your SO. Hope she feels better soon.
#182
#184
Oh, yeah.....I hope she gets well soon....
#186
Of course, if you would like to explain it in ways I can understand it (talk slow, use small words, etc....LOL) I would be a willing pupil.
#187
#188
I always love it when people bring up the subject of wing wash out. As I understand it, it is a variation in the curvature of the wing at each wing tip which will prevent tip stalls. You induce a flatter airfoil near the tips, but I don't know what percentage. Haven't looked at Frank's (Murocflyer) link yet.
Now never having induced washout in any plane I currently own, I have zero qualification in explaining it. Wasn't that fun?
Hey, you're still doing a great job on the Missy!
Bob
P.S. Looked at Murocflyer's link: washout is basically a change in wing incidence along the wing root to the wing tip. The tips are aligned 1 to 2% lower at the leading edge than the incidence at the wing root. Better to build it in than trying to wing warp it with water or other fluids. End result: no tip stalls if you build it right.
Bob
Honestly, I have no idea. I don't even understand the term "washout", but one of the guys mentioned it and said it looked good.
#192
As always, you are a wealth of info. Thanks, I appreciate the link.
Thanks Al; I kinda figured even with the warp in the fuse I had, it would fly OK with some help from the trims, but I feel much better having it straight. And the slow speed should be great for my flying skills to improve with.
#194
I am hoping this can be my "throw in the car in case I can get a few mins to fly" plane. It's surely light enough. If it flies slow enough, I may even take it to the headquarters to fly on my breaks.
#195
I do have a question I'll post here, though. My elevator servo buzzes when I power up. I am told this is probably some slight binding from the connector I used, and it may free up with use. It also should not be a power drain issue. Anyone have this come up, and how did you solve it?
#197
I can jiggle the sticks and sometimes it stops. Or I can slightly move the control surface and sometimes it goes away. Sometimes it doesn't do it, and then I move the elevator and it starts. It also seems to be lessening up as time goes on, making me lean towards the suggestion that the connection between the connector and the servo arm just needs some time to loosen up. But I wanted to bounce it off my buddies here and see what comes out of discussion.
#198
I get noise with some of my HS-55s but it usually stops with some control movement. Noise typically means pressure on the servo arm from something. If it is getting better I wouldn't sweat it for right now, just keep an eye/ear on it.
Frank
Frank
#199
Hey Mslpc, no offense intended. I see the term "tip stall" quoted a lot. I don't use it and have never really experienced it (especially since it apparently doesn't exist!
). So what exactly is an uncoordinated stall- a newbie who's all thumbs and puts his plane into a death spiral? Inquiring minds want to know.
Bob
Bob
