Motor Cuts Out
Old 04-12-2020, 04:50 AM
rc727737
Exclamation Motor Cuts Out
Hi guys. Iíve been out of RC stuff for a few years now and just decided to start up again.
I have a Spektrum DX6i transmitter. I have a couple of Specktrum receivers that had previously been bound to certain models from a few years ago. Anyway, I have a couple of motors I wanted to hookup to see if they run.
I hooked up one motor, and when I advanced the throttle on the DX6i, the motor ran but cuts out and cuts out altogether at any point where throttle advancement is stopped. I tried my other motor and it did the same thing. So I tried different escís, different batteries, and different receivers all with the same results. That would lead me to believe that itís the transmitter itself.
Is there anything I may have missed or does anybody have any other ideas? Thanks!
Rick
rc727737 is offline
Old 04-12-2020, 09:11 AM
rc727737
From the tests you have done it certainly sounds like the Tx is at fault. I would also use a servo tester to run the ESC and motor just to be sure they worked.
Then use the DX6i "monitor" function. This display shows what signal the DX6i thinks it is sending on each channel. If the throttle display bar is not travelling smoothly in line with the stick movement then it is most likely the stick variable resistance 'pot' has failed. Not simple to fix as it is completely built in. You may be able to find a complete stick module which is fairly easy to replace.
I have this problem but it is on the rudder pot so that DX6i is relegated to flying simple "bank and yank" planes!
quorneng is offline
Old 04-12-2020, 08:26 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Connect a servo to the throttle channel and see what it does when you advance throttle.
ron_van_sommeren is offline
Old 04-12-2020, 08:56 PM
RideTheLightning
Be sure the end points for the throttle channel are set at 100%. I’ve seen ESCs act weird when the input signal is not at the full range.
RideTheLightning is offline
Old 04-13-2020, 05:30 PM
Past President of PSSF
Plug you ESC into a different channel and see how that acts.
Use the elevator channel but PLEASE fasten a rubber band to hold the stick down as if it is the throttle stick.
Then do your test.
Wildflyer is offline
Old 04-14-2020, 12:15 AM
rc727737
It moves erratically.
rc727737 is offline
Old 04-14-2020, 12:17 AM
rc727737
When I connect a servo to the throttle channel and advance the throttle, the servo moves erratically.
rc727737 is offline
Old 04-14-2020, 12:20 AM
rc727737
Throttle end points are set at 100%.
rc727737 is offline
Old 04-15-2020, 02:03 AM
skyhawk940
remove the back of the transmitter and spray contact (electronic cleaner) into the stick pots. Had the same problem with my DX6I. Worked like a charm. I will clean mine every year now. The pots are of open design and get dirty. Don't worry about the spray, it won't hurt anything if it gets on it.
skyhawk940 is offline
Old 04-15-2020, 04:17 AM
rc727737
Thanks, I’ll give that a try!
rc727737 is offline
Old 04-15-2020, 03:40 PM
ron_van_sommeren
And do you get full throw, the throw you would expect?
Old 04-15-2020, 05:04 PM
rc727737
Yes, I get full throw.
rc727737 is offline
Old 04-15-2020, 05:52 PM
I am pretty sure an ESC will not respond to an instant signal cut out as a servo would.
The ESC will react instantly to an signal interrupt and cut out. When the signal returns at more than the minimum throttle level the ESC will not respond as a safety feature. An ESC will only 'arm' at a minimum throttle setting
Cleaning the suspect pot to ensure it makes continuous contact is the only answer.
quorneng is offline
Old 04-20-2020, 02:33 AM
rc727737
Ended up taking the back of the transmitter off, blowing on the throttle pot, and brushing it with a very fine haired paint brush. Works great now!
rc727737 is offline
Old 04-20-2020, 02:32 PM
skyhawk940
Do that at the beginning of every season. Mine took out a plane two years ago.
Page generated in 0.08547 seconds with 11 queries
