Converting PZ Spitfire to brushless
Old 08-25-2008, 08:26 PM
  #226
joeted
Originally Posted by groundrushesup View Post
Here's an illustration. It's a slow day at work lol
In your case it looks like #3, the backplate, is that flat washer.
Here's an idea of how to mount the stock spinner until you get a new one. Ream out the hole in the bottom part, of course.
Hope this helps.
Thats brilliant help mate thanks very much for that.
1 more silly question tho lol
By looking at mine do you know what my radial mount is or have I not got 1 ?
P.s Ive just noticed my name on the motor LOL Excellent work love it
joeted is offline
Old 08-25-2008, 09:47 PM
  #227
groundrushesup
groundrushesup's Avatar
yeah, your radial mount is already on, its the thing that attached to the motor housing with the hex screws.
groundrushesup is offline
Old 08-25-2008, 10:30 PM
  #228
joeted
brilliant thanks buddy. ive just plugged it all in and gave the motor a little run for the first time ,dont it just sound gorgeous .the power on this thing is amazing .it lifted off the table a bit and i havnt even got a prop on lol.
and that was noway near full throttle.
joeted is offline
Old 08-25-2008, 11:24 PM
  #229
radweld
radweld's Avatar
Hope this helps.
Wow, great drawings there. You must have had a real slow day lol.
radweld is offline
Old 08-25-2008, 11:30 PM
  #230
radweld
radweld's Avatar
I'm running the 1100KV version of this motor in my X-Ray, I personally prefer slower motors that can turn larger props. If nothing else, they are quieter lol.
radweld is offline
Old 08-26-2008, 12:17 AM
  #231
groundrushesup
Yeah, its been a killer. And the drawings are basically what I do, so why not.
Anticipating the question, here's a third
Old 08-26-2008, 12:38 AM
  #232
DetroitHawk
Super Awesome
DetroitHawk's Avatar
I would suggest when you launch this plane to have someone else throw it at first, launch @ WOT and hive them throw it up on a 45 degree. You have the 'i don't have to worry about stall' card so you might as well use it.
Get the plane up in the air and trim it out before you attempt to hand launch it yourself. If you look at my spitfire maiden video it takes me quite a while to dial it in. Give it a good firm toss, the plane will want to torque roll a little at first but it will pull out of it rather quickly once you gain airspeed.
DetroitHawk is offline
Old 08-26-2008, 09:05 PM
  #233
joeted
Thanks for the extra pic buddy, they are brilliant pics and a massive help
joeted is offline
Old 08-26-2008, 09:16 PM
  #234
joeted
Ok mate thanks I'll make sure I follow them instructions.
Theres a possible little issue,when I lay the plane on its belly on a table it rolls onto its left wing (as im facing the plane), due to the fact that the belly is curved i suppose its got to roll one way but even when i lean the plane on its right wing it still rolls over onto the left wing.will this effect the flight ? its strange coz i think theres more weight on the right side coz thats where the larger reciever is and the little 2nd reciever is on the left side with the servo ( which i suppose weighs a bit). if i lay it on its belly on the carpet it doesnt seem to do it as much.
joeted is offline
Old 08-27-2008, 01:42 AM
  #235
DetroitHawk
Super Awesome
My plane also does the very same thing, just as long as you make sure there isn't anything obviously wrong. remember A nose heavy plane might be hard to control, but a tail heavy plane you don't have to worry about; that usally it ends in a crash.
Old 08-27-2008, 09:53 PM
  #236
joeted
Ok Im all set apart from the spinner,prop and charger which im waiting to be delivered.Oh I need the cf tubing too but 1 more thing about the centre of gravity,in the spit manual it says 70mm with a 11.1v lipo from leading edge of wing (I take it thats from the edge opposite the ailerons) but it doesnt say how many mm from the end of the wing or if u like from the fuselage ? or is it just 70mm from the leading edge and it doesnt matter about the distance from the end of wing or fuselage ?
joeted is offline
Old 08-28-2008, 06:29 AM
  #237
groundrushesup
Take the measurement from the LE as close as you can get to the fuselage.
Old 08-28-2008, 06:31 AM
  #238
groundrushesup
Talking Maiden Video
Alright, here is my official maiden... (this was a replacement airframe and never flew with stock kit) after a few shakedown flights everything seems to be working great - besides a slight pitch-up at WOT as predicted by Aetc4Boom, it flies great. And fast enough for me.
Old 08-28-2008, 02:45 PM
  #239
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
Wow, she's fast!
Old 08-28-2008, 05:50 PM
  #240
AETCBoom4
Awesome job!!! Here are pics to help the WOT pitch up you mentioned. Just shim it between the fuselage and wing at the mount holes. (Pic is from my former P-51, but principle is the same).
ID:	76623   Click image for larger version
AETCBoom4 is offline
Old 08-28-2008, 06:32 PM
  #241
drewpyfz6
Trainee Ground Teaser
drewpyfz6's Avatar
Can I please ask, what does "WOT" stand for?
drewpyfz6 is offline
Old 08-28-2008, 06:39 PM
  #242
radweld
radweld's Avatar
Wide Open Throttle
or max power
radweld is offline
Old 08-28-2008, 06:40 PM
  #243
drewpyfz6
drewpyfz6's Avatar
Wide Open Throttle
or max power
Thanks radweld -
Old 08-28-2008, 07:37 PM
  #244
joeted
Houston we have a problem !!
Look at how far my spinner is infront of the cowl, does this mean i need to make a new motor mount ?
ID:	76625   Click image for larger version
joeted is offline
Old 08-28-2008, 08:22 PM
  #245
groundrushesup
if you cant adjust it back any more, then yeah, thats a problem. And I'm closer to San Antonio.
Old 08-28-2008, 09:08 PM
  #246
joeted
lol , san antonio we definately have a problem then,i cant adjust it back anymore,i'll look around for a smaller mount but if not then its to the work bench and saws for me
joeted is offline
Old 08-28-2008, 09:51 PM
  #247
radweld
radweld's Avatar
Turn the outer part of the mount around, you can the get it to sit back enough. I was worried about this problem as well which is why I chose the components I chose, so that they would fit right. Or you can turn the motor around, move the center shaft so it sticks out the front and use a collect type pop adapter either option should work ok. Don't forget to balance it, I would be interested to see where it balances as is and how much weight you need to add to the back to get i to balance at 60mm
radweld is offline
Old 08-28-2008, 10:14 PM
  #248
groundrushesup
Originally Posted by Lieutenant Loughead View Post
Wow, she's fast!
Yeah, she is a rocket. I flew this right after my styro chuck glider project which is considerably more tame, ad I had never run it wide open like I did here, so it was a handful and a blast all in one.
Old 08-28-2008, 10:18 PM
  #249
groundrushesup
Thanks radweld -
Sorry about the jargon.
Old 08-28-2008, 10:20 PM
  #250
groundrushesup
Wide Open Throttle
or max power
Max Power, AKA Homer Simpson
Quick Reply: Converting PZ Spitfire to brushless
Page generated in 0.11916 seconds with 15 queries
