best volt per cell for accurate IR reading??? - Page 2 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-22-2015, 07:20 AM
Originally Posted by Flysohigh View Post
Have you used a 308 or higher? They show IR on load
I have the iCharger 4010 Duo, you are correct in that it does show total battery IR during charging but that's no use as far as IR measurement goes. If you want to measure IR do it using the special IR measurement function which as i explained should be done on a rested battery. that will give you IR for each cell rather than just the whole battery.
Old 10-22-2015, 07:28 AM
Forgive me for this "Flysohigh" .... but you really seem to be making a mountain out of a molehill on this.
The iR shown by a typical charger is representative at best and really is only an indication of state. As said by myself and others ... you use these results as indication of battery change - not absolutes. You also need to do the checks at same state of packs.
The total iR of a pack is about as much use as an Icemaker to an Eskimo ... because as said - its the individual cell iR that counts.
Can I ask why the so deep involvement in this iR matter ? You seem so determined on it ...
Believe me I am not trying to be rude or unhelpful ... just honestly interested in your side of this.
Old 10-22-2015, 06:37 PM
They say that a picture paints a thousand words, so maybe a video paints a million?
Anyway, heres a video of how to check I.R. with an iCharger Duo:
Old 10-22-2015, 06:43 PM
Flysohigh
electrified
Flysohigh's Avatar
Just trying to understand howto know whats a good and bad pack thats all
Flysohigh is offline
Old 10-22-2015, 07:40 PM
Good pack delivers the power you need... Bad pack doesn't.
I don't bother with IR testing any more.
When the pack can't handle the full throttle for 30 sec climb-out of the big EDF I move it to something with lower demand. (about 3 yr old packs when they fail this test)
Then when they can't handle the sport aerobatic models they get punctured,/destroyed/burned then trashed (Trashed AFTER they have no potential to burn).
Old 10-22-2015, 08:22 PM
To be honest neither do I, at least not routinely. If I feel that a pack might have an issue I'll I.R. check it to confirm, otherwise I hardly ever bother.
Old 10-22-2015, 08:55 PM
OK now that is the right question. What you have not understood is you need a base line to compare reading to.
The only way to do that is when the batteries are new and under controlled conditions. When you get a new battery, cycle it 5 to 10 time and note capacity and Ri. At first you will get a high reading until you have a few cycles where capacity peaks and Ri is minimum. Now you have a base line for future reference. When you see capacity fading and Ri rising, you know the end is near and time for replacement.
Then after a few years experience, you will give up making those measurements becuase you physically notice performance loss when used. Instead of 7 minutes, you now get 5 minutes. Time for replacement and quit worrying about documenting Ri and capacity. But go through the motions.
Its like college. Everything you learned in college is worthless and not applicable to real world. Just gave you the tools to start learning. When you come out of school you think you know everything until you have gone to work for a weak and realize you should change your name to Dunnochit, or Coward like NoBama.
dereckbc is offline
Old 10-22-2015, 11:02 PM
Flysohigh
electrified
Flysohigh's Avatar
Jaja like that one....ok got it up until now i been using the old method"If it works dont fix it" nkw that i have a charger i can measure IR and get more of a reference but what the heck...just fly fly fly
Old 10-23-2015, 12:13 AM
The light doth flicker at end of tunnel !!
Go fly ... stop worrying about things that really make themselves obvious without need for 'science'.
12-06-2014 08:08 AM
kittiwat1
FMA Direct
12-06-2013 02:22 PM
Henry111
118
03-18-2011 06:27 PM
Quick Reply: best volt per cell for accurate IR reading???
Page generated in 0.11162 seconds with 13 queries
