Show Your Scratchbuilt Foamie
Old 01-19-2015, 12:50 PM
  #101
Crashalott
Crashalott's Avatar
My new Infineon Bipe
Crashalott is offline
Old 01-27-2015, 03:52 PM
  #102
Crashalott
Crashalott's Avatar
Default Extra 300 Build Sorta
Here is the latest build of the Extra 300
Old 01-27-2015, 11:26 PM
  #103
riverrat
circa: 1946
riverrat's Avatar
Crash
MANNN! you sure are a prolific foam builder.
And great builds too!
Maybe one day I'll get the courage to try a foam build.
Been looking at the Ft-Viggen kit. I guess I should start with a
kit rather than a scratch build?
Regards
Jimmy
riverrat is offline
Old 01-27-2015, 11:46 PM
  #104
Originally Posted by riverrat View Post
Crash
Regards
Jimmy
Why pay another to cut foam for you ?
New sharp blade ... and away you go. Once you get that first done - you'll wonder why you ever hesitated !
Old 01-28-2015, 11:12 AM
  #105
Crashalott
Crashalott's Avatar
Crash
Regards
Jimmy
Heya Jimmy, get a simple plan for foam and build it.
The first one may or may not be to your liking but you will get better the more you build. If you need a link for plans let me know.
Crash
Old 01-28-2015, 11:14 AM
  #106
Crashalott
Crashalott's Avatar
Ditto
Crash
Old 01-28-2015, 03:16 PM
  #107
riverrat
circa: 1946
riverrat's Avatar
Crash & Mr. Luther
Thanks for the advice.
And due to your expertise,
I will take it under advisement.
riverrat is offline
Old 01-28-2015, 04:09 PM
  #108
Crash & Mr. Luther
Blimey MR LUTHER .... bit formal ?
Where'd you find that snippet from ?
No problem ... just not what I'm called usually !!!!
Old 01-28-2015, 05:23 PM
  #109
riverrat
circa: 1946
riverrat's Avatar
Mr Nigel
I knew that would get a rise out of a BRIT!
Yeah, that SNIPPET was from one your post a few days ago.
By the way we love the Brits!! (even thou)
Regards
Jimmy
riverrat is offline
Old 01-29-2015, 07:11 AM
  #110
Ronald86
Nice plane
Ronald86 is offline
Old 01-29-2015, 07:56 AM
  #111
Is that Depron? Or...?
Old 01-29-2015, 08:39 PM
  #112
Crashalott
Crashalott's Avatar
Originally Posted by Ronald86 View Post
Nice plane
Well thank you Ronald and it fly's very nice indeed.
Crash
Old 01-29-2015, 08:41 PM
  #113
Crashalott
Crashalott's Avatar
Not Depron, $Tree Foam(Adams) and sometimes called Rediboard.
Crash
Old 01-31-2015, 11:00 PM
  #114
riverrat
circa: 1946
riverrat's Avatar
Crash
Crash
Do you leave the paper on your $tree foam
when doing your builds?
Regards
Jimmy
riverrat is offline
Old 01-31-2015, 11:20 PM
  #115
Crashalott
Crashalott's Avatar
Crash
Do leave the paper on your $tree foam
Regards
Jimmy
Only when i do a FliteTest build, they leave the paper on for their designs.
Like the one im working on now(Spitfire) and the paper is left on.
I will post a picture when it is finished.
Crash
Old 01-31-2015, 11:53 PM
  #116
Crash
Thanks, Crash. I've been thinking about building one of those planes but wasn't sure if paperless Rediboard would cut it as a building material.
May I ask which version of the plans you're using? What you wingspan is? And what kind of reinforcement (spars, etc.) you're using?
Old 02-01-2015, 10:51 AM
  #117
Crashalott
Crashalott's Avatar
It is the Flite Test version, and here is a link to the build,plans,Video.
http://forum.flitetest.com/showthrea...spitfire+build
Hope this helps
Crash
Old 02-01-2015, 11:16 PM
  #118
riverrat
circa: 1946
riverrat's Avatar
Default $tree paper
Crash
You must have a quick method of removing
the paper, due to your many builds. Would
you care to share your method?
Regards
Jimmy
riverrat is offline
Old 02-02-2015, 10:50 PM
  #119
Crashalott
Crashalott's Avatar
Crash
Regards
Jimmy
Real easy, just stick your fingernail under the edge of the paper and start pulling it off. Of course it is easier if you have smaller pieces so you might want to cut out your patterns first them pull the paper off.
Have fun
Crash
Old 02-02-2015, 11:02 PM
  #120
Hope this helps
Crash
Oops, we got off track somewhere. I was talking about your 'new Infineon Bipe,' not your Spitfire. What foam you used for it, what wingspan, which plans, etc.
Old 02-03-2015, 12:56 PM
  #121
Crashalott
Crashalott's Avatar
Ok Mark, the Infineon is paper off and very light.
Dollar Tree Foam
Plans are by Mr.Flash on rcgroups.
http://www.rcgroups.com/forums/showthread.php?t=606425
Enjoy!
Crash
Old 02-03-2015, 04:23 PM
  #122
Michael763
Have fun
Crash
I also found that removing the paper after I cut the parts out is easier. I also found that the black papered dollar tree foam allows the paper to be removed easier than the white kind. I use spray adhesive to attach the plan templates to the foam, cut out the parts and then peel away the paper and templates.
Happy building
Michael763 is offline
Old 02-05-2015, 04:03 AM
  #123
Happy building
That's how I do all of mine. The 1/4" blue fanfold foam I use has a thin onionskin on one side, but I do the same thing there, gluing the plans to the onionskin and then peeling both off at build time.
Old 02-09-2015, 02:10 PM
  #124
Crashalott
Crashalott's Avatar
I use Scotch Glue Stick for attaching plans to foam, it peels back off easier.
Also no overspray to contend with in the house.
Crash
Old 02-10-2015, 08:17 PM
  #125
eflight-ray
eflight-ray's Avatar
Just some pictures of my Depron scratch builds -
(Been a while since I was on here )
ID:	179560   Click image for larger version
ID:	179561   Click image for larger version
ID:	179562   Click image for larger version
ID:	179563   Click image for larger version
ID:	179565   Click image for larger version
ID:	179566   Click image for larger version
eflight-ray is offline
Quick Reply: Show Your Scratchbuilt Foamie
Page generated in 0.16717 seconds with 22 queries
