Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Seaplanes E-Powered
Seaplanes E-Powered Discuss electric powered seaplanes here
Old 10-11-2007, 02:51 PM   #26
ripster327
Paul
Location: Keuka Lake (One of the Finger Lakes in New York State)
Default A True Pioneer
Larry,
Thanks for your pioneering labor in experimenting with CorrosionX on your electronics and motor.
Paul
ripster327 is offline
Old 10-12-2007, 02:32 AM   #27
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
90 Minute Thermal Duration  60 Minute Thermal Duration  30 Minute Thermal Duration  4kW
Friends: (21)
I did it in my own self interest, but your very welcome anyway
Larry
Larry3215 is offline
Old 07-10-2008, 03:59 PM   #28
Jason23
I own CorrosionX 16oz spray ( RED ONE ) I tried it on my receiver and esc ... I soak both in the stuffs for about 10sec and let it dry on a paper tower for about 1 hrs and I tester back my esc in my rc with a glass of cold water throw it in my esc and as stopped this product dont work ? or I dont do good the instructions ?
thanks for you help !!!
Jason23 is offline
Old 07-10-2008, 05:24 PM   #29
Larry3215
Larry3215's Avatar
Friends: (21)
You need to let it soak long enough to get inside every where and coat all the little parts very well. Make sure it gets inside the case on the Rx and inside the heat shrink on the controller so it covers ALL the electronic parts. It needs to cover the circuit boards and not just the outer case.
The other thing is that if water touches the crystal in the Rx - especially the socket pins - it will de-tune the rx and it will quit working. CorrosionX will not prevent that from happening.
Its not dead - it will start working again as soon as the water drains off.
I think I need a signature.
Larry
Old 07-12-2008, 11:23 PM   #30
Jim Casey
Seaplane Nerd
Jim Casey's Avatar
Club: Florida Float Flyers
Nice report on CorrosionX, Larry.
You're right about not using CorrosionX on servos. They (or at least the cheap ones I use ) have BRUSHED motors. CorrosionX or any other insulating contaminant is not good on motor brushes/commutators. It'd be good to open the servo and apply a little CorrosionX to the circuit board. In reality, servos are pretty water resistant and you can get them pretty wet without hurting them.
ALSO coat any exposed metal parts: Clevises, linkage, hinge pins, tailwheel bracket or water-rudder hardware. Don't forget the motor and float-strut attachment screws.
A fuel engine likes CorrosionX as an after-run to keep the bearings from rusting especially if it has been dunked. Particularly a 4-stroke, since most 4-strokes don't purge the bearings as they run, and if you dunk a 4-stroke it chills quickly and sucks water in thru the bearings or breather. I had to re-bearing an OS.91 because of water contamination and bearing corrosion. BOCA stainless bearings and CorrosionX got it running again, even tho the crank and cam were pretty heavily pitted, too.
Jim Casey is offline
Old 08-09-2017, 07:55 PM   #31
d0uglas
Originally Posted by Larry3215 View Post
Do NOT fly off salt water. It will kill the battery packs in just a few minutes and I don't know how well the CorrosionX would work on protecting the esc's and RX's in salt conditions. They use it for Marine electronics, but they don't normally expect a complete dunking in salt water.
With exception to one pond where I am trying not to wear out my welcome I only have access to saltwater. CX is indeed no match for salt, I don't know what is other than good luck and barriers. Wrap your battery's balance thing as it will corrode otherwise, though I've never had batteries die or degrade in minutes or any amount of time, except for one that I left on the ground during low tide.
But yeah, if you can avoid it, lay off the saltwater, it's heavy on the billfold. But if you do, have at least a liter of isopropyl alcohol on you and another bottle at home to splash and dunk exposed electronics. That stuff has saved me many many dollars.
P.S. Do NOT be tempted to run your motor while its under water with a prop attached to try to 'motor boat' back to shore. The water has soooo much extra resistance compared to air that the motor will draw huge currents and over load. You will probably kill the controller or battery if you try it.
https://youtu.be/fWHqL9WW8rU
Doug
d0uglas is offline
Old Today, 04:48 AM   #32
Psychron
youtube.com/psychron
a lot of waterproofing a seaplane's ESC has to do with suspending it in the center of the plane without letting it touch any exterior walls. this helps to keep the water away from the components. might have to modify the inside. Also, I heard liquid electrical tape is good stuff, or plastidip.
I figured I could waterproof my ESC by hot melt gluing the open ends, then coating the closed ends with either of those two liquid coatings. If I cook the esc, then I just buy a bigger one.. say I fry a 30 amp. I buy a 40 amp instead and it'll run without overheating because it's oversized and underutilized.
I just flew my Icon A5 a couple weekends back and fried the rudder servo.. of course because it was on the bottom of the plane and as a matter of lack of quality control I've come to expect from horizon or e-flite there was a hole in the seam on the underbelly. I managed to fix it.. it's not pretty on the bottom but no one looks at that part until it's in the air and then it's moving too fast. Here's a video showing what I did and where I relocated the servo in order to reduce future risk to it.
-Dan
My Videos
Psychron is online now
For Sale E-flite Park 300 combo, GWS 35a esc, Ultrafly outrunner esc combo, 8a Electrifly ESC Mike Parsons Motors and Speed Controllers for sale & WTB 9 05-21-2009 11:28 PM
waterproofing bawbeeseboy Castle Creations discussion 14 04-04-2009 11:44 PM
Waterproofing CC Phoenix ESCs Maine Flyer Seaplanes E-Powered 1 03-10-2006 09:14 PM
2dogrc ESC SALE!! 18A ESC $20! 2dogrc Airplanes - Electric For Sale & WTB 0 02-23-2006 02:27 PM
Page generated in 0.07123 seconds with 35 queries
