Have an elev prob. With the GWS F-15 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 03-09-2009, 04:08 AM
THE.NEED.4.SPEED
Default Have an elev prob. With the GWS F-15
Ok well i have a problem right now so its short and simple. The elevator needs two servos and one go's one way and the other go's the otherway. how can i solve this? I have a GWS 6 ch recever. i hate when this happens.
THE.NEED.4.SPEED is offline
Old 03-09-2009, 06:17 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
You should be fine.
Just plug one servo into the elevator channel and one into the aileron chanel and adjust the programing on your tx to elevons or Delta mix and then reverse one or both channels as needed untill they move in the correct directions.
With some tx's the right side goes into the aileron but that varies from one TX to another so you may need to put the right side into the elevator channel. Try it both ways if you cant get a combination of reversing the channels to work.
Larry3215 is offline
Old 03-10-2009, 07:20 AM
THE.NEED.4.SPEED
Well all the ch's are being used and it has a stearable landing gear. I seen a v-tail connector and was wondering what that would do.
Old 03-10-2009, 02:08 PM
wingspann
Certified Codger
wingspann's Avatar
If your transmitter doesn't have mixing capability, the V-tail mixer should work. You said all of the channels were being used on the reciever... the V-tail mixer would plug into the receiver in place of the elevator servo and the aileron servo. Then plug both of the elevon servos into the mixer.
John
wingspann is offline
Old 03-11-2009, 05:23 PM
foamnpacktape
foamnpacktape's Avatar
Like wingspann said, but further:
If you want to use the steerable gear, you will have to get a Y connector for between the Rx aileron channel and the mixer, one part of the Y goes to the mixer, the other to a separate servo for steering.
foam.
foamnpacktape is offline
Old 03-11-2009, 07:25 PM
Larry3215
Larry3215's Avatar
John
Nose wheel steering is usually done thru the rudder channel not the aileron You could do it either way if thats what your used to. Just be sure to warn any other pilots what you did before they try to fly your plane or if your going to buddy box - there may be mishaps other wise
Old 03-13-2009, 06:43 AM
foamnpacktape
Red face
Correct, not sure what happened there? typin not thinkin, kinda got caught up in the three channel mentality.:o
foam.
Old 03-13-2009, 07:36 AM
Larry3215
Larry3215's Avatar
foam.
Well, the older I get the more certain I become that its NOT old age. I was screwing up long before I got old
THE.NEED.4.SPEED
Electric Ducted Fan Jets
01-06-2009 06:21 PM
herk_1
13
11-08-2008 04:20 PM
mescalinedreamz
ParkFlyers
08-23-2008 09:09 PM
THE.NEED.4.SPEED
8
05-29-2008 06:57 AM
paranoia
08-17-2007 06:29 AM
Quick Reply: Have an elev prob. With the GWS F-15
Page generated in 0.06528 seconds with 13 queries
