Charging Lipos...
Old 08-10-2007, 05:34 PM
Tinman
The Hot dog man
Tinman's Avatar
Default Charging Lipos...
I'm charging two lipos for a couple flights tomorrow morning.
Do you usually charge them the night before and then hit them with the charger right before you fly? Is that necessary and does it hurt the battery if you do that? ??
thanks
Tinman is offline
Old 08-10-2007, 05:45 PM
adamdb
Every Lipo tutorial I have ever seen says DO NOT top them off. The self-discharge rate is so low on lipos that they will lose very little overnight. Even over the course of a month or two they won't discharge enough to need topping off.
adamdb is offline
Old 08-10-2007, 06:14 PM
Gnascher
Got My TX - Need 2 Fly!
Gnascher's Avatar
What adamdb said is true.
Maidening that SD?
Gnascher is offline
Old 08-10-2007, 06:25 PM
Tinman
The Hot dog man
Tinman's Avatar
Thanks adam, thats what I thought, just wanted to make sure.
G, yep tomarrow is the day. Got everything tripple checked. I'm going to try to fly it with a 2150 Lipo. Fits in there really well and the CG is right on. I'll let you know how it goes, I'll try to get some pics.
Tinman is offline
Old 08-10-2007, 06:32 PM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Good luck with the maiden Brian. You'll do great.
Grasshopper is offline
Old 08-10-2007, 06:35 PM
Tinman
The Hot dog man
Tinman's Avatar
Thanks Tom, after flying your gravity defying Mustang a few times, I think I got this one in the bag
Tinman is offline
Old 08-10-2007, 06:41 PM
Lip84
Lip84's Avatar
I have always heard/read that the best battery care is to charge them full in one go and drain them all the way down in one go as well. IF you do multi session charging you can shorten the life and/or reduce capacity. Once I charged my lipos after a flight and didnt use them for a week, maybe two, and they were perfectly fine. I got full flight times out of them.
Lipos tend to hold their charge VERY well. They have the slowest non use discharge of all the types you can find out there (nimh, nicd, li-ion)
Lip84 is offline
Old 08-10-2007, 07:34 PM
Gnascher
Gnascher's Avatar
Congrats and glad to hear it. With that 2150, you'll probably be able to fly until your neck hurts!
The only thing to watch for is if you ROG, let her lift off on her own. If you horse her off the ground, she'll torque left and ground loop. (That's my experience anyway).
Also, if you've got mixing capability, add a little rudder mix with the ailerons ... this plane likes coordinated turns.
Gnascher is offline
Old 08-10-2007, 07:57 PM
Tinman
The Hot dog man
Tinman's Avatar
Thanks for the info G.
I plan on ROG takeoff since I'll be flying at the ball field. I'll keep fast and won't yank her off the ground.
Good idea about the rudder mix. I never thought about doing that. Do you have a specific percentage that works?
Tinman is offline
Old 08-10-2007, 08:40 PM
Gnascher
Gnascher's Avatar
I have a 60% mix, but I think that's a bit on the aggressive side. Use that as a starting point and work back from there.
I like it there but it is VERY responsive (almost twitchy) at that setting. I may try reducing it at some point, but I never think to when I'm actually at the field.
The difference in roll rate between rudder mix and no rudder mix is impressive.
Gnascher is offline
Old 08-10-2007, 08:44 PM
Lip84
Lip84's Avatar
I was wondering about your mixes...do you have it mixed in so that when you apply rudder you get some aileron to prevent roll or do you have it so that when you aileron you get rudder or both?
Seems to me the common sense way is to have aileron mixed in when you apply rudder.
Lip84 is offline
Old 08-10-2007, 08:50 PM
Gnascher
Gnascher's Avatar
No, the opposite. It mixes in a bit of rudder with the aileron to produce a coordinated turn, and counteract any adverse yaw created by the ailerons.
It'd probably be possible to set up a mix to apply opposite aileron (to counter roll coupling) to your rudder inputs if you wanted to do side-slips ... which I think is what you're suggesting.
Adverse yaw is the tendency for an aircraft to (for instance) yaw left momentarily when right aileron is applied. This occurs because it's "easier" for the inside wing to dip than to raise the outside wing. This causes additional drag on the outside wing which causes the aircraft to yaw to the outside of the turn momentarily until other forces combine to counter it.
You can counter adverse yaw either by having a bit of differential in your ailerons (they go UP more than they go DOWN), and/or by applying rudder in the direction of the turn.
Gnascher is offline
Old 08-10-2007, 08:52 PM
Lip84
Lip84's Avatar
I was just thinking...what if you want to roll and have just aileron input but you mixed rudder with your aileron....that would not work. (Thinking of slow rolls or snap rolls, maybe you dont mix in rudder for planes doing roll aerobatics?)
Lip84 is offline
Old 08-10-2007, 08:59 PM
Gnascher
Gnascher's Avatar
I do have a switch on my TX programmed to turn the rudder mix on or off. However, the rudder mix (on my plane anyway) doesn't adversely affect the roll characteristics ... in fact, I find it dramatically increases the roll rate. If I flip off the rudder mix, the roll rate slows down, and I can do slow rolls.
Snap rolls require rudder input anyway (full rudder, full aileron, full elevator usually), so it doesn't matter in that case. Any rudder input I put in on the left-stick overrides the mix anyway.
Gnascher is offline
Old 08-10-2007, 10:51 PM
Tinman
The Hot dog man
Tinman's Avatar
Great info G. Also like your explanation on adverse yaw. Not to many people know what that is.
Tinman is offline
fresbill
13
03-28-2008 04:35 AM
kaz88
13
03-17-2008 01:50 AM
rx20040
08-31-2007 05:31 PM
DamianWalker
15
02-12-2007 10:29 PM
bodie-hammer
8
08-02-2006 07:03 PM
Quick Reply: Charging Lipos...
Page generated in 0.09021 seconds with 13 queries
