For Sale For Sale - Futaba 6EX Transmitter, Four Matching Receivers, and more — $100 Shipped
Transmitter:
Futaba 72mhz 6EX Transmitter in original box. Includes instruction manual, wall charger, and channel 52 flag (still in original bag). Also included is the original 9.6V 600mah NiCd Tx battery. Transmitter has normal, light wear on the case. The "chromed" areas are perfect, with just some surface scratches on the black plastic on the back of the case. Gimbals are nice and tight. Transmitter is functionally perfect and has performed flawlessly.
Also included is a matching GWS USB cable to use this transmitter with your favorite flight sim.
Receivers:
One Futaba R156F 6ch receiver.
Two Corona RS610II 6ch receivers. Both Rx function perfectly. Please note that one Rx has a repaired antenna that was severed in a crash. The antenna has been carefully repaired and has proven trustworthy on numerous flights since the repair. See image below for close-up of the repair. The other has a small crack in edge of the blue shrink wrap but is otherwise perfect. (No effect on functionality, obviously.)
One GWS Pico 4ch receiver.
All of this equipment (transmitter and each receiver) includes matching crystals on channel 52. I may have an additional channel 52 crystal, if so it will be included.
$100 for all, shipped in the cont. U.S.
Payment via postal money order or PayPal (preferred).
Will consider trades of unbuilt GWS kits, or similar.
Please PM if interested. I'll base buyer priority on time of PMs.
Receivers:
P M sent.............................................. ............................
OK, apparently it forces you to a five post minimum before you can PM. So here's some bumps so I can talk to Clyde!
