Motors and Speed Controllers for sale & WTB List your brushless or brushed motors and speed controllers for sale in here
ew Lensrc 25t spindle mount outrunner brushless and CC Thunderbird esc.
Old 08-25-2005, 01:04 AM
1987tc
Guest
Posts: n/a
Default ew Lensrc 25t spindle mount outrunner brushless and CC Thunderbird esc.
Motor and esc are brand new. I only soldered them together ( it spins correctly for normal prop)
Includes prop saver/adapter and micro deans on battery end of esc.
Both bought new. Only powered up to check direction motor spins.
Motor has new vented bell.
I used the same set up in a Mountain Models Dandy Sport and it was PLENTY of power for it
$95.00 for Motor, ESC, Prop adapter/saver and tube mount.
Also included is a new 8040hd prop.
Shipped free in 48 states . Paypal only
Below are the specs:
The Spindle Mount 25 Turn motor runs great with the GWS 8x4 Direct Drive prop and 3 cell Li Poly battery.
rpm per volt : 1100
Weight :23 Grams
THUNDERBIRD-18
Brushless Controller
Castle Thunderbird controllers feature automatic lipo detect cutoff right from the package! Just plug in and and fly your lipos safely with no programming needed (or change the setting to fly NiCad/NiMH)!
SPECIFICATIONS
Cells w/BEC - 2s, 3s Lipo or 5-12 NiMH/Nicad
Continuous -18 amps
Switching Rate - 13 khz
Brake - on/off
Reversible - yes
Low Voltage Cut-off - auto lipo or nimh/nicad
Size - 1.32x.33x.90
Weight .6 oz (17g)
Castle Creations speed controls features:
Safe "Power On"
Low torque "Soft Start": protects gear boxes and belt drives from shock
Simple setup: no complicated switches or wiring
surface mount construction
Smooth reverse exponential throttle
Audible Arming Signal
Self-calibrating endpoints: maximizes usable stick travel
Auto Motor cut-off with reset
Auto shut-down when signal is lost
Microprocessor Controlled
toy4x4
03-11-2008 03:39 PM
1987tc
01-04-2006 09:20 PM
1987tc
12-18-2005 02:13 AM
1987tc
10-15-2005 10:05 PM
1987tc
10-08-2005 11:41 PM
Quick Reply: ew Lensrc 25t spindle mount outrunner brushless and CC Thunderbird esc.
Page generated in 0.12122 seconds with 15 queries
