Polyurethane for dollar tree foam
Hi
I have wing that I知 building with dollar tree foam. I would like to water proof the bottom portion of the wing especially. Right now the whole wing weighs about 260 grams without battery and I would like to keep the added weight to a minimum.
Would oil based polyurethane work fine without adding much weight? Or was I better off with just using packing tape?
Thanks!
Thanks!
Hi
Thanks!
Thanks!
Never weighed to see how much weight it gained???
It works for me & I like the finish! And I think it adds a little strength???
Regards
Jimmy
I use clear varnish as sold for woodwork / boats etc. I also have spray lacquer - but that needs a barrier paint on before its use as the propellant is petroleum solvent - which eats bare foam.
Just commenting ... for paint jobs on models - I use house emulsion of poster paints which are all water based. The Emulsions are generally resistant enough for our use and if no other added - can be easily touched up when marked. The Poster paints of course will not like any moisture ... have a model out when that little shower happens and you may find the paint starts to lift ... so I give it a thin coat of varnish over seals it ... Easy to repair / touch up ... You can get matt ... semi matt ... gloss varnish as you want ...
