Pretty in Pink
Old 01-04-2009, 02:08 AM
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
Talking Pretty in Pink
I heard that there was a WattFlyer here that liked pink aircraft...
FlyWheel is offline
Old 01-04-2009, 03:00 AM
gfdengine204
gfdengine204's Avatar
Oh my.....that's a Miss.....isn't it?
(You didn't mean ME, didja? LOL)
gfdengine204 is offline
Old 01-04-2009, 03:02 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
Pink or not, that bird looks SHARP!! Nice work, Fly!
xuzme720 is offline
Old 01-04-2009, 03:09 AM
That actually does look pretty nice. Nice plane.
Old 01-04-2009, 04:41 AM
Airhead
Redneck Member
Airhead's Avatar
Good job Flywheel.... Chellie would really like that.
Airhead is offline
Old 01-04-2009, 04:54 AM
Thats a Cute Airplane I Love it But i want to make a pink one like this
Old 01-04-2009, 04:59 AM
Airhead
Redneck Member
Airhead's Avatar
Hey Chellie,
Is that your newest plane?
Airhead is offline
Old 01-04-2009, 05:20 AM
Originally Posted by Airhead View Post
Hey Chellie,
Hi Bruce I am going to be making a foam biplane like that one, with a 6ft wing span, it will have swept back wings on top and bottom like the ultimate, but it will have a longer Fuselage than the Eagle or Ultimate biplane, wish me luck Chellie
Old 01-04-2009, 05:30 AM
Airhead
Redneck Member
Airhead's Avatar
I sure do wish you luck Chellie.
however, you are just a skilled builder and flyer. It will go real good for you.. Can't wait to follow yur build.. Take care..
Airhead is offline
Old 01-04-2009, 05:33 AM
Thank you Bruce for your Vote of Confidence in me I have been thinking of different ways of building it, I normally build a plane in my head First, then I build it, I have a lot of room in my head Take care, Chellie
Old 01-04-2009, 05:38 AM
Airhead
Redneck Member
Airhead's Avatar
A lot of room in your head......
You are tooooo Funny...
Airhead is offline
Old 01-04-2009, 09:19 PM
starcad
Model Designer
starcad's Avatar
Very nice build and covering.
starcad is offline
Old 01-04-2009, 09:33 PM
starcad
Model Designer
starcad's Avatar
You can do it Chellie. I think my next one will be a PT-19 and like you I design it in my head first. I have the wing designed and am working out how I want the fuse. Sorry it won't be pink in color though.
starcad is offline
Old 01-04-2009, 11:11 PM
Boy, that's a plane for the nitro guys to talk about.....
Seriously, looks good!
Old 01-04-2009, 11:19 PM
xuzme720
c'mere Monkey
xuzme720's Avatar
Am I wrong or is Stewie as the pilot?
xuzme720 is offline
Old 01-04-2009, 11:27 PM
Bill G
Super Contrubutor
Bill G's Avatar
6 feet. That's a LOT of foam.
Like to see this build.
On the pink planes, there's a pink GWS transmitter that would go with them real well.
Bill G is offline
Old 01-04-2009, 11:33 PM
some pink trim would look nice
Yes thats a nice Nitro plane, all $189.00 worth, and you have to build it from a kit but after its done, you will have a very nice plane they dont give that plane away Take care, Chellie
Hi Xuzme Not sure who the pilot is I just found the pic on the web Take care, Chellie
Old 01-04-2009, 11:40 PM
FlyWheel
FlyWheel's Avatar
Yes, it's a Miss, and no, I didn't mean you specifically (unless you do like pink, of course. Nothing wrong with that).
However, it is not mine. That one will be a transparent violet or purple. I found out that UltraCote offers both now. I found this bird on a information gathering search I was doing on the Miss Stik, it was put up by the owner's husband, I think.
Which reminds me I need to ask about the difference between the two colors. Which one is darker, mostly.
FlyWheel is offline
Old 01-04-2009, 11:52 PM
yes it going to take a lot of Foam OK , the hardest part will be to make sure the wings does not flex, as it will have a flat 9mm wing, being a biwing will help alot, and using 8.5mm carbon fiber square tube will help too, I am also going to use 3/8" formed balsa on the leading edge to help to make the wing more ridged, and 3/8" balsa or basswood on the trailing edge, the wing will be squared off, with a wood frame, and the round foam part of the wing tip will be epoxied on, i belive the wood frame and the cf tube and the wings being tied together will make it strong and minimize wing flexing, in the middle of the wing, i will use a flat thin plywood 1/8" x 4" wide on top and bottom to hold the wing in the middle, the fuselage will be 6mm depron build up, the nose and front of the plane will have plywood inside the foam for strength and to mount the landing gear too, I think i have most of the bugs worked out I have Researched a lot of Foam builds to incorporate technics found on other builds to be used in my 6ft w/s plane, wish me luck, Chellie
gfdengine204
I believe Violet is the darker of the two on the color spectrum. The next "darker" to violet is ultraviolet.
Old 01-05-2009, 01:17 AM
FlyWheel
FlyWheel's Avatar
Wink
Thanks, but I was referring to the UltraCote colors, silly
Violet - Purple
All the online sources show them rolled up, which is the worstest possible way to display a transparent covering IMO. From what I do see the purple "looks" a little closer to what I'm going for, a "Wizard's Purple".
(Miss Stik = Mystic, get it?) Think "Albus Dumbledore" from Harry Potter.
I would really like to see what they look like with light shining through them. I have seen the violet on another thread, but not the purple.
FlyWheel is offline
Old 01-05-2009, 01:21 AM
gfdengine204
LOL I was being serious....but I AM a jester, after all.....
And I like the way you think about it. Albus would be proud. Snape would sulk, but who cares......and as for He-Who-Shall-Not-Be-Named, well......
Old 01-07-2009, 12:54 AM
proffcharlie
Chellie, I can't tell for sure, is that a Skybolt or a Sportster Bipe? It is a pretty plane but I think it would be better if the color pattern was reversed. I'll also be looking for your built thread.
Charlie
proffcharlie is offline
Old 01-07-2009, 03:26 AM
Charlie
Hi Charlie Hope your Holidays were nice, my foam and CF tube, came in the mail today, and my props and lipo came in yesterday, Soooo I am ready to start soon it should be fun, I am waiting for some leading edge balsa, spruce and plywood to get here, it should be a fun, BIG build, Take care, Chellie
Old 01-08-2009, 04:36 PM
Dereck
You want how much pink?
The Sweet'n'Low-ish Stik started out as a BARF StiKlone from China's "RC Ploduct Industlie" and flew c#@& - so I made a few alterations to it Covering's Monokote, the logo was upscaled from wifey's fave coffee/tea sweetener with a scanner, DesignCAD, some imagination and a large class of wine...
"Bubbles" was my first tailless design. The wing came out of my 'Li'l Special' design, it lost its original job in a pylon race when some idiot had a hard time with the concept of 'straight and level', sawing her tailplane off. The wing was the sole survivor and found a new job in this design. Three of this design were built in total by me, though other variants appeared, including an 81" twin! RCM still sell the US plan, BTW...
If all pink rocks the soul overly, Solarfilm's 'Heather' (pink, in marketingspeak!) and whatever they call purple go very well, and MoneyKote's versions also fit well together.
Though 'Cow-Moo-Flage' in P & P is a little hard on the eyes at times
But always remember that, when following the herd, the view never changes
Regards
Dereck
ID:	89654   Click image for larger version
ID:	89655   Click image for larger version
ID:	89656   Click image for larger version
Dereck is offline
J Reed
Foamies
36
02-15-2013 08:17 PM
gfdengine204
Humor
22
06-04-2008 03:21 PM
cranet561
12-09-2007 03:03 AM
ericthetree
Delta & Flying Wings
08-25-2006 04:32 PM
skiman762
Foamies
19
05-28-2006 12:37 AM
Quick Reply: Pretty in Pink
Page generated in 0.14751 seconds with 19 queries
