Appropriate ballast for balancing plane?
Old 10-05-2008, 04:41 AM
Desolas
Default Appropriate ballast for balancing plane?
Been searching for this answer for a bit and am curious what is considered the "correct" ballast for balancing a foam flier, or really any models when balancing down the centerline.
I have been using 7g lead weight (1/4 oz stick on wheel weight) that are left over from other projects and seem to work fine. It works just fine, and I shrink wrap them in black so they look alright .... but if there is a cleaner solution I am open to learning something new.
What do you guys use?
Desolas is offline
Old 10-05-2008, 04:47 AM
gfdengine204
gfdengine204's Avatar
I have used lead weight strips used for golf clubs. Each strip is 1oz, and has sticky tape on the back. They also bend some, so they can be formed to a degree to fit curves and all.
I found mine on clearance at Walmart in the sporting good section after the golf season was over for my area.
Welcome to Wattflyer, Desolas!
gfdengine204 is offline
Old 10-05-2008, 07:43 AM
jonnyjetprop
I've used spare change, nuts, screws, washers, and lead sold in hobby shops all with good effect.
John
jonnyjetprop is offline
Old 10-05-2008, 11:00 AM
rocket_jim
Fly Long and Land Softly
rocket_jim's Avatar
I'm rather fond of depleted uranium, but sometimes it's a bit tough to find at retail.
Just kidding! Anything heavy works just fine.
Jim
rocket_jim is offline
Old 10-05-2008, 11:27 AM
Fishing weights work great, and mag type wheel weights with the glue on them, washers, work fine too, Take care, Chellie
Firestem4
06-30-2008 06:44 AM
jnastasi
06-27-2008 07:22 AM
Low-Q
3D Flying
9
02-19-2008 12:56 PM
Army Dad
09-30-2007 10:37 PM
ictbu
06-10-2006 03:10 PM
Quick Reply: Appropriate ballast for balancing plane?
Page generated in 0.12530 seconds with 9 queries
