Standard & Large E-Heli Talk Discuss all standard and large sized electric rc helicopters in here
copterX + scorpion = not so good
Old 08-10-2008, 03:28 PM
MaxAdventure
AMA 198798
MaxAdventure's Avatar
Default copterX + scorpion = not so good
I wanted to report that running the Scorpion HK-2221-6 in a copterX may leave you disappointed.
oh, not from performance! The thing really does zip around like a mad hornet, however I went aluminum frame thinking it would last longer than carbon for me, and um, no.
Last time I was flying, I saw something small fall out of the canopy on a low pass, was totally flyable but I slowed down worried I lost a screw and something else flew out, so now I'm thinking I should be crashing if I'm losing bits, but it's still flying great. So I bring it down to check it out. The upper frame cracked by the motor mount on both sides. I'm actually missing about 1/2" of frame on one side. Crazy. I'm guessing the torque of the Scorpion is too much for the frame, or I'm playing in normal mode too much, or both.
I figured I'd be replacing parts with align as I went, I just didn't expect to replace the frame so soon, with no crashing!
I'm guessing with a more mild motor, not such a big deal.
MaxAdventure is offline
Old 12-04-2008, 05:00 AM
ehirobo.com
ehirobo.com is offline
Old 12-31-2008, 03:49 PM
MaxAdventure
AMA 198798
I wanted to come back and say that with the align top frames and a new 10t pinion (thanks for the help locating!) the combo is working well!
Old 01-13-2009, 04:30 AM
ministeve2003
Class Clown
ministeve2003's Avatar
any Idea what Pinion Your using?
I tryed the hobbycity turnigy 450 heli motor, but it was too powerful for my copterx on stock pinion... It was pulling 45amps.... and the gyro and tail servo couldn't keep up...
SK
ministeve2003 is offline
Old 01-15-2009, 05:02 PM
MaxAdventure
AMA 198798
I'm currently running this 10 tooth: http://www.helidirect.com/product_in...oducts_id=7266
(I posted 9t by mistake above)
My Setup:
Scorpion HK 2221-6 w/10T Pinion
align 335mm wood blades
CC Phoenix45
Hitec HG-5000 gyro w/Hitec HSG 5083MG tail servo
stock tail blades
40.4Amp peak w/ Zippy 2200 20C-30C (silver)
6min flights, no issues with the tail holding
Old 01-15-2009, 08:15 PM
ministeve2003
Class Clown
I tryed the hobbycity turnigy 450 heli motor, but It had too much headspeed and the 401 gyro/ 9257 tail servo couldn't keep up... It was 46amp peak, but that was with the stock pinion... I was going to lower it... but I put the stock stuff back, and sold my copterx to upgrade to a trex 500... I wanted something a little bigger...
SK
Old 02-05-2009, 05:10 PM
Crash9
www.FPVpilot.com
Crash9's Avatar
I have a CopterX and the HK-450, IMO the problem I see is the aluminum is weaker then Aligns frame. with an Align frame in my hand I can barely bend it, and the CopterX is easy to bend. The HK , CopterX and other Trex clones use a cheaper aluminum to save cost and looks a bit thinner.
ID:	92647   Click image for larger version
Crash9 is offline
Old 02-05-2009, 05:18 PM
ministeve2003
Class Clown
my CopterX SE V2, before I sold it... came with carbon fiber frames... I purchased it from ehirobo.com and the only gripe I had was the belt pulley wasn't on streight it wobbled a little, so I replaced it with a genuine Align One
SK
Ramovan
455
07-22-2012 03:46 AM
EpoweredRc
15
08-30-2008 03:54 AM
General RC E-Heli Talk
23
06-12-2008 02:49 PM
Quick Reply: copterX + scorpion = not so good
Page generated in 0.11417 seconds with 16 queries
