useing a lipo in place of a nicad battery - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-11-2009, 07:40 AM
Rhondas
Rhondas's Avatar
Default useing a lipo in place of a nicad battery
Product# JE60 I have this type of ESC, Jetti 60 amp with 2 pot adjustments for brake and speed and a switch, I have used it on my planes with speed 400 and speed 600 can type motors and up to 10 cells Nicad type sub C battery packs ,can I use this ESC with a S3 Lipo 1300Mah battery ?
Rhondas is offline
Old 06-11-2009, 09:44 AM
slipstick
Yes (if S3 means 3S i.e. 11.1V). You can use most ESCs with almost any type of battery, it's the voltage and current they care about not where it comes from.
As usual with old ESCs you'll need to time your flights and be careful not to let the lipo voltage run down too low. You can't rely on the LVC on that ESC to be of any use to you.
slipstick is offline
Old 06-14-2009, 04:46 PM
Rhondas
Rhondas's Avatar
Default lipo for a brushed motor
thanks , also Im told never use a 3S 1300mah with a speed 400.and 5x3 prop,its a darn shame I have all these motors even speed 600's and now that Im going into lips , I cant get away with it.thanks
Rhondas is offline
Old 06-14-2009, 04:52 PM
cbatters
cbatters's Avatar
I am running an AB3 with a 380 brushed motor for the last 6 months on a 3S 1100 MAH lipo and it is still going strong. You just need to limit the amount of time at WOT to avoid burning up the motor. (Also critical to have good cooling to the motor.)
cbatters is offline
mtuhoop24
Batteries & Chargers
19
12-09-2015 12:50 AM
jakjr
10-19-2007 09:30 PM
diverdon
09-13-2007 03:03 AM
gymnast
03-10-2007 02:25 PM
confuqua
10
12-12-2005 11:43 PM
Quick Reply: useing a lipo in place of a nicad battery
Page generated in 0.08224 seconds with 13 queries
