heat from a outrunner - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-20-2009, 05:41 AM
Rhondas
Rhondas's Avatar
Default heat from a outrunner
how hot to the touch should the average brushless motor of speed 400 size with a 8X5 prop be after a 10 minute flight with a 3 cell lipo pack ?
Rhondas is offline
Old 06-20-2009, 05:52 AM
Gnascher
Got My TX - Need 2 Fly!
Gnascher's Avatar
Warm, but not uncomfortably hot.
Gnascher is offline
Old 06-20-2009, 08:14 AM
Whats the kv on that motor, and does your motor have good air flow around the motor, if not, open up some vent holes to let some air get to the motor, also, check to see if air can get out of the rear of the plane for good cooling of the electronics, Take care, Chellie
Old 06-20-2009, 12:48 PM
Sky Sharkster
Sky Sharkster's Avatar
Default Some Like It Hot?
Hi Rhondas,
Gnasher and Chellie are right, generally warm but not too hot to hold in your hand. But a lot depends on whether it's cowled in and how the air venting is working. Outside temperature makes a difference, too.
One way to check before you fly is a Whattmeter. If the amp draw with a particular prop/battery combination is within the specs for the motor, you should be OK. Over-propping (or too many volts for the prop size) may be the single biggest error going. An overly hot motor will be one of the signs, and the final indicator is...smoke. By then, it's too late!
Ron
Sky Sharkster is offline
Old 06-21-2009, 05:24 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
For most people around 140 degrees F is the start of "too hot to touch".
Thats actually a safe temp for most motors. Some of the top quality motors out there have magnets that are safe up to well over 200 degrees C which is 392 deg F and can run that hot all day long with no damage.
The cheep outrunners and inrunners are made with much lower quality parts and the magnets start to deteriorate at 150 deg F or even less.
So if its a cheep motor keep it cool enough to hold your fingers on it for several seconds without being uncomfortably hot. It can still be quite warm, but if you think you need to say ouch, then its too much.
A hi quality motor can run hot enough to blister you with no damage - to the motor at least
Larry3215 is offline
Old 06-21-2009, 05:31 AM
Rhondas
Rhondas's Avatar
Default motor hot to touch
thanks every one
Rhondas is offline
yank51
Humor
06-18-2008 03:13 AM
Calcomputers
8
01-14-2007 11:13 PM
thomdoe
18
09-13-2006 12:46 PM
megaglow_Z
01-02-2006 05:37 PM
RcOre
Aerial Photography
08-18-2005 12:43 AM
Quick Reply: heat from a outrunner
Page generated in 0.06120 seconds with 15 queries
