Airtronics RDS8000 Receiver and Flyzone Cessna 182 Select - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 02-20-2009, 02:41 AM
dman1843
Default Airtronics RDS8000 Receiver and Flyzone Cessna 182 Select
Heres the plane i bought: http://www3.towerhobbies.com/cgi-bin...I=LNVZA9**&P=G
And i had a bad experience with the on board receiver and transmitter so i decided to upgrade it before i even did its initial flight.
I hooked everything up the lipo battery and all the servos and the receiver was not getting any power. Now the 72 Mhz receiver did not need an additional battery for it to operate. Does the RDS8000 Need a receiver batter even though the plane is electric and using a lipo battery as the main source of power? Thanks.
dman1843 is offline
Old 02-20-2009, 03:38 AM
constantCrash
prefectionist
constantCrash's Avatar
just to make sure, you have the battery hooked up to the speed controller (which also hooks up to the motor and the reciever, and then the servos hooked up to the reciever?
are you sure you have the servos plugged in the right way?
constantCrash is offline
Old 02-20-2009, 05:35 PM
dman1843
I'm pretty sure I do i can try some other configurations but yea the battery is plugged into the speed controller and the speed controller is hooked to the throttle channel...So I don't know, I might be doing something wrong Ive read through the manual and i cant find anything about lipo power. Only that a diagram shows that I need a 4.8v Rx batter but i didnt think i needed that since i had the main power source as the lipo..
dman1843 is offline
Old 02-20-2009, 11:34 PM
offtom
Megans Servant
offtom's Avatar
Like the 72 system, just plug the ESC in the throttle channel on the RDS reviever. It doesn't need a seperate battery.
offtom is offline
fmattox11
05-18-2010 04:50 AM
ParkFlyers
76
06-10-2009 06:38 PM
wyldkrd
01-30-2008 06:04 PM
constantCrash
17
12-01-2007 08:50 AM
RCisAddicting
03-17-2007 02:51 AM
Quick Reply: Airtronics RDS8000 Receiver and Flyzone Cessna 182 Select
Page generated in 0.08099 seconds with 13 queries
