is this battery good????
Old 01-16-2009, 02:10 AM
swedendude
Talking is this battery good????
hi i was just wondering if i bought a 9 cell 2000 mah nimh 4/5a battery pack will it be good for use with a 32 amp esc and 400 mttor or will it fry them??oh and it will also power four servos. thanks!!!!
swedendude is offline
Old 01-16-2009, 02:21 AM
Bub Steve
Bub Steve's Avatar
Your good to go, That'll work just fine, hope this helped ,Bub Steve
Bub Steve is offline
Old 01-16-2009, 02:24 AM
swedendude
thanks ill have my trainer up in runnin in no time with all your guys help!!! thanks!!!!!!!
Old 01-16-2009, 02:35 AM
Bub Steve
Bub Steve's Avatar
Don't forget to post some pixs! your bub, steve
Old 01-16-2009, 02:43 AM
swedendude
i wont forget i just dont have anything installed yet! thanks
Old 01-16-2009, 02:46 AM
Bub Steve
Bub Steve's Avatar
You just holler if you need help, you can PM me anytime or just post here, You'll have her up in no timebub, stev
Old 01-16-2009, 02:47 AM
swedendude
ok thanks for your help i just posted a nother thread for what is auto cell detect?
thanks
Old 01-16-2009, 02:49 AM
Bub Steve
Bub Steve's Avatar
thanks
My Bub TWMaster got you covered!! he's a good Bub, steve
Old 01-16-2009, 03:00 AM
swedendude
oh one more thing on the 30 amp welgard esc the manual says if the battery is 7.4 voltsor less you can use 4 servos but if it is 11.1 volts it says only three servos so should a stick with a 9 cell battery pack or should i go lower to around 7.4 volts??i havent bought the battery yet and i will have 4 sg-90 servos. thanks
Old 01-16-2009, 03:08 AM
Bub Steve
Bub Steve's Avatar
swedenBub:as long as your use'in 9 or 5 gram servos you should be fine, If I remember right thats what you've got, your bub, steve
Old 01-16-2009, 03:14 AM
swedendude
thanks so if i run the 4 servos at 3 amps i should be fine with using a 9 cell nimh pack?just making sure
Old 01-16-2009, 03:15 AM
Bub Steve
Bub Steve's Avatar
If your still worried I use these on some planes, UBEC will power the servos instead of the ESC, bub, steve
HXT UBEC 5/6v output, 5.5~23v Input
hexTronik UBEC.
Will supply a solid 5v or 6v to your reciever with a 2 to 5S Lipoly pack.
Specifications;
Output: 5v/3a & 6v/3a (Selectable via jumper)
Ripply: <50mVp-p(@2A/12V)
Input: 5.5v~23v (2 to 5s)
Weight: 12.5g
UBECs are used by connecting the input wires to the battery and the output to the receiver. This allows your Speed Controller to run cooler, and safer as you now have an external circuit to power your receiver. Should the Speed Controller be overloaded and fail, you still have control of your plane.
25g 496
$6.95
swedendude
i think 3 amps is around 6 volts? maybe not sure
thanks
Old 01-16-2009, 03:17 AM
swedendude
in your opinion are they really nessary for me to get a ubec or should i be just fine with out one?
Old 01-16-2009, 03:18 AM
Bub Steve
Bub Steve's Avatar
thanks
Don't work that way, theirs a Big Difference, It'll work fine without one , bub, steve
Old 01-16-2009, 03:21 AM
swedendude
thanks i think that pretty much sums it up ill buy a 9 cell 4/5a nimh pack 30 amps bec and a 400 brushless outrunner motor for my trianer plane.
thanks for all your help!!!!
Old 01-16-2009, 03:25 AM
Bub Steve
Bub Steve's Avatar
Don't forget to update us as you get her together, I hope she a PIP! bub, steve
Old 01-16-2009, 03:30 AM
swedendude
whats a pip im sorry i not familiar with the shortened words yet
Old 01-16-2009, 03:31 AM
Bub Steve
Bub Steve's Avatar
Pip is a good Bub, or a nice guy or just a good thing!! bub, steve
Old 01-16-2009, 03:33 AM
swedendude
thanks the reason why im asking is my cats name is pip! lol guess thats a good thing!!
park_flyer
Batteries & Chargers
05-28-2008 12:43 AM
floridawen
28
04-14-2008 01:13 PM
gditeam
Delta & Flying Wings
07-05-2007 07:33 AM
cyclops2
10-17-2006 03:27 AM
Heidelberg Germany Flyer
02-05-2006 05:13 PM
Quick Reply: is this battery good????
Page generated in 0.13433 seconds with 12 queries
