Richmodel Yak 54 -40
Old 07-14-2008, 07:43 PM
AcC8braman
Default Richmodel Yak 54 -40
Hi All,
I have baught a Richmodel Yak 54 -40 and will be using an elec motor.
The destructions are a bit vague around attaching the motor mount.
I have included photo's of the motor attached, its pointing slighty up and to the right- is that right -or should it be point to the left and down?
Cheer
ID:	72625   Click image for larger version
AcC8braman is offline
Old 07-14-2008, 07:50 PM
Drewed
Plane in shop...vac......
Drewed's Avatar
Off the top of my head, you should want down and to the right. You want right thrust in the motor to overcome the torque from the spinning motor and down thrust to help prevent the ballooning (nose of the plane pops up) when power is applied during a flight. (Ballooning is not to be confused with porpoising which is when your planes nose pops up and then down continually during level flight. Porpoising is caused by a plane being tail heavy).
However I am unfamiliar with your specific plane, so it might be different.
Drewed is offline
Old 07-14-2008, 08:15 PM
AcC8braman
Nice, think you are right, down and right.
Its the biggest plane I will be flying so far, so need to makesure its spot on!!
CrashJunkie1980
3D Flying
01-18-2008 03:38 PM
ARTP47
ParkFlyers
07-24-2007 04:26 AM
admin
02-28-2006 03:21 AM
3dfoamworks
Foamies
9
02-04-2006 01:34 AM
Harleyflyer
Foamies
09-07-2005 03:19 AM
Quick Reply: Richmodel Yak 54 -40
Page generated in 0.10123 seconds with 16 queries
