li-poly li-ion ?
Old 05-14-2007, 06:31 PM
raad
Default li-poly li-ion ?
al salam alaikum ,,
hello i need help with a charger issue, does the Esky li-poly battery charger charge lithium polymer batteries ? it says li-ion on the back ,, i wont want to end up with a bad(ruined) battery ,,, please help out ..i have 3E 3 cell 1800 mah 12c battery ,, the esky model number is (EK2-0851)does that model do balanced charging ?
Thank you
raad is offline
Old 05-14-2007, 09:56 PM
redgiki
redgiki's Avatar
Lithium Ion batteries and Lithium Ion Polymer batteries are nearly identical. The chemistry is slightly different due to our very high discharge rates. The net effect of this is that a Lithium Ion charge on a modern 20C Lithium Polymer battery will often only charge it 90-95% of capacity, to a resting voltage of 4.13-4.20v/cell. LiPo chemistry is usually 4.235v/cell @ 100% charge.
Basically, it will get you close enough. When planning discharge on your battery, though, plan on only a 75% discharge maximum to be on the safe side.
Note: This varies by charger, too, and I do not have direct knowledge of the Esky charger. But if it's a "Li-Ion" charger, it will charge Lipos just fine, just be aware it may not be a 100% charge.
redgiki is offline
Old 05-14-2007, 11:16 PM
markind
Hmm, you made me go in for a closer look.
My E-Sky charger is EC103A and it says "Li-Ion Polymer"
Its been doing a good job though - seems to give full charge on my TP 1320 packs and they read 12.6V when done.
~m
markind is offline
Old 05-15-2007, 12:17 AM
raad
thank you for your reply , i appreciate your help .. glad i got something right at last
Raad
raad is offline
Old 05-15-2007, 11:12 PM
ryanmo
~m
..........hmm "seem" the word seem is a relative term. Your seemingly full charge might be even 'fuller' with a lipo charger
ryanmo is offline
Old 05-15-2007, 11:47 PM
raad
so? it would over charge ?and not balance ?
raad is offline
Old 05-16-2007, 01:11 AM
ryanmo
no it would not overcharge, if you have a lipo charger your battery will have slightly longer flight times.
ryanmo is offline
SlapShot
06-30-2008 04:17 PM
mtuhoop24
Batteries & Chargers
31
12-28-2007 05:31 PM
cyclops2
03-19-2007 04:34 AM
zerts
07-21-2006 02:17 PM
JWN
10
09-26-2005 06:18 PM
Quick Reply: li-poly li-ion ?
Page generated in 0.06824 seconds with 13 queries
