Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > ParkFlyers
Old 02-09-2018, 02:44 AM   #1
F22trainer
Default House of Balsa Cub
Anyone tried these Schoolyard Series kits?
Picked one up really cheap on Fleabay...postage was more than kit - NIB was sealed from factory.
Will probably reduce dihedral and add ailerons as well as some struts for looks and function. Got olive drab Hangar 9 covering and do L4 finish.
Should be a quick build and will probably just do a few flights and sell, as I need to make some room for a bigger project
F22trainer is offline
Old 02-13-2018, 05:48 AM   #2
F22trainer
This is an unbelievably easy and well cut kit. I literally pinned 2 pieces down and everything fit snugly in place and stayed put. Drop CA at the joint and let dry. It took me about 20 minutes to do this wing panel. Easier to assemble and better fit than any puzzle!
Now I did have to lay out all of the pieces and ID a couple of pieces that had fallen out of the sheet and a few damaged small tab corners, but this is a real gem.
Old 02-13-2018, 02:13 PM   #3
View firemanbill's Gallery67
Club: Smoky Mountain Aero Club
Friends: (64)
Nice!
A friend of mine built one, it flies really well.
President - Smoky Mountain Aero Club, Sevierville Tennessee
Old 02-19-2018, 06:24 AM   #4
F22trainer
Default Wings ready for aileron mod:
See for your self!
Old 02-20-2018, 03:46 AM   #5
F22trainer
Default Clone?
Well this Cub is about the same size as my foam HZ, so I had a brainstorm - put the same electronics in it as the HZ version! Just go to the replacement parts tab on Horizon and get what I need!
Almost anyway, servos, linkages and motor / ESC are perfect fit. I will add the Eagle L3 for simple stabilizer as it shouldn't need the AS3X/SAFE variety. I already have a Spektrum receiver that should work nicely. Will also use same motor and mount, prop and hub for the HZ model.
Trying to decide whether to sheet the wing and fuselage with 1/32. Covering will be in colors along the lines as this one.
Old Today, 05:52 AM   #6
F22trainer
Default Foam Cub parts in a balsa version...
So I guess I have a new build technique - let the manufacturing geniuses work the problem and use he same equipment! Using the same linkages, servo, and engine from a PZ Cub
For Sale House of Balsa P51D kit RARE! 75.00 scalercflyer Airplanes - Electric For Sale & WTB 0 11-18-2017 03:11 AM
House of Balsa Super Decathlon Dave180 Sport Planes (Formerly I/C & Gas Conversion) 13 01-23-2014 12:02 AM
Build 2 House of Balsa AT6 Texan Micro Electric drummaker Scratch and Kit Built Aircraft 62 11-23-2013 11:31 PM
Sold SOLD Builders Lot of Balsa and Wood Merritt General RC items For Sale and WTB 0 02-18-2013 12:53 AM
Anyone have experience with House of Balsa? JimH Ca Beginners 4 05-24-2012 05:45 PM
Page generated in 0.07340 seconds with 39 queries
