Sig kadet senior problem
Old 09-16-2020, 05:59 AM
amstrong32
Default Sig kadet senior problem
Hello I have a problem with the tailwheel of my kadet senior sport. The stock tailwheel was not working because it bended with the weight of the model and tended to turn only to one side. So I replaced the tailwheel for a ohio superstar that is linked to the rudder music wire using a custom two arm linkage and springs. The fact is the rudder now works fine when taking off, the tailwheel turns great on the ground but the taxi difficult because the plane turns right or left fine if it is not a tight turn but it is impossible for me to make it turn continuously, so I cant turn the plane 180 degrees for example. The plane starts turning but gets straight after a second although I am keeping the rudder turning.
How can Isolve this?
Also the plane tends to balloon heavily when I apply more than 1/2 throttle, this is with trim fully down. Is this normal? I am using a saito 82 for power.
Regards.
amstrong32 is offline
Old 09-16-2020, 04:56 PM
Past President of PSSF
I had trouble when I tried to use a tail wheel setup with springs, I took the springs out and it works fine, but you need a rugged servo on it. Some guys I know use one servo for the rudder and one for the tail wheel. That way if rough ground damages the tail wheel servo, the rudder servo is still just fine.
The ballooning with power means you need down thrust. Some planes need quite a bit.
Wildflyer is offline
guapoman2000
02-17-2017 07:59 PM
guapoman2000
26
03-07-2016 08:05 PM
dheaton
13
05-06-2014 05:27 AM
hanick
10
02-16-2014 04:56 AM
brutus
05-06-2012 11:58 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Quick Reply: Sig kadet senior problem
Page generated in 0.08771 seconds with 9 queries
