Sig Kougar Mark II
Old 12-16-2012, 01:10 PM
gramps,i love the way your wing tips turned out so nicely!!!the whole bird looks great.
having had the same issues with the prop cutting grass...lol...i cut my nose gear and soldered a longer gear on. the reason i soldered it is the gear is located behind the motor and fire wall. everything was operating so well with the exception of prop clearance.
i flew the cobra for the first time this season after it's waiting 2 years hanging off the ceiling and it was awesome!!!! it still cut grass though and gained speed quickly for liftoff. once on the ground i cleaned her up of grass clippings and flew again.
i agree that putting a larger tire on the nose stinks for the visual looks on the flight table,but in the air as the pilot...wheels were last thing on the mind and just getting her finally flying was all that mattered.
gramps it would be a blast to get a bunch of us together and try formation flying.
i put in these pictures of the gear before the soldering. the repair look great and didn't add much weight. so if the nose gear still gives you problems its a very easy fix. you can see i had the nose gear to short in the pic of it on the table. not the pitch of the plane is nose up a bit and takes off great.
Name:	new folder 083.jpg
ID:	164883   Click image for larger version
Name:	new folder 084.jpg
ID:	164884   Click image for larger version
Name:	new folder 085.jpg
Old 12-18-2012, 02:16 AM
gramps2361
gramps2361's Avatar
This is not my first trike so I now about cutting the grass. I think I do a better job of it than the guy that cut's the field. The tips of my props become green and I have bits of grass stuck to the plane.
I checked the prop clearance with a 11" prop I have 2 1/2 inches of clearance with 2 1/2 inch wheels. When it's ready to fly I will see how much of a issue it is I have wire on hand to bend up a new UC.
Stuart it would look sweet seeing these fly in formation at a fly in.
Well I am waiting on the spinner to come in and then I can mount the cowling so I can get the colors on it.
gramps2361 is offline
Old 01-11-2013, 11:06 PM
starcad
Model Designer
starcad's Avatar
Originally Posted by gramps2161 View Post
Started on the covering have the white down on the wing and trailing stab and rudder covered. Did this the other day a nice white canvas to add trim to.
Started getting some color on the wing tips red and blue are down.
I tried heating and stretching the red covering on the tips for the first time. The first one came out with some wrinkles and the second attempt came out a lot better. Just need to heat it first then pull and tack it down. My wife helped hold down the wing it does take some force to get the covering pulled and then iron it in place.
Next is to try and mimic the Thunder bird on the bottom of the wing.
Just taking my time and doing a little bit each night makes it more enjoyable. What do they say baby steps.
Looking good Gramps. Your so right the best trick to Monocote is Heat, starch, and Tac. Took me years to learn that but now it seems like just doing a normal day of ironing. About 10 years ago I was fortunate enough to be able to watch all Top Flite Monocote Covering VHS tapes. I learned more in those three hours than in 30 years covering models.
starcad is offline
Old 01-13-2013, 01:03 AM
gramps2361
gramps2361's Avatar
Thanks Starcad I watched some covering videos on YouTube they are good learning tools. The actual covering part that's when you really get the learning curve.
I just got the correct prop adapter from True Turn awesome folks to do business with. I clicked on the wrong one, and had to send it back. I called them up to let them know the phone rang 3 times and I am speaking to a person!
I did get the decals put on and checked the CG. Found I will be able to go with a 4c 3300 mah battery instead of the 4000 mah one little more wgt. savings. All that wgt. off the back end paid off I had the battery pushed back towards the COG instead of all the way forward against the motor mount. Now to get the cowling mounted so I can get some color on it.
On the home stretch finally.
For got to add the AUW is 5lbs 1 oz she did come out light for a conversion to electric.
Name:	bucker jungman 001.jpg
ID:	165532   Click image for larger version
Name:	bucker jungman 002.jpg
ID:	165533   Click image for larger version
Name:	Sig Cogoar 003.jpg
Old 01-13-2013, 01:11 AM
road king 97
old hat
road king 97's Avatar
Looks great Gramps ,reminds me of the thunderbirds that would practice clost to the subdivision i was building in Vegas. Iam looking forward to your maiden flight Gramps . joe
road king 97 is offline
Old 01-27-2013, 10:13 PM
gramps2361
gramps2361's Avatar
Joe I love watching the Thunder Bird's videos on youtube.
Finally have the battery compartment figured out, and CG looks to be good. A couple of flight's will confirm whether the battery needs to be moved back. It does seem on the nose heavy side, which I have learned is better for a first flight.
Been so dry and cold up here plus the pellet stove dries things out even more. I have some extra wrinkles to take out of the covering, but I will hold off and see what happens when the air is not so dry.
Ran up the Axi 2826/10 11X5.5 prop with a 4c 3300 mah battery charged at 4.10. Very happy with the readings from the watt meter pulling 42 amps and 667 watts then would drop to 647 to 637 watts. this is a 2 year old battery that has seen better days.
Well when the warmer weather gets here, and I can get down to the club I will post up on how she flies.
Very happy with this plane to me she looks sleek and beautiful.
Name:	Sig Cogoar 001.jpg
ID:	165931   Click image for larger version
Name:	Sig Cogoar 002.jpg
ID:	165932   Click image for larger version
Name:	Sig Cogoar 004.jpg
ID:	165933   Click image for larger version
Name:	Sig Cogoar 005.jpg
ID:	165934   Click image for larger version
Name:	Sig Cogoar 006.jpg
Old 01-27-2013, 10:26 PM
road king 97
old hat
I have to stop looking at your thread Gramps ,your plane is a piece of art and makes me want to hunt down a sig kit of my own. Good luck on your maiden Gramps she is a keeper ! joe
Old 01-27-2013, 10:48 PM
ripacheco
I'm back in the hobbie after 20 years. Sig airplanes are awesome. I got a Sig kadet senior EG something like this Kougar is at least 2 airplanes away still. Awesome project!
ripacheco is offline
Old 03-24-2013, 07:56 PM
Achmed
Achmed's Avatar
I am planning to build a Kougar out of foam but cannot find any plans. If someone would please share some dimensions with me it would be a great help.
What i need....
wing measurement LE to TE in the center including the aileron as well as the same measurement at wing tip.
dimensions of ailerons
dimensions of fuselage at largest point as well as the TE of the fuselage
I already have the dimensions of the tail feathers
Thank you in advance!!
Achmed is offline
Old 03-24-2013, 09:38 PM
gramps2361
gramps2361's Avatar
The wing span is 51" center of wing 12 5/8" tapers to 9 1/2" at the wing tips. The ailerons are 21 1/4 X1" fuselage length is 45 1/2".
Hope this helps you out. I am still waiting to maiden this plane hoping next weekend will be good weather wise.
Old 03-24-2013, 10:19 PM
Achmed
Achmed's Avatar
On the fuse i was actually looking for how tall the fuse is in the front and rear and how wide it is across the top in the front and rear.
I am in illinois and got 6 inches of snow this morning and just started snowing again.
Achmed is offline
Old 03-24-2013, 10:45 PM
I have a King Kobra kit and am planning to go e-power with AXi 4120/18 on 6S (had it in a .90 size Pattern style plane that I wore out)
I am expecting to have to use a 3-blade prop to prevent needing to make the plane look like its on stilts.
I found this thread a bit late... There's a lot of room to lighten the wing by cutting holes.
I believe Sig is discontinuing the Kobra, Kougar, King Kobra series. They have been wonderful aircraft.
Old 03-24-2013, 11:07 PM
gramps2361
gramps2361's Avatar
The front measurements are 3"w 4"h the tail is 1"w 1 7/8 H. I saw a great battery hatch to late for this plane. It was made where the canopy sits on the turtle deck. Way better than the way I did it on the bottom.
fhuber you are not going to save much wgt. by taking foam out of the wing.
Old 03-24-2013, 11:28 PM
Achmed
Achmed's Avatar
Thanks Gramps
Achmed is offline
Old 03-24-2013, 11:49 PM
gramps2361
gramps2361's Avatar
No problem if you have any other questions ask away I will help if I can. Hope you post up some pics when you get done.
Old 03-25-2013, 12:15 AM
Not just foam... big lightening holes clear through, all aft of the airfoil high point.
I have done this before on sheeted foam wings with great results.
Old 03-25-2013, 12:34 AM
gramps2361
gramps2361's Avatar
Gotcha thought you just meant cutting holes in the foam then sheeting the wing.
Old 07-17-2013, 03:47 AM
ripacheco
Has the Kougar flown already?
Old 07-19-2013, 02:55 AM
gramps2361
gramps2361's Avatar
ripacheco i did the maiden flight down SEFF this past spring was a little nose heavy. the kougar has been tweaked and the CG is where I want one thing I need to do is add a little more down thrust to the motor. Other than that I love the way this plane fly's and looks on a low fly by. After the limited flights i have on this plane I can see why it was and still is a sought after kit.
Old 03-31-2016, 09:17 PM
rfzl
rfzl's Avatar
Default Modified Kougar - Princess Plane
I know this thread is a bit old but now that I'm getting back on this site, wanted to show what this plane can become if you have a grand daughter who loves Disney princesses.
It started out as a standard kit and removed the turtle deck and canopy, added retracts, and installed electric motor.
The images are a few years old as they are when I finished the plane for my grand daughter's 3rd birthday. To say it is popular at our club's family picnic day is an understatement. Like all Kougars, it flies great and is fast with the wheels pulled up.
Ron
rfzl is offline
Old 03-31-2016, 09:50 PM
gramps2361
gramps2361's Avatar
That is awesome I like the look with out the turtle deck and a different canopy. Your granddaughter's beaming smile says it all. She loves her Disney themed Kougar!
Curious what motor battery combo did you electrify the Kougar.
I am still flying and loving mine.
Old 03-31-2016, 10:10 PM
rfzl
rfzl's Avatar
Default Princess Plane specs
Gramps,
You have me there as I can't see the motor with the cowl on. If memory is correct, it is a HK NTM motor somewhere near a 3842 with about 1000kv and pulls north of 550w (maybe 600w at WOT). I turn a 11x5.5E APC prop and use a 4S 4000mah LiPo. It balances just fine with this setup and goes like a bat out of hell when I put the coal to her. The weight is somewhere around 5.5 lbs but don't hold me to that as I really don't remember. It is 3 years old now and I've not needed to pull it apart for the last couple of years.
The retracts add greatly to the speed and the absents of the turtle deck makes people ask about what kit it is. I did add scoops for intake and exit openings to keep the EAC cool. There are just plastic spoons glued to the sides with holes under them. The decals were made using Testor's decal maker and images were pulled from the web.
Thanks for the kind words and yes, the grand daughter was/is very happy to have a plane of her own.
Ron
rfzl is offline
antione
02-07-2019 06:10 PM
raitheslacker
09-17-2012 08:13 PM
FMA Direct
07-17-2012 12:32 AM
Nitro Blast
02-12-2011 04:06 PM
Quick Reply: Sig Kougar Mark II
Page generated in 0.19778 seconds with 26 queries
